Question about Polar S120 Wrist Watch
Need to buy a strap for polar s120 - Polar S120 Wrist Watch
Took apart a polar s150 watch to change the battery. I went too far and 2 little springs fell out and a small black rubber donut. I don't know how/where to put these back. The two springs appear to...
Hello Clintsanders,
I am sorry to inform you but there is no way that you can repair the unit yourself, you will need to return the unit to Polar to be repaired. Here is a LINK to Polar and all of there service centers and the numbers and procedure that you need to follow in order to return your unit for repair.
Sorry but this is not a DIY item.
Thank you for choosing FixYa.com
Justinbur167
May 16, 2011 | Polar S150 Heart Rate Monitor Wrist Watch
Where can I find a new watch strap for my Polar AXN 500
You can get these directly from Polar. www.polarusa.com or www.polar.fi
Apr 05, 2011 | Polar AXN 500 Watch
I have numbers on the screen (and a new battery), but when I press the red button nothing happens
Really the only thing to do is send into a Polar Authorized Service Center. If you did this for your battery replacement then you have a warranty and the service is free. If you used a regular watch place or did it yourself (never recommended) then something could have been damaged inside.
Mar 26, 2011 | Polar S120 Wrist Watch
Can you change the battery in the chest strap for polar f6
There are two types of straps for Polar:
1) hard rubber/ solid - These can not have the battery changed.
2) soft strap with connector in middle - these you can change the battery.
If you have the soft strap, it will have a small hard around 3 inch long block that "snaps" onto the strap to connect it. These have a battery compartment. Turn it around and you will see the outline for the battery compartment. These are not always easy to open, and the batteries are a little harder to find. Take it into any watch repair and they should be able to pop a new battery in for you pretty easy.
There is a link on my tips and tricks page to get manuals for Polar products, the T-31 wearlink is the product we are talking about, it has the how to change the battery and battery type.
Jan 12, 2011 | Polar F6 Wrist Watch
Reset button has no impact on S120 - no functions available other than time of day
The S120 is now a fairly old watch. When the function buttons and heart rate cease to function this is generally an indicator that the battery needs to be replaced. The buttons themselves can also become worn out or weak of function, in either case you have a couple of options.
1) send in to a Polar Authorized Service center: This is very important, do not take to a normal watch shop. You need the watch properly resealed and handled correctly as well as you may need parts such as a button return spring they will not have. Plus there is a 90day warranty on Polar's repair. You will also need to send in your chest strap just to make sure that is still functioning properly. Battery repair about $15-, new buttons another $10ish, and a chest strap if needs replacing about $25 or $30-. $50-$60 total if everything needs work, but this is just an estimate.
2) buy a new watch unit. The RS100 (the current replacement) is about $100- and is easier to use with a better chest strap.
Dec 28, 2010 | Polar S120 Wrist Watch
I have no speed or trip distance showing, cadence is normally ok. also my watch strap has broken and because it is glued on i cant get it fixed!
Since your Cadence is working then there is a problem with the actual speed/ distance sensor. First make sure that in your settings you have speed turned on. If so then...
1) Your battery may be dead = Replace CS sensor
2) The distance of the sensor and magnet is not set correctly = make sure magnet on spokes and sensor are within 1-2mm of each other.
Polar can fix the strap, you need to send into an authorized service center. They replace the entire strap unit. If you send into Polar to get the strap fixed, then you can send in the sensor unit as well for diagnosis if you want. But if #2 doesn't fix, then it's #1 and they will just tell you to buy a new one anyway.
Nov 29, 2010 | Polar CS300 Cycling Computer and Heart...
How to replace battery in polar f4 watch
HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
Nov 25, 2009 | Polar F4 Heart Rate Monitor Watch
New battery needed and fitted to a Polar heart rate monitor
This is really easy to do yourself. Get a CR1632 battery, unscrew the four screws on the back (dont tip the watch as there is a small spring in the watch), unclip the metal band holding in the old battery noting the way 'round the battery is in (minus side up), pop in new battery and push clip back down, when re-fitting the back make sure the spring mentioned earlier lines up with the white sticker with a hole in it on the inside of the watch back, screw down the back. After you have re done all your settings you may need to re-aquaint the watch with the strap, to do this put on the watch and strap, set the heart monitoring going, bring the watch up close to the 'Polar' logo on the chest strap until the time is displayed, should now be all set up.
Andy
Oct 28, 2009 | Polar F4 Heart Rate Monitor Watch
Polar CE0537
you need CR2032 lithium batteries. They can be found on amazon (pretty cheap). here Finally charging for our multi device world
click on the link and chose some (by price or vendor...) I hope this was helpful. cheers
Aug 20, 2009 | Polar A5 Wrist Watch
My watch band is ripted
I don't know this watch in particular, but I know there are two main types of bands. Coded and non-coded. The S120 uses non-coded. That means you can use possibly any band on the market. Bands I know are compatible: Sigma and Ciclosport. The Polar bands are sealed, so you can use them while swimming. That's not true of the other two I mentioned - but the upside is you can replace the battery yourself once it wears down. You can probably get a replacement band from Polar directly, or buy a cheap knockoff elsewhere.
Jun 05, 2009 | Polar S120 Wrist Watch
Polar S120 Wrist Watch Logo
411 people viewed this question
Top Polar Watches Experts
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
