Question about NEC MultiSync MT1030 Multimedia Projector
Picked up a nec MT1030+ on a gov auction with no remote. Lamp hours have exceeded the 2100 and projector is shut down. With out remote how do I get it back on? I guess I should be specific here. I have replaced the lamp. The projector is plugged in switch is on in the front and there is a red light and a yellow light on. None of the buttons work to turn it on.
First make sure that you have install the bulb correctly. There are number of issues that can cause this problem.
1.Check for dirty air filter and clean if need. Make sure the air filter cover is on all the way. Make sure the cover to the lamp is on all the way, and that the screws are tight.
2. First turn off and unplug the projector. Then remove and reinstall the lamp, with cover firmly fixed. Make sure are cover are properly fastened. You should get the projector to turn on by pushing the power button on the unit. Wait for an hour if you keep having this problem, then plug the unit back in.
3. Then reset the lamp timer. Sorry I don't how to reset the timer. I home manufactured an LED lamp for mine, so I don't have to worry about replacing lamps anymore.
You might want to ask someone here on the fixya forums how to do a hard reset of the timer and unit.
You might find projector central.com helpful, where the owers manual for the MT 1030 is available in PDF version.
http://www.projectorcentral.com/NEC-MultiSync_MT1030+.htm
Posted on Feb 09, 2011
2 Suggested Answers
  • 3278 Answers
SOURCE: picked up a NEC MT1030+ on a gov auction with NO
Hello, Paul.
You don't need the remote to power on the projector. There are front panel controls that power on/off.
The problem is that you need to replace the lamp. The lamps cost $200 +, USD.
Hope this helps.
Posted on Mar 14, 2010
Lamp hour reset NEC MT1060
The NEC MT1060 lamp hours is stored in an EEPROM chip built into the lamp. As soon as you put in a new lamp (MT60LP or MT60LPS), the hours will be reset. If you remove and put back in an old lamp, the unit will see the hours on that lamp. Thus if the lamp has reached 2100 hours, the projector will remain in standby. See page 53 of the manual for the replacement and reset information.
Most of the manuals for the NEC projectors are available here: http://www.nec-display.com/dl/en/pj_manual/lineup.html . The direct link to the manual for the MT1060 is http://www.nec-display.com/dl/en/pj_manual/mt1065.html .
I hope this helps.
May 24, 2016 | NEC MT1060 Multimedia Projector
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
I replaced the lamp on my NEC LT280, but am unable to reset the lamp so that the projector works again.
Whe the lamp exceeds 2100 hours (up to 3100 hours in ECO mode) of service, the projector cannot turn onand the menu is not displayed. If this happens, press the HELP button on the remote for 10 seconds to reset the lamp clock back to zero. When the lamp clock is reset to zero, the LAMP indicator goes out.
Here is the URL for the User Manual:
http://www.necdisplay.com/documents/UserManuals/LT380_user_manual.pdf
Dec 14, 2014 | NEC LT280 LCD Projector
VT595 won't power on, no power indicatior led. There is power at outlet
When the lamp exceeds 2100 hours of service, the projector cannot turn on
have it checked out at the service center
Aug 22, 2014 | NEC Office Equipment & Supplies
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
Picked up a NEC MT1030+ on a gov auction with NO REMOTE. Lamp hours have exceeded the 2100 and projector is shut down. With out remote, how do I get it back on?
Hello, Paul.
Hope this helps.
Mar 14, 2010 | NEC MultiSync MT1030 Multimedia Projector
I replaced the bulb in my projector and now it
You need to hold the help button on the remote control for ten seconds, that should reset the lamp hour. NEC decided to make it inoperable after 2100 hours on the bulb.
Nov 13, 2009 | NEC VT700 Projector
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
Preylahong NEC MT830+need help to reset new lamp
After replacing lamp in MT-830(NEC) press and hold "on" button for 10 seconds to reset lamp hours. If projector has beyond 2100 hours press the "off" button for 10 second.
May 01, 2008 | Office Equipment & Supplies
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 08, 2008 | NEC VT47 Multimedia Projector
NEC MultiSync MT1030 Multimedia Projector Logo
270 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
