Question about Whirlpool LER5636P Electric Dryer
Heat without Drying - Whirlpool Dryer
I just moved into a new place and my dryer has never had any problems before. We had to switch from the 3 prong cord to the 4 prong but otherwise installed it no problem. Everything seems to be running fine (the dryer is tumbling and the clothes are getting hot) but I've been drying the same load for 4 cycles now and they are still wet...not damp. I checked the duct and the dryer side of the duct and the wall side of the duct and it seems nice and clear. The lint collector on the dryer is empty as well. The only suspicious thing is that there is a light that comes on the back of the unit periodically while running....it glows orange for a few seconds and then shuts off.
Please help!
  • geminivo Apr 04, 2008
    i had to change the 3 prong cord to the 4 prong cord when i moved to my new apartment the dryer is not getting as hot as it should and clothes are damp not dry. what could be the problem please advise on what to check for.my dryer worked until i changed out the cord.
  • robert samples May 11, 2010
    try drying a load with the vent unhooked from the dryer and what kind of vent do you have it hooked up to go out side with the vent hooked up and check the airflow and let me know also make sure the damper door is opening
The exterior exhaust vent for the dryer was locked shut not allowing the air to escape. So hopefully that will completely solve the problem!
Posted on Apr 01, 2008
Dryer not heating and timer dosen't move
A dryer runs 2 halfs (one half 120, the other 120). Sounds like you are missing the 120 that operates those two. Did you change from a four prong to a three prong?
Jun 02, 2012 | Whirlpool LEB6200 Electric Dryer
Just moved, the dryer has a 4 prong plug and house has 3. Should it replace plug to dryer to 3 prong or house plug?
Buy a 3 wire cord and install it on the dryer. Hang onto the 4 wire one in case you move again.
Aug 28, 2011 | Whirlpool LER4634J Electric Dryer
Moved and the new place has a 4 prong outlet. i need the wiring diagram to switch from 3 prong to 4 prong power cord
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2010 | Dryers
I was switching the electrical cord from a 3 prong to a 4 prong and grounded a hot wire. there was a big pop and now i cant get it to start. would i have blown it up?
WHy are you switching the cord from a 3 to a 4? If the dryer came with a 3 prong cord and its a 3 prong terminal block, then i dont think you can change it to a 4 becuase you will short circuit. DOes the terminal block where your cord was hooked up have 4 terminals. Each termial can only have one lead/wire to it. check your circiut breaker panel? Is the circiut breaker tripped?
Jul 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
GE Dryer not producing heat
First, replace the door switch. Second, check the wiring of the new cord. It should be as follows:
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Third, if you still have no heat, make sure there is strong air flow out the vent outside the house when the dryer is running. If all that is good, check for 240 volts to dryer. (dryers can run the motor on 120, but need 240 to heat). Comment back (including model number) if you have further questions.
May 22, 2009 | LG DLE7177 Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
My Whirlpool Gas Dryer (MDL # LGR7648KQ1) is not drying properly. The unit will heat up initially but after a while it will not ignite. I've taken it apart and run it without the drum. It ignited...
Be sure the vent is totaly clear.if the t-stat(s) heat up from lack of air flow the heat will not return until the t-stat is cool enough.Running without the drum in place will also heat up the sensor(s).This is a very common problem.
Oct 25, 2008 | Whirlpool Dryers
New dryer (Maytag Bravos MED6400TB0) will not heat but the dryer I just replaced works great
AF warning comes up during the drying cycle. What is this?
Jan 14, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
125 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
