The drum is making a lot of noice when the drum is spinnig
  • 164 Answers
One word, bearings. they're bad. depending on the age of the machine either replace the bearings or the machine.
Posted on Apr 01, 2008
Top Load or frontload machine?
Posted on Mar 31, 2008
KNOCKING NOICE AT BACK WHEEL
check the rear hand brake in the drum. they are prone to undo the the pin that holds the hand brake shoe in place. when the pin falls out it can make a knocking sound as the pin is being hit and can cause damage to the shoe and drum. you will need to take the drum off and check shoe and change the pin/pins...
Jan 06, 2014 | 2000 Audi A4
MY zanussi, ZWI1125, FRONT LOADER, now makes such a noice on washing and spinning. the plumber has relevelled it but it still makes a noice esp on spinning. Why?
This could be something stuck in the drum ie ,A bra wire or could be bearing trouble an engineer could tell you within seconds.
Oct 30, 2013 | Zanussi Washing Machines
I have a Westpoint Frontloader washing machine. Everything goes well untill it starts spinning. Then is starts shaking and there's a lot of noice. We did make sure that it is level. What else
It is so common that the washing machine can maketerrible noise in many ways and is a common fault. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that machine isvibrating when it is running then the motor /drum suspension has to beinspected. Since these fittings are located on the underside of the machine itis important that you look for the noise with a good inspection lamp. Manuallyturn the motor and drum and listen for the noise, if so the motor bearings, thedrum agitator shaft and fittings must be checked. Also the suspensions whichinclude the shock absorbers and springs, the body clamps must be checked to bein correct alignment and not changed in position. Tightening of themounting is also very important. Finallyin most cases a drop of OIL or smear of grease on the moving parts cane solvemost issues.Check this link :http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlFor replacement of bearings check for tips on thisvisual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jul 05, 2012 | LG Washing Machines
Hotpoint WT965 is making a loud noise when spinnig
Suspect bearings. With door open wiggle the top of the silver drum If it moves up and down inside the tub, replace the bearings
May 15, 2012 | Washing Machines
Why is my washing machine making a loud banging noise when spinnig?
wip the top off and have a look at the big stabilizer springs that hold the drum up if one is missing or broken off replace it,,,,if these springs brake or fall off the washer dose a grate dance around the floor done it?
Nov 24, 2010 | Indesit W 123 Front Load Washer
My window ac is making lot of noice.whom to contact?
You may have an HVAC parts supplier in your town. Big towns have more than one. Quiz the guys that sell the parts they know their customers and can recommend one that they like as you'll find that you'll like them too.
Aug 12, 2009 | Heating & Cooling
Machine drum makes loud noice in the spin cycle. Makes the same sound that a top-loading machine makes when it goes out of balance. Help.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 20, 2009 | Kenmore Washing Machines
Hotpoint tuble dryer, Aquarius, VTD20 makes scraping sound
sounds like the back drum shaft has worn and dropped through back[plate ... there is a fix for this by buying a new drum shaft and support kit comes with front bearing also .. can be a tricky job tho ....
Mar 30, 2009 | Hotpoint NWXR473EV Dryer
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
