Question about LG WM1812C Front Load Washer
Water will not drain, drain line is straight. could the pump be faulty, how do I drain the water
  • 1,557 Answers
Detach the main flow hose leading from the drum whaen you find the pump see if it turns freely if not replace if so it may still be burnt out have a look at some of my past post about block etc
good luck
Posted on May 15, 2010
My swan sw2061b won't empty water, pump doesn't seem to be clogged as water runs straight out,
How does water run straight out? I guess You mean if you lower the hose below the drum height? If this is the case then it's most likely the drain pump either has something stopping the impellor turning, the pump itself faulty or the relay on the pcb faulty
Jan 15, 2018 | Washing Machines
Why does my washer only drain when the hose is at ground level? It also seems to be filling with more water than usual - almost overflowing for a small load of laundry.
the water pump on a washing machine is nothing more that a water stirrer as the vanes are straight out
the pump is full all the time and passes water if the hose is laid on the floor. the fact that it is not pumping indicates that it is not getting power at the right time. or the motor of the pump has malfunctioned O new pump) The over flowing machine indicates that the hose to the pressure switch ( what you turn for the water amount ) is blocked or has a hole in it
With both problems combined it may be a faulty control board so have a washer machine mechanic have a look at it.
May 10, 2015 | Haier HLP23E Top Load Washer
There is water leaking out from the bottom of my furnace. It leaks whenever the ac is running.
Hello, sounds like a clogged condensate line or a faulty condensate pump if the unit has one. Cleaning the drain line should fix the problem.
Jul 12, 2011 | Heating & Cooling
The water starts to go in but drains straight away.
If the drain hose is too low and below water level the water has no reason to stay in the machine, and will flow straight through. If the water is pumping out during fill, you have a technical problem....Good luck....Nomess
May 20, 2010 | Washing Machines
Kenmore washer fills during spin cycle and doesn't drain completely
HI, this is just a slight clog or faulty drain pump. check the following areas.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 18, 2009 | Kenmore Washing Machines
Washer won't spin out the water
This is a drainage issue. the spin cycle works in conjunction with the draining pump. they both work at the same time during the spin. if the drainage hoses or pump are clogged with debris, it will prevent the water from being drained properly.
Check the following to address the faulty drainage issue.
2. Water Pump
May 31, 2009 | Maytag Washing Machines
Pump constantly emptying
make sure that the drain line is higher than the water level in the tub. If it isn't the water will just drain
Mar 30, 2009 | Washing Machines
Drum not filling up with water, it's draining straight out.
That means that the drain pump is always on.
That can happen because of a faulty or stuck water level switch (the one with floating sensor), because of a faulty drain pump solenoid, or because of a faulty pump.
Oct 24, 2008 | Washing Machines
Hotpoint wf860
not sure about the f04 code but if its still full of water try putting the washer onto a drain cycle if the water does not drain then your pump is either blocked or faulty to check if its faulty pull the washer outnow take the drain hose and place into a bucket low to the floor if it comes straight out then the pump is faulty what it is is they have a magnectic part which goes down if the water doesnt come out its blocked you will have to take the washer outside tip it backwards but dont put it on its back now undue the sump hose which is situated in the centre of the drum pull it the water will drain out now undue the 2screws under the pump pull out undue the pipes you should see the blockedge if not could be in the drain hose itself m8 let me know how you go on if the pump needs replacing shouldnt cost no more than £20
Nov 16, 2007 | Hotpoint Ultima WF860 Front Load Washer
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
LG WM1812C Front Load Washer Logo
107 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
