Question about Toshiba Satellite A100-S8111TD Notebook
Screen rotation Hi, I'm a bit of a computer klutz and I rotated by screen 90 degrees clockwise by mistake so that I have to turn my head sideways to look at the screen, how do I reverse my mystake?
  • addyme4me Oct 14, 2008
    i have same problem have to turn my head to the side to view page .what icon do i need to use to get it back in the upright position
  • 655 Answers
There is an icon for your screen setup on the tray.
right click on it. an option will be there in pop-up appeared for rotation. Select the right choice.. n njoy.....
thanks
iqbal
Posted on Mar 30, 2008
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
My screen turned sideways
go to Control panel, and find Graphics / Video icon e.g. Intel, Nvidia etc.. There is an option to rotate 90 degrees clockwise or counterclockwise. Select that setting until your screen is turned in a normal way..
Aug 07, 2011 | HP Mini 1000 Netbook
My computer screen went sideways and now i have 2 turn my computer sidewayys too how do i fix it
Most likely the change was on the display setting. You need to get to diplay settings and rotate the screen another 90 degrees.
Jun 30, 2011 | Acer Computers & Internet
Screen Rotation problem
To revert the screen to normal upright position, press these three keys together:
ALT CTRL and UP Arrow key.
(See attached image)
Hope this solves your problem. Thanks for using FixYa.
Jun 12, 2010 | Acer X193W LCD Monitor
Data on the screen is all loads 90 dgre rotat to norm
Hi there.
Hold down Ctrl, Alt and the press one of the cursor keys to rotate the screen back to the position you had it in.
Good luck and thanks for using Fixya!!!
Mar 02, 2009 | Dell Inspiron 6000 Notebook
Monitor screen displays sideways
if the screen is rotated then press
ctrl + alt + up arrow
your screen will be placed correctly
this is happened because sometime you might have pressed by mistake ctrl + alt + some arrow key .....
the hot key will be enabled defaultly so your screen got rotated
Jul 05, 2008 | Gateway FPD1950
My screen is functioning but the picture is turned 90 degrees
Use ctrl+alt+ up Arrow key (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Dec 27, 2007 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba Satellite A100-S8111TD Notebook Logo
532 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
