Question about Microsoft Xbox 360 Console
How to connect xbox to computer with ethernet cable and wireless internet
  • 47 Answers
You can only basiclly cant with only one connection which is either through ethernet or wireless device that you have to buy from any supermarket it s not hard either way to set them up
but with ethernet you need to have the xbox close to the router
wireless connects to your xbox 360 throught the usb then basically scan for your router then put in the routers wep key or wpa psk key
Posted on Jun 09, 2010
Testimonial: "Cheers"
How to connect xbox360 to internet with laptop
Hello bernelltaylo,
This is a very simple procedure, but pay close attention.
First, here are the requirements to attempt this procedure.
_____________________
- An Ethernet Cable,
- Wireless Connected Laptop
- Bridged Connection Eligibility
_______________________
1. Get an Ethernet cable, they are commonly blue, or yellow.
2. Plug one end of the Ethernet cable into the back of your Xbox 360 console, and the other end of your Laptop.
3. Log onto your laptop, (assuming you're using Windows), and find the list of your wireless/wired connections.
4. You'll see something like, "Local Area Connection 2", and "Wireless Network Connection 3". Make sure you're already connected to the Wireless Network before continuing to the next step.
5. Highlight both the connections, and right click one of them. Click on, "Add a Bridge".
6. A process will start which will bridge the connections, enabling your laptop to work as a modem for your Xbox 360. This may take as long as anywhere between seconds, to minutes.
7. When it's done, do NOT remove the Ethernet cable, until your desire to disconnect from the internet on your Xbox 360.
______________________________________________________
Hope this helped, see ya' later. :)
Dec 02, 2012 | Microsoft Xbox 360 Console
Lagging on a xbox 360 with a 320gb hard drive
It is not only the memory to check when your xbox is lagging. You need to check if you are connected wirelessly for it might be interferrences issues. You need to connect via ethernet cable first to isolate wireless issue. Once connected via ethernet cable and still lagging you can check the bandwith issue. Make sure that when connected to your computer/tower, its only the xbox in use. Turn off any computer, laptop, any wireless device that might be using the internet.
Dec 21, 2011 | Microsoft Xbox 360 Console
How do we connect the xbox to the internet
To connect the Xbox to the Internet you can either use a wireless or Ethernet connection. The Ethernet is the most common method and is simpler. Connect a Ethernet cable to the xBox and connect the other end to a modem from you ISP (Internet Service Provider) such as AT&T or Comcast. In the Xbox, configure the Network by setting up the connection - follow the Xbox instructions on how to enable the network connection.
Feb 01, 2011 | Microsoft Xbox 360 Console
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
How do i connect xbox live to my lap top
you need a laptop or pc with wireless built inand an ethernet cable, right click your wireless adapter icon then click properties,click on the advanced tab and make sure 'allow all other network users to connect through this computers internet connection is ticked, plug in your xbox to your pc with ethernet cable and turn it on, then click on library in media player11 and go to media sharing,tick the share my media box and your xbox should appear there.
Hope this helps.
Jan 07, 2010 | Microsoft Xbox 360 Console
I have a wireless router hooked to my computer & my son recently got a wireless-G USB adapter so that he can play his xbox 360 online. Will this work, or will we have to put the router on the xbox...
XBOX 360 will only work properly with a 'genuine' USB WIFI adapter designed specifically for it (and at an over inflated price IMO!).
One popular way to play 'network' via the internet is to connect the XBOX 360 to your PC via Ethernet cable and have the PC connecting to the internet either via another ethernet connection or more likely via a Wifi connection which could be via your USB adapter connected to your PC and talking to your Wifi Router)
Dec 26, 2009 | Computers & Internet
How to hook your xbox360 to laptop to get on xbox live
wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
Oct 25, 2009 | Microsoft Xbox 360 Console
How do you hook up xbox 360 to cricket a600 broadban
Yes, but if you want to connect the X-box and computer directly you may need to get a crossover cable. Sorry, I can't say for sure on this as it depends on the network card in the PC.
You should have a box in the configuration dialog for the Cricket saying something like "Allow other network users to connect through this computers internet connection". Be sure this box is checked.
Aug 28, 2009 | Westell Wirespeed LiteLine 6110 Modem
Cannot connect belkin wireless adapter to my xbox 360 thru my pc
every computer has an ip adress you might have to go to your internet setting and find some thing that says some thing like... internet adress hook up hopefully you keep files on your computer becuase with out your ip adress you might not be able to hook up its sorta like a combination hope it helpes:)
Mar 02, 2009 | Belkin Video Game Consoles & Games
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
