Question about Boating
Motor keeps running after key has been turn'd off
  • 5,520 Answers
Check your wiring to the starter solenoid. Also the keyswitch. The ignition has 2 ways of getting power. The START position on most keyswitches carries the "tickler" charge to make the solenoid work and another charge to the ignition.
The second terminal supplying ignition power is the RUN position which keeps the engine running.
When you turn the keyswitch to OFF both of the terminals (RUN,START) on the KEYSWITCH are suppose to be dead. Make sure no added equipment is able to supply power to the ignition.
Posted on May 15, 2010
My cub cadet 2146 pto won't turn on, also the key will not shut off the motor. I recently took the motor off to replace a sheared fly wheel key way.
Hi
Sounds like you didnt replace the immobiliser chip or reprogram the new one.
Get a diagnostic test to verify
Apr 24, 2017 | Cars & Trucks
The starter motor keeps running after you turn the key off
try to check your ignition cylinder specially the back plate of the cylinder for loose or short.
Mar 10, 2015 | Cars & Trucks
Radiator fan runs after ignition is off and key is removed
Does the fan motor shut off after a time or does it run your battery down?
If it runs for a time and shuts off, this is normal with a lot of cars today. It is a second stage cooling system that keeps cooling even after the motor is turned off. They all have either a temperature control or timer switch that turn them off.
If the motor runs till your battery is discharged then the temperature or timer control switch has gone bad and needs to be replaced.
Should you find that your car is overheating while in town, then the fan motor or sensor switch are usually what is at fault and will need to be evaluated and replaced accordingly.
Dec 27, 2013 | 2007 Jaguar X-Type 3.0 Sedan
99 dodge ram 3500 diesel starter will not shut off with key, turn off key and starter moter stays engaged and engine has run on. had to disconnect both batteries. gently tapped starter selenoid with hammer...
it sounds like the starter solenoid contacts are not separating to stop the starter from turning.the run on is due to the starter not stopping causing the motor to continue to spin.replace the starter unit as it will have damage due to being engaged with the motor running,also have the flywheel inspected to make sure the teeth are not damaged on it.
Apr 12, 2011 | 1995 Dodge Ram 3500
2001 ford f-150 it has a 4.6 motor the temp gauge goes all the way to hot when the key is turned on and stays there while running but the motor is not running hot the motor looses power like it is going...
PROBLEM IN THE ENGINE COOLANT TEMPERATURE SENDER UNIT.IF ITS FAULTY BY IT BEING PART OF THE PCM.IT WILL TELL PCM ENGINE RUNNING HOT WHICH WILL SHUT DOWN TO KEEP FROM DOING FURTHER DAMAGE.
Apr 23, 2010 | 2001 Ford F150 Styleside SuperCrew
Truck won't keep running
Try giving the intake air control motor a few whacks with the handle end of a screw driver. You'll find that on the throttle body, it looks like a little metal cylinder with an electrical connector on it. While someone is keeping the truck running, a few light whacks will do. If it keeps running after that, replace the IAC motor.
Aug 25, 2009 | 1992 Ford F250
Turn the switch off motor keeps running
It sounds like there is a short in the alternator or wiring for alternator. You are continuing running with the battery cut off. But the outboard generates its own power and its finding the way to the ignition. As for grounding, you may be idling too high for a quick shut off.
Jun 18, 2009 | Boating
2004 impala blower motor
The purple wire voltage, black wire is ground, at the blower motor. At the blower motor control processor, the red wire is a fuse protected circuit, hot all the time. With hvac off, if nothing on the speed control circuit, doesn't the problem have to be the control processor? Do you see it differently? Just my opinion.
Jun 01, 2017 | 2002 Chevrolet Impala
Boating Logo
142 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
