Question about B&W Bowers and Wilkins Zeppelin iPod Music Speaker System
I get a humming sound when the ipod is attached,
Definitely not ipod fault as i have tried three separate ipods and sme humming sound happens
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
The humming sound maybe coming from the 60hz frequency of adaptor attached to your other device. Try connecting ipod to a device that uses battery and see if it has the hummming sound, if no humming present its confirmed that it is coming from your power supply.
Posted on Mar 12, 2015
    Scholar:
  • 159 Answers
The hum comes from three possible sources, the power unit can cause it before failure, the amplifier which can effect one or more speakers or the interface board between the other two, the interface board and the power board are known problems to b and w, so if you have not already contacted service at b and w, then do so.
Posted on Jan 16, 2011
Ipod and External Hard Drive No longer recognized by PC
Depending on your iPod, may have to go see if there is a driver on-line to download and reinstall on your computer. Short of that, you may want to try a DEFRAG, or else try and go back to a RESTORE past RESTORE point and see what happens. Even try Virus Scan and Ad-Aware scan for Bugs that may have infected the file that reads your iPod. Try to think of any software updates you may have made shortly to the iPod not be identified...
Aug 28, 2009 | IO Magic Corporation GigaBank (I250HD35)...
IPod not detected at all
aLL YOU have to do is reset it, look on youtube it'll tell you there.
Aug 19, 2009 | Apple iPod shuffle MP3 Player
Ipod Classic 120GB video problem
where did you get the vids from. it sounds like the codec used for the vid is not ipod compatable. you may be able to convert them using free software like anyvideo converter or ipod robot. i tunes can play them because it has a greater library of video codecs (anything installed on the system... almost)
Aug 14, 2009 | Apple iPod MA446LL/A MP3 Player
Bad sound with static on left channel
First I would attempt to reset the iPod. If that fails you should restore using iTunes. And last but not least, if that fails you will need to replace the headphone port. Below is a step by step on all three trouble shooting options. Let me know if there is any issue at all in resolving this situation :) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. ---------------------------------------------------------------- How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
With the casing separated, grasp the top half (the part with the front bezel) and flip it over. Note that there is an orange cable in the top left corner that connects the iPodlogic board to the headphone ports. If you gently grasp the cable and pull, it will slide out of its connector on the headphone port module board.
May 19, 2009 | Apple iPod nano
5th generation iPods hose up while using Altec Lansing IM600
Yes, the docking station is damaging the iPod. The vibration when used load is causing damage to the iPod. If you notice, the iPod will only freeze when it is playing load in the docking station. To avoid the problem, you'll need to play the music at a lower sound with less vibration. Once I began to play my music at more reasonable sound levels, I discontinued the problem. Very disappointing solution...but it is the answer. I too called Altec Lansing. They are not aware of this issue...I told them to search the internet - it's all out there.
Mar 21, 2009 | Altec Lansing Inmotion-IM600...
Radio just hums.
Im having the same problem!!! Trying to figure out if my 6 year old cut the little cord that is attached, inside, next to the line in hole.
Jan 29, 2009 | Dual Electronics ihome iH9BR iH9 Alarm...
Itunes dont regocnise my ipod,so i cant update or add any tracks
Most of the time, your iPod won't come up because of a slightly dodgy hard drive. There's a couple of ways to solve this. The first one would be to get another iPod of the same model from a trusting friend or something, take the back off and swop the hard drives. Then plug the other iPod in. It will want to restore. Go through the restore and then swop it back. It should ask to restore now in your iPod. The second one is to buy a zif 1.8" usb hard drive caddy from ebay (should be under £10). Open it and attach your hard drive, wait for it to be recognized by your PC, then right click on it and format it as FAT32. Put it back in your iPod and it should want to restore. Or, buy a new hard drive.
Nov 22, 2008 | Apple iPod classic MP3 Player
Not being recogonized
try another computer. If it doesn't work on another computer then send the ipod to repairs.
If it works on another computer come back and tell me.
May 21, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod freezes up computer when hooked up
uninstall itunes and the ipod software then reload everything it and if u have more then one usb slot make sure u put it back in the one u use to load it with because sometimes the computer is very picky with that. its worked for me when mine does that so maybe it will work for u
Nov 10, 2007 | Apple iPod MA446LL/A MP3 Player
B&W Bowers and Wilkins Zeppelin iPod Music Speaker System  Logo
231 people viewed this question
Top B&W Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Are you a B&W Audio Player and Recorder Expert? Answer questions, earn points and help others
