Question about Pioneer VSX-35TX Receiver
VSX-35TX 5.1 Channels Receiver: Receiver would only stay on a few seconds, and a l...
Receiver would only stay on a few seconds and a little smoke came up through the top when started repeatedly. found 2 fets (IRF9450 & IRF450) in one channel of the power amp were shorted. Replaced them. The resistors that gave off the smoke seemed to be ok (same reading as on other channels) so I left them. after replacement it stays on there is no smoke all the controls and displays seem normal but there is no output on any of the channels. The pre-outs are ok but nothing on any of the speakers. any ideas?
How do you troubleshoot a Pioneer VSX-1023 A/V receiver?
Try to do the factory reset on the Pioneer:
Switch the Pioneer into standby (turn it off).
1. Simultaneously press old the buttons on font panel for 5 seconds - BAND & STANDBY/ON
2. "Reset" on the front panel press
AUTO SURROUND/STREAM DIRECT
3. Then press ALC/STANDARD SURROUND
OR
Simultaneously pressing "down" and "on/off" for 5 seconds to reset the Pioneer
Mar 05, 2015 | Pioneer VSX-1023-K Receiver 7.1 Channels,...
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
My power went out while watching TV. Now there is no sound when I turn my receiver to TV/SAT. If I put the receiver on CD there is sound but no picture. The receiver works fine if I go to DVD; there is...
It would seem the TV/SAT source is where the problem lies. No picture with CD? Really?
How about bypassing the receiver to prove what is failing?
Apr 21, 2011 | Pioneer VSX-35TX Receiver
VSX-1018AH-K 7 Channels Receiver: My VSX 1018AH mutes automatically after 15 seconds...
The exact problem just started with my same receiver, did you get a solution to it in any way ?
May 16, 2010 | Pioneer VSX-1018AH-K Receiver
I have a VSX-35TX receiver. When I turn on power,the receiver turns itself right off. Yesterday, the receiver would stay on for a few minutes after I turned it on.
Disconnect all your speaker wires at the receiver then turn it back on. If it stays on, your receiver is ok and you need to re-connect each speaker wire and test power. You will either find the fault or fix the problem. If you need further help troubleshooting, post a comment and I will help some more. Hope this helps
Sep 23, 2009 | Audio Players & Recorders
Looking to connect 4 speakers to the surround back
Series the speakers, they may not get as much power as you would like, but your receiver will last longer.
Aug 16, 2009 | Pioneer VSX-518-K Receiver
Pioneer VSX-35TX , "Power Off Message" , will not stay on.
It's probably going to need output transistors and some resistors, it's a job for a technician. A rough estimate on price is $100 to $130 (that's parts and labor). Before the smoke it may have only needed repair of bad connections.
Mar 08, 2009 | Pioneer VSX-35TX Receiver
I have pioneer receiver Vsx-454 i want to know if this receiver is 5.1 surrounds
Yes. It is 5.1 surround. There are 2 front channels, 1 center channel, and 2 rear channels which comprise the "5" in 5.1 surround. The pre-amp output channel for a sub is the ".5".
Jan 11, 2009 | Pioneer VSX-454 Receiver
PIoneer VSX-D510 power issue! pleas help!
Must be the protection circuits kicking in. One or more amp channels must have blown.
Feb 01, 2008 | Pioneer VSX-D511 Receiver
Pioneer VSX-35TX Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
