Question about Blenders
I have bfp-10ch 600w cuisinart powerblend duet. It powers up but not turning.motor winding are ok.light keep flashing & ifyou press grind or any fuction light get solid but blender won't turn
4 Suggested Answers
  • 87 Answers
SOURCE: I have the red Cuisinart
if you over loaded these machines there is a thermal fuse one time shot will blow . it is not resettable , you can buy them @ Radio Shack 8 amp should do fine . it might be stamped with the rating value too. need a test meter to check component very small .187 diameter & .750 length apx
Posted on Mar 14, 2010
SOURCE: Cuisinart Smartpower Duet model BFP-703.
The thermal fuse is located on top of the windings. It is hard to get at unless you take the circuit board off. Any luck finding the part number? I had the same problem with my blender... :(
Posted on Jan 28, 2011
SOURCE: Cuisinart BFP-703CH Chrome Blender does not start
I had the exact same problem with my Cuisinart bfp-703ch blender. When I plug it in, the lights come on but the motor wouldn't run. After reading some posts I almost decided to throw it away. But my brain started to itch and I gave it a shot anyway. I eventually found the problem to be with the Thermal fuse. If you overload/overheat the blender, this fuse is going to blow off.
To replace it, I opened the bottom panel and followed the wires that come from the circuit. Once of those wires eventually will lead to the thermal fuse. It may help you if you unscrew the circuit board. Then I detached the fuse with pliers, got a replacement thermal fuse from Radioshack and connected it back on. I also had to solder it to make sure the connection is more robust. And Voila!!! my motor started working again.
Posted on Dec 23, 2011
Base of my blender won't detach
please use the WD-40 for to loose and Ready.go www.40company.com
God bless you
Nov 06, 2013 | Cuisinart BFP-703CH SmartPower Duet...
My cord to my bfp-703 cuisinart blender melted can it be replaced ?
Unfortunately it cannot. Cuisinart does not sell parts direct to consumers. However, their products carry 3 year warranties. Contact Cuisinart directly and they will be able to assist you with getting the unit fixed.
Apr 08, 2012 | Cuisinart BFP-703 Blender
Manual is destroyed. Need new copy for Cuisinart PowerBlend Blender/Food Processor
The Instruction Booklet for your Cuisinart BFP-703 SmartPower Work Top Blender can be found here:
http://www.cuisinart.ca/pdf/ibs/en/BFP-703CHC_en.pdf
Thank you for using FixYa!
Jul 30, 2011 | Cuisinart BFP-703 SmartPower Work Top...
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
Cuisinart Smartpower Duet model BFP-703. I cannot locate the fuse. I am assuming it is on or near the motor somewhere but I cannot remove the motor from the housing. The shaft goes through the top and the...
Jan 05, 2011 | Blenders
I have the red Cuisinart BFP-703 SmartPower Duet Blender/Food processor. I turn it on and press and of the buttons and it does come on. What should I do?
Mar 14, 2010 | Cuisinart Blenders
Burnt out motor?
The motor most likely burnt out. Happened to mine to.
Jul 02, 2009 | Cuisinart BFP-703 SmartPower Work Top...
Apr 15, 2009 | Cuisinart BFP-703CH Chrome Blender
Clutch on the jar of my cbt500 cuisinart blender is broken.
The clutch assembly is for the teeth on the base itself. If your problem is with the teeth that are connected to the bottom of the blade that sits in the jar, you want to order a blade assembly instead.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 21, 2009 | Cuisinart Blenders
Blenders Logo
756 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
