Question about Kenwood VR615 Receiver
Volume adjustment I have a Kenwood VR615 (No Volume) ...as I turn the volume clockwise it goes up to "0Db" and if I turn in the opposite direction goes to "-1Db" , "-2Db" , and on and on until reaches "-92Db"...."00Db". ...any does't matter to which direction I turn I don't have volume! I guess I need to configurate/adjust the volume settings to positive and I do not know how to do that.
  • 1,557 Answers
Its more than that i think you have either turned your speakers a/b off or have blown up the sound valve i would send it in for checking by a ppro as no adjustment would be needed to get at least some sound
Posted on May 15, 2010
Kenwood receiver
Could have an open internal fuse
Sep 01, 2016 | Kenwood VR615 Receiver
How come i can only adjust the volume levels on the center, surround sound left and right, and the sub, down but not up? is 0 max volume?
Some equipment use 0dB as the reference, and you can choose to decrease the volume from that point. If you need to "increase" beyond 0dB, you need to reduce volume on the main speakers so the volume is finally balanced between all speakers.
May 15, 2016 | Audio Players & Recorders
When I turn volume knob to a higher volume, volume decreases...
Could be a Japanese system, that's the way it works, unless u going to switch the outer wires on the volume controls, then it would work clockwise, that if its not soldered on the circuit board.
Oct 25, 2013 | Kenwood VR-505 Receiver
Kenwood
I'm assuming 'Kenwood' means a home stereo amp or receiver? If so, the volume control probably just needs to be cleaned. Control cleaner can be purchased at Radio Shack, or a similar store. Just buy a can, and spray a tiny amount into the control, and turn it all the way clockwise then all the way counterclockwise several times. If that doesn't correct the problem, the control may just be worn-out and is in need of replacement.
Apr 28, 2013 | Audio Players & Recorders
When I adjust the volume, I'll turn the knob, for instance, counter clockwise to turn it down. It will go down a couple digits and then may go up again.
hi richard, seems as if your rotary volume control internal switch pins are wearing out. this is a typical problem on many units that use rotary/digital encoder volume controls. before replacing the control clean the face pins, or have the pc board checked for moisture damage, or have the solder joints checked on the volume control. cheers.
Jun 23, 2012 | Kenwood KDC-322 CD Player
Kenwood km-994 is to loud when volume dial is on low and will blow speakers if I turn it up
I'm no sure what you're asking. Do you mean that it goes directly from low to high immediately when you turn the dial(I'm assuming it has a dial, I haven't looked it up) or push the up or down button?
Answer is, if rotary, a bad rotary switch, or in both cases, a bad microprocessor or electronic volume.
May 02, 2012 | Kenwood Audio Players & Recorders
My kenwood vr615 reciever had the volume turned up, unit shut down and now when it gets to a certain volume that is much lower than normal it will turn off and the stand-by light will flash, I have to turn...
hello ,i strongly suspect the units protect circuit is sensing a speaker problem.Listen to each speaker to see if all the drivers(woofer,midrange,tweeter) are working and if so are any of them sounding distorted.When an amp is damaged it wont play at all,sounds like a bad speaker to me.
Jan 09, 2011 | Kenwood VR615 Receiver
Purchased your A/V reciever NS-R5101 yesterday. When I removed it from the carton I noticed that Master Volume Dial has no stops in either direction. Dial turns continually in clockwise and counter...
This type of volume control is often called an encoder. Basically it is a control for an electronic volume control chip. Rather than a vairable resistor like the "old fashioned" volume controls, this one basically is a rotary on/off switch. As you turn it the internal fingers pass over copper bars causing quick on/off sequences. These are interpreted as vol up and vol down.
Realise that this is an over simplification, but is essentially how it works. Your unit is fine.
Dan
Jul 29, 2008 | Insignia Audio Players & Recorders
SA-AK95 volume control problem
This volume controls is actually what is called an encoder. The control itself needs to be replaced. Figure on $5-$10 for the part plus the local labor rate for the total repair cost.
Dan
May 01, 2008 | Panasonic SC-AK75 Shelf System
Kenwood VR615 Receiver Logo
163 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
