Question about Necchi 3101 Mechanical Sewing Machine
Bobbin jamming My bobbin seems to be notting up after about 5-6 forward stitches. I have taken the bobbin out and put it in again, I have fiddled around with my tension but it still seems to knot up.
  • 106 Answers
Sounds like it is the bobbin tension that is causing the problem not the top tension. Have a look in your manual it should explain how to adjust the tension. If you do not have a manual have look at this website if they do not list one for your model email them and they will help. Check out the threading page as well.
www.sewusa.com
Posted on Mar 30, 2008
SOURCE:
Makes one stitch then abrupt stop with threads bunching up from bottom
Have you taken the bobbin out and made sure there is nothing caught in the bobbin race area. Maybe even unscrew the plate and take the whole bobbin race assembly apart and clean well. Once that is done put back together then re thread machine. Next I would start by hand turning the machine and doing some stitches slowly with the fly wheel make sure to to forwards only never turn the fly wheel back wards. If everything seems clear give it some power slowly and see how it goes.
Feb 11, 2014 | Singer 9960 Quantum Stylist Sewing Machine
Thread becomes jammed in reverse
Reverse can be tricky if the machine is not timed correctly. So try this. after you've stitched forward for a while, use the hand wheel to bring the needle all the way down into the fabric and let it come part way up. Then push your back button and take your back stitches. If that works for you then you know the machine should be checked for proper timing.
Oct 02, 2013 | Singer Sewing Machines
Machine jams after 4 or 5 stitches. Bobbin thread locks up.
try these suggestions
change the needle
make sure the thread doesn't come off the thread take up lever--this
can jam the machine
make sure the bobbin is turned the right way in the bobbin case--this
can cause problems if the bobbin is turned the wrong way
make sure the bobbin is not warped or damaged
make sure there are no burrs in the bobbin area or on the needle
plate
Oct 16, 2012 | Singer 8280 Mechanical Sewing Machine
I hit a pin with my Singer Stylist 7258. It jammed. I changed the needle, rethreaded it, and turned it off and on, but it snarls up thread under the fabric, and seems that the thread does not always loop...
Good that you changed the needle. Did you rethread just the needle or did you rethread the machine? You may have already taken these steps, but if not, here is what I would suggest:
1. Replace the old needle (which you did), even if it looks ok, as it may be bent or have a tiny burr or other damage that isn't easily visible. Make sure the needle is seated properly - facing forward and fully inserted.
2. **Completely rethread the machine, making sure the thread is going through the take-up lever. It can easily pop out when the machine jams, and you can't always see that the thread is out of place. That could explain why the thread doesn't loop properly around the bobbin.
3. Remove the bobbin and clean any knotted thread or lint from around the bobbin carrier. Canned air is great for cleaning the lint.
4. Replace the bobbin, making sure the thread-end is clipped neat, not frayed or knotted.
5. Try sewing on some practice fabric to make sure the stitches are going to form properly before returning to your sewing project.
Apr 01, 2011 | Singer Sewing Machines
I have a Janome 4900Qc which has the sign Stop for Safety Purposes, this comes up really often, it has been back and been checked but no better now
Are you having thread jamming problems before you get this message?
I found that my bobbin holder which is held by magnets was being dislodged when I had a thread jam up, usually when I was trying to sew something very thick over a seam such as jeans hems.
Have you mastered removing the needle plate and the bobbin holder to clean in under it and putting this all back together again? With my 6500P, the needle had been striking the bobbin holder when it dislodged and rotated out of postion, the bobbin case had holes and damage to the plastic which was then catching the thread as the bobbin rotated making the jams happen.
Each time, I would dismantle the bobbin holder, clean everything, cut the jammed up threads, check the bobbin case and give the damaged bit a file with a nail file to make it smooth again, then put it back matching the red markings on the bobbin holder and the stopper, rethread and start over. I have bought two new bobbin cases too and taken it back to the dealer a couple of times over 5 years.
I've now learnt to not try to stitch over the thick seam intersections, I'll stop before, lift the pressure foot, move the work past the seam, then restart sewing. However, my machine was just serviced last week and it looks to me like the mechanic has added a part to hold the bobbin case in better, its like a little black lug on the left screwed into the outer housing. So perhaps Janome have addressed this issue with an aftermarket repair.
Apologies if this is telling stuff you already knew, good luck.
Mar 07, 2011 | Sewing Machines
My old machine has jammed and cannot stitch
You need to take the bobbin case out to check thouroughly for a piece of thread that may be stuck, that is usually the answer.
Jun 10, 2010 | Sewing Machines
My bobbin wont feed through
take the bobbin out check for debris (pieces of thread, lint, etc.) that may be jamming the bobbin. check under the feed plate for a thread jam or debris. check if your bobbin is wound too tightly. it can happen! then it will keep breaking. the other adjustments are mainly for thread tension- the spool on top. if they're too tight, the thread will keep breaking. you can tell- once they're properly adjusted- by the quality of the stitch. check the bobbin first! if it's too tightly wound, you can probably adjust the winding tension on top. try a different bobbin. if that works then 'rinse and repeat!'.
good luck!
Sep 24, 2009 | White Sewing 1418 Mechanical Sewing...
No stitch happening
May sure you are using the correct size of needle and thread suitable for the fabric. make sure the thread in the bobbin and the needle is of the same weight or size. Make sure the needle is changed often - after the completion of an garment. After much use the needles become blunt and cause problems with your stitches.
Also, if the bobbin is jamming that is normally because the machine is threaded incorrectly, or the bobbin case thread is wound unevenly, or the bobbin case is not put in properly.
Try this! Just stop for a while, give yourself a few minutes to relax. When you return pull the User's Manual and slowly go over the instructions, especially the "troubleshooting" section. Also, rethread the machine and the bobbin case by carefully following the steps in your User Manual. I have found that it helps me tremendously when I have problems. Hope it help. Happy Sewing
I have similar problems
Aug 02, 2009 | Janome 8080 Computerized Sewing Machine
Sewing Machine, Upper Thread Jamming in Bobbin
I am having this problem also, and it is jerking up the whole bobbin case. I went to Joann's - the lady there said I have worn out the bobbin case and need to replace it.
Jan 04, 2008 | Sewing Machines
A horrible tangle
This is a bit late, could the bobbin case not be seated properly? You need to put it into place and then turn it clockwise until it seats soundly in the opening. Also, check for burrs...the needle may have left a rough mark on the plastic or metal in the bobbin area. A piece of batting, or even an old knee hi should snag on any rough areas.
Jan 05, 2007 | Singer 2662
Necchi 3101 Mechanical Sewing Machine Logo
117 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
