We have a ge washing machine model number WJRE5500G1WW. We were starting a new load of laundry and the washer was just filling with water. There was a loud noise we stopped the machine and it looks as if the entire central component that holds the washer separated from the metal shell. It is no longer suspended from the outer support framework and is floating unsupported. Do you know what we should do to fix this?
Posted on Jul 31, 2010
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
Why does my GE front load model#GFWH1200DOWW leak water from the back?
had same problem on my washing machine. got some plumbers tape from the hardware shop and wrap in around the screw thread before fitting the plastic screw connector of the hose to the washing machine.and tigthening it up.
Jan 07, 2015 | GE GFWH1200DWW Laundry : Front Load...
GE washer wont wash and spin?
Is this a new machine? If so, then it may have a sensor that lets it know that you have a big enough load. Mine will only wash when I have a full load of laundry.
If you have had it for a while and it just quit, then you may have a broken belt. A third suggestion might be that your drain is clogged. Any of these could stop a front load machine from washing.
The numbers you gave were for the noise filter on the washer. Not sure if that would make any difference or not.
Dec 07, 2013 | GE Washer Filter Power Line WH12X10330...
Ge spacemaker laundry dryer does not heat
All dryers have states to control heat GE has a safty stat that is comon problem small round stat at top after removing lid check with ohms meter with wire unpluged if no continuity changed then check venting of dryer inside and out improper venting will cause dryer to over heat
heat element is the next go to same check but must take dryer apart more send model Number we can give you a diagram and location of everthing you will need
Jan 30, 2013 | GE Spacemaker Washer and Dryer Electric...
Ge washing machine wsxh208a1ww, The dial seems to get stuck during all cycles. If you go out and manually turn the dial one click it will keeping going. But it takes forever to do a load of laundry since...
The bad news is that you most likely need a new timer. I get mine (used) from e-bay after looking up the parts at "Sears Parts" by model number. Sears will sell you new parts by model number for your GE.
Be blessed.
Nov 08, 2010 | GE Washer Washing Machine Timer WH12X1000
Ge wjre5500g1ww. My washer will do the cycle but at the end the softener is till full and the cloth still soak wet. Any way to fix this issue?
Try this:
Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. Put the machine in a spin cycle and see if it runs.
Mar 26, 2010 | GE Washing Machines
How do I get my GE agitator out? model #WJRE5500G1WW
I will be very happy to assist you in this issue.
http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
i hope this answer your question
your rating and comment its very important to me
thank you
Nov 13, 2009 | Washing Machines
Ge washer M#: wjre5500g1ww will not fill
First, make sure there's water getting to the washing machine. if the hoses are not kinked and, the water is reaching the unit, replace the water valve assembly.
Jun 19, 2009 | GE WBSE2090A Top Load Washer
GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Nov 12, 2008 | GE WBVH6240F Front Load Washer
Washing Machines Logo
292 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
