Question about Hitachi NR83A2 2" To 3 1/4" Full Head Framer with Depth of Drive
Craftsman combination nailer/stapler
It shots many staples at at time and they don't go in at all only the first one goes in, other times it just makes a noise of air going in and nothing happens.
  • 25 Answers
MY POWER SHOT WONT SHOOT THE BRADS A LOT OF TIMES, WILL SHOOT STAPLES EVERY TIME
These tools are designed primarily as staplers, with a gimmick of being able to shoot brads. If you need to do a lot of brad nailing, purchase a brad nailer -- air or electric -- to do the job. In the meantime, try placing one or two drops of thin machine oil (3-in-1 is a common brand) on the impact area of the tool. Sometimes the adhesive used to form brads and staples into strips builds up on the tool surfaces and keeps them from moving freely.
Dec 31, 2017 | Staples Tools & Hardware - Others
Where does the spring go inside a Sear's Craftsman Staple gun & brad nailer?
if the spring popped.. it will pop again
no exploded view for it
@ $20 stapler might be a throw away stapler
you can undo the screws to the housings
keep it as spare parts
Nov 10, 2016 | Tools & Hardware - Others
How do i load the Stanley Bostitch 00540
Hi Diane,
If you look at the back of the stapler, there's a bright red button. Push this in and slightly lift up at the same time, then magazine is withdrawn. Feed a strip of staples in and replace the pusher unit.
Bostitchtools co uk Bostitch Nailers Staplers Fasteners Coil Nails Staples
Jan 29, 2015 | Stanley Bostitch 00540: 00540 AntiJam ?...
What gage staples do I need for a p300 ryobi air stapler?
Good morning Victoria,
The staple series that you'll need is probably need is a 90 series. These are again an 18gauge wire in several different lengths.
Regards
collatedfasteners
Jul 05, 2014 | Ryobi P300 One+ Stapler Brad Nailer
I have a craftsman 18 gauge nailer/stapler the only # I see is 351.184540 when connected yo air supply it only hisses no firing. Took off depth setter on rear of gun inside it appeared to b a diaphragm and...
Model 351184540 CRAFTSMAN COMBINATION NAILER STAPLER Parts
You can price parts and decide if it is worth it, is the gun old, used much etc. If you don't use it much HF sells inexpensive ones. If you use it more often buy a better name brand at HD, Amazon E bay.
I have a combo nailer/stapler and i only use it for staples. The combo will put a bite mark on your wood. I use a nailer that doesn't leave marks so cleanup before finishing is much easier.
Oct 29, 2017 | Air Tools & Compressors
The staples go through the material, but don't fasten or close on the back side
This is not a type of stapler that clinches the legs of the staples. There would have to be a lower jaw to do that. Like a desk top stapler has.
Nov 25, 2012 | Stanley TR250 H Heavy Duty Heavy Duty...
Stanley stapler/nailer gun spits out more than one staple at a time
Sometimes a gun will double fire, quickly fires twice and is caused by worn trigger valve or safety foot. However, two staples driven with one shot indicates that the staples could be the wrong gauge for the gun or the driver is damaged. The driver of a nailer has a taper on one side of the blade to prevent the driver from hitting two staples. The taper will push the remaining staples back into the rails. Make sure that the taper is facing the staples and that the staples are correct for the gun.
Aug 25, 2011 | Stanley Carrying Case Bostitch Brad...
I am using the 1 1/2 staples and going into oak, and can't get the depth wheel to seam to adjust. Leaves the staple sticking up about a 1/8 in.. I have sprayed everthing good with WD-40. Combination...
well oak is a barn hard wood, do you realy need a big staple cant you use a shorter one??? its that or buy a stronger staple gun or a big hammer!
Jan 12, 2010 | Air Tools & Compressors
Crown Stapler stopped shooting staples
Did you look for a staple jammed in the driver mechanism? If the piston is stuck down, it won't respond to the trigger. Try smacking the top of the stapler onto a wooden bench to see if the force will release the piston. Make sure that you use air-tool oil for lubrication inside the tool. Hope this gets you running!
Jan 04, 2010 | Air Tools & Compressors
Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Nov 02, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Hitachi NR83A2 2" To 3 1/4" Full Head Framer with Depth of Drive Logo
78 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
