Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Slow write speed
Thanks for your interest, yes it has been used as storage device, also as master but to no avail
    Genius:
  • 3,587 Answers
Well...hmmm..so what's the issue again with this ext drive?
Posted on Mar 30, 2008
SOURCE:
How to master reset zte z798bl
Hi @Kyle Glenn
Please follow the steps below:
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. From any Home screen, tap Apps > Settings > Backup & reset > Factory data reset > Reset phone.
  2. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  3. Tap Erase everything.
Master reset with hardware keys
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card. If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  3. Press the Volume down button to highlight wipe data/factory reset.
  4. Press the Power button to select.
  5. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  6. Press the Power button to select.
  7. Wait as the device resets.
Hope this helps!
Device resets ZTE ZMAX
Nov 01, 2017 | ZTE Cell Phones
My nokia 7210 supernova phohe work is very slow how can i use fast
I think you device is slow because you have exhausted or about to exhaust the available memory space. Increase the amount of memory spaces available (both on the phone and any other external storage device) by deleting or backing up some of your files. And be sure you phone is not affected with any virus because that can also affect it.
Mar 09, 2012 | Computers & Internet
Help! XP stopped recognizing my external hard drive. It has worked fine for two years and then suddenly: My Laptop no longer "dings" when I plug in the external hard drive. There are no unknown...
No question is silly dear, problems are there and we are in this site to help.
Yes, you mentioned that the said device works fine with your desktop, then it is probably not the problem with your device. You have also said that your tried formatting the os. Good.
Hope your pc, laptop and the memory device are disinfected with a good, licensed and updated antivirus.
Check, if Universal Serial Bus Controllers (corresponding to the nos. of total usb port present in the machine) are present and enabled both in the device manager and the bios as well and set to Hi-Speed if it is Full-Speed.
Well, have you tried formatting the memory stick/device? Format it and see if it works.
Next, please change the usb connectivity cable using/attached to the device and see.
Another thing while connecting an external storage device like ext-hdd. The external usb storage devices that gets connected with a usb cable, in some rare cases needs to be connected as a usb-master or usb-slave [you can see many external usb drives comes with a splitted or dual usb port connector cable, this is either for connecting two usb device or to connect as master when used as a single drive], therefore use such cable to connect and use alternated ports, and see which works.
Now, if all above fails, it then might be the problem with your external drive, i guess.
Best to seek help of your system admin/vendor.
Oct 16, 2011 | Microsoft Windows XP Professional
My garmin nuva 1300 takes a really long time to load points of interest that i search for. For example, I typed in "Ocean City" to determine how to get to the beach, but it took a good ten...
I have a Garmin Dezl - which gets slower with less available memory. I can simulate slow behavior by planning a very long route - reducing available memory to the extreme. Unfortunately the Nuvi & Dezl (based on the Nuvi) doesn't have a function to clear up memory space.
In my situation I had to master reset the Garmin to get memory back. This clears all user data (including all POI's, favourites) and restores the factory state. A master reset works by holding the right bottom corner of the screen while pressing the power on button once.
Jul 08, 2011 | Garmin nuvi 1300 Car GPS Receiver
I have a 2004 Pontiac GrandPrix. When coming to a slow stop, abs starts pulsating. Only with slow speed stops, when you are on the brake pedal lightly. No warning lights on, and I pulled the front...
Its the ABS Computer, it is getting to be a common problem now, I have had that happen to me and I almost hit a car. I would unplug the abs until you can get it fixed, the plug is in the box that the brake lines run to from the master cylinder. The ABS light will be on but its better than rear ending someone.
Jun 12, 2011 | 2004 Pontiac Grand Prix
HOW TO CHANGE CODE ON A MASTER LOCK 5400D THANKS.
Can't unless it is a lock that allows this. You don't say it is such a lock so I tell you you cant.
If it is a lock with the ability to have the combo changed, do you have the key?
Thanks for your interest in FixYa.com
Jan 22, 2010 | Master Lock 5400d: Portable Select Access...
Can i install 2 harddisk drive in one computer, how, does it have any effect in my pc, i have two low capacity disk, and i want to have bigger space, thanks
yes you may be able to,but it depends on some things and how you want to add them.
if you want to have them as an internal device ,ie in the case and always available with your operating sytem, then you need to know what conection they require to be plugged in. some examples are sata,ide,scuzzi.most latest hard drives are sata ,the most popular are ide though.im guessing you most likely have ide hd's.
good thing with them is you can connect two harddrives on the same ide cable.you have to set 1 up as master the other as slave.this is done by adjusting the jumpers on the physical hard disk.the jumpers are located on the bottom corner of the hd next to the power and ide interface.their willl also be a diagram to show how to set master/slave on the hd in most cases.
benefits are more storage and speed but in the above case because you use the same cable for both disks.
if you dont know alot and are not confident in installing them personally and just require more space,i iwould suggest buying a cheap kit $20 ,and using your spare \hd as an external usb disk.
if ive assumed wrong or you need more help ,let me know
good luck and let us know how it pans out
May 22, 2009 | Compaq Evo D510 Ultra-Slim (470043-542) PC...
NHDE35 Enclosure
Posted by Decoder1 on Feb 25, 2009 I also had a problem with XP not recognizing the hard drive. The USB Mass Storage Device was reporting a Code 10 (Device cannot start). Ryockey provided the solution in that the drive pins can be offset by one set when connected to the interface. Be careful to get the pins aligned correctly, it worked for me. I also have my drive jumper set for Master. Thanks Robert!
Randy P.S. I am using a Seagate 250 GB HD 7200.7 Ultra ATA
Feb 12, 2009 | NexxTech Portable Hi-Speed USB 2.0 Kit...
I purchased a western digital 160G external storage device. My computers tell me that it will be slow without a high speed USB port. However, I get a prompt to install software or to insert a disk into...
use windows xp service pack 2 professional
all the ports are then usb 2 .
if this doe not solve the problem change the circuitry of the ext drive on which you mount the hdd
Jul 09, 2008 | Western Digital Passport WDXML800UE...
Dvd writer problem
taking too many time to burn a dvd movies and all others dvd disc.
Mar 24, 2008 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
35 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
