Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi rearTV has intermittent wavy lines running throughout
Tv has intermittent horizontal or vertical wavy lines running throughout picture and blurring screen.happens whether watching tv or dvd or playing video games. It's a mitsubishi Medallion 65in rear projection hdtv
    Problem Solver:
  • 12 Answers
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
Posted on May 16, 2010
  • 4 Answers
THIS ISSUE is caused by a faulty 9 volt Regulator on these TVs. Located behind the input jack panel.
IC9C25. Replace with "LM7809" chip.
Cheap and easy repair.
Posted on Oct 11, 2012
How do I fix wavy lines on Hauppauge Wintv hvr950q?
Are they wavy lines throughout the picture or are they just wavy on the side? Waving picture is usually caused by poor power supply filtering. Wavy lines throughout the picture are caused by interference. Try moving the device away from the computer with an extension USB cable it may be picking up interference from the surrounding electronic devices. It could also be defective.
Oct 19, 2014 | Hauppauge WinTV-HVR-950Q (1191) TV Input
Mitsubishi VS-4543
is that wavy in vertical motion? and bending?  in that case maybe you have low voltage in your power inlet! or can you specify the color of wave and motion, if horizontal or vertical?
Oct 16, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Wavy horizontal lines running through the screen
Ur tv convergence is dead.U must know how to solders?The 2 STK convergence ICS.and some or all it resistors must change.Tries websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 17, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WD5725 DLP set. Picture is Ok before
The set has over 150 capacitors that could be causing the problem but it is at least 1 doing this. Contact Mitsubishi. Some people have been able to get new replacment TVs because of this problem
Mar 04, 2010 | Mitsubishi Televison & Video
Picture is wavy and has black vertical and horizontal band
The following are supposed to be checked on the horizontal and vertical,
the supply of the sawtooth oscillator
eletrolitic capacitors near a line transformer
zener diodes
and driver transistor a round that area.
Apr 08, 2009 | Toshiba 35A44 35" TV
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Mitsubishi WS-65809 65" Rear Projection Television Logo
725 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
