Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
How can I reprogram an old style 61LM to a garage door with a learn button? Thanks!
    Scholar:
  • 143 Answers
This Liftmaster 61LM remote is the equivalent remote t? the Sears Craftsman 139 model number listed above. It h?? dip switches inside the battery compartment that ??? match up w?th ???r existing remote t? m?k? ?t open ???r garage door. There is also a set ?f dip switches ?n the overhead opener itself ?f ??? n? longer h??? a working remote. It ?h???? b? easy t? find ?n the garage door opener. This remote operates ?n a 390 MHZ Frequency, and works ?n models fr?m 1984-1992 essentially.
There will be a colored learn button on the motor head. Press and release this button and then press the button on the remote. That is it. Thanks BB Sorry about the lousy question marks in the last post
Posted on Sep 16, 2010
About a remote for a garage door opener, how to program it.Bought a new remote and programmed it and now the old one don't work. How do you reprogram the old one?
The same way you programed the second one.
DO NOT hold the learn button down, just press it once and release it. Then press the button on the garage door remote and it will program to the garage door opener. Do the same for anything else you want to program to the garage door opener. When you hold the learn button down it erases all of the learned codes and you have to start over.
Feb 19, 2015 | Building Materials
Liftmaster Garage Door Opener won't clear codes
This was a first generation learn button model. Antiquated by current technology standards. It was a two channel system. One channel for a dip switch remote, the second for a 66LM key pad. No way to erase the programming, however, by programming in a dip switch remote (61LM with the dip switches set to new positions, and a 66lm set to a new entry code) will purge the two channels of their previous memory, now set to the the new settings.
Jun 06, 2012 | Home Security
I have a clicker model KLIK2U and forgot the code. How do I reprogram without the old code?
It's really easy to reprogram your unit:
Step 1. Hold down the (*) and the (#) keys until the keypad stops flashing.
Step 2. Determine your opener ID using the list below:
*1= linear garage door openers manufactured from 1997 to
present.
*2= Chamberlin, Sears, Craftsman, LiftMaster, Master
Mechanic and Do it garage door openers manufactured from
1997 to 2004 ( Orange learn Button)
*3= Same as *2 above, but manufactured from 2005 to present
with a (Purple learn Button)
*4= Same as *2 above, but manufactured from 1993 to 1996
with a (Green learn Button)
*5= Genie Intellicode and Overhead Door garage door openers
manufactured from 2005 to present (315 MHz).
*6= Same as *5 above but manufactured from 1995 to present
(390 MHz).
*7= Stanley garage door openers manufactured in 1998 to
present.
*9= Wayne Dalton garage door openers manufactured
in 1999 to present.
Openers with learn Buttons
Programming: Enter the PIN that you want to use, remember
(4) digits only. then press #
Enter ID # from list above, for example 2 then #
Press and release the Learn button on your
garage door opener.
Enter your (4) digit PIN and press (0),
for Genie and Overhead door units press
(0) twice. To test and use wait for light to go out
on keypad, Enter you PIN and press (0).
Note: If opener doesn't function repeat programming.
Instructions if required.
Sep 17, 2010 | Universal Garage Wireless Keyless Entry...
Th?? Liftmaster 61LM remote ?? th? equivalent remote tο th? Sears Craftsman 139 model number listed above. It h?? dip switches inside th? battery compartment th?t ?ου match up w?th ?ουr existing remote tο m?k? ?t open ?ουr garage door. Th?r? ?? ???ο a set οf dip switches οn th? overhead opener itself ?f ?ου nο longer h?ν? a working remote. It ?hου?? b? easy tο find οn th? garage door opener. Th?? remote operates οn a 390 MHZ Frequency, ?n? works οn models frοm 1984-1992 essentially.
Mar 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Need to reprogram a single button remote for my Chamberlain garage door opener
Locate the smart/learn button on the rear of the motor unit. Now hold the button down on the remote while you press and immediately release the smart/learn button. Should do it.
Oct 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Have a Craftsman Garage door opener (SRT series, red button) and a wireless keypad outside the door. Just moved in the house and past owner didn't leave the code. How can I reprogram a new one?
On the rear of the motor unit near where all those white wires go you will find the smart/learn button. Press and immediately release this and then walk over to your keypad and key in any 4 digit code and press enter.
Oct 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
New code entry does NOT override old code on Craftsman 315 keypad
yes. Press the learn button for 8 seconds to clear the remote memory. Reprogram all remotes and keypad
Feb 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Mar 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
160 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
