Question about E-Machines eMachines Desktop PC
How do i get a new ip address my laptop has suddenly stopped connecting to the internet and i dont seem to have an ip address
    Sniper:
  • 126 Answers
You can easily get your IP-address details easily with the help of http://www.ip-details.com/ because i have also used to it for locating my Ip-address.
Posted on Aug 16, 2010
  • 37 Answers
Every laptop or PC must have an ip address to connect the internet, if u want know more details then please give full details of the problem
Posted on May 15, 2010
2 Suggested Answers
  • 95 Answers
SOURCE: My internet connection Internet
Hi
There is no need to assign ip address for you computer to enter into internet you system will be getting the ip through DHCP.so remove the ip address and check the internet connection.Check wether the telephone line is ok .check wether there is dailtone in your telephone line and check the username and password is correct.
Jyothish
Posted on Jul 19, 2008
Wifi connection problem
plz try to configure ur manual ip addressing on ur laptop .Hope u will access internet soon ....>>>>becuz its prb with ip address
May 12, 2010 | NetGear DG834G Router
Can not connect to internet
Go to control panel and then systems and then hardware and then click on the device manager. Listed under network adapters check to see if it is working properly. If it is not enable, enable it. go back to your control panel and then double click on network connections.
on the device right click to go to properties>>now in a new window
Click on tcp/ip and click on properties make sure that ip address and DNS server address automatically and you should be connected to the internet.
If you dont have ip address that might be required you may contact the service provider or
ISP(internet service provider)
Fixya is glad to help you!!!!
May 12, 2009 | Acer Aspire 5610-4648 Notebook
We have a main pc attached to our broadband via ethernet and 1 other laptop which is also attached to the the internet but wirelss, my son has purchased an acer aspire 7730/7330 series laptop , how do we...
I think you need to specify the gateway address in your new laptop. For that you have to know the gateway address ( i,e. the IP address of your boardband router/ adsl modem.).
First, go to your old laptop, right click on My Network Places, Right click on the wireless lan connection and select properties. Click on Internet Protocol(TCP/IP) and click properties.
Take a note of the Default gateway.
Now come to your new laptop, use the procedure mentioned above to open the Internet Protocol(TCP/IP) Properties box. Type in the Default gateway address which you have noted earlier. Click ok twice. Now see if you can access the internet. If you can't then let me know the IP address configuration of both your old and new laptops.
Nov 26, 2008 | Acer Computers & Internet
Suddenly router stopped working!
Hi jsamanta!
First of all check if the power light is blinking or solid. if it's blinking reset your router.
When your computer is directly connected to the router try checking the IP address by clicking start>run> type cmd then ok. then type ipconfig then hit enter. IP address should be something like 192.168.1.100. not 169.254.xx.xx. if it's the latter reset your router. use a ball point pen or a paper clip. the reset button is a small hole at the back. If the IP address is like the first one i've mentioned. log-in to your router.
launch browser (internet explorer or firefox)
type http://192.168.1.1 or whatever your default gateway is. go to the status tab and check if you are getting a WAN or internet IP address. if not you will see a "release" and "renew" button. hit release then renew. if you're still not getting anything. do a power cycle. turn everything off. connect everything the way they are supposed to be connected. turn on modem first then router then computer.
If everything fails the last options is a firmware update on the router.
Hope this helps. =)
Oct 11, 2008 | Linksys Wireless-G Broadband Router
Router Connectivity
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Aug 08, 2008 | Computers & Internet
RG54SE II
In your wireless router,U want to configure the ip adress of internet,may R u static ip R dynamic ip address,
1. Statis ip customer means, configure the static ip address in your wireless router,
2. Dynamic ip customer means, configure the ip address of the ADSl modem ip.
May 20, 2008 | MSI Wireless-G RG54G3 Router
Network Connection
First off, the 1394 connection is a firewire connetion. Firewire is a less popular and slower alternative to USB 2.0 connections. Disregard that in respect to your internet connection. Now in regards to your desktop internet connection.... -Go to the control panel, select network connections, then local area connection. -Right click and select properties -Under the general tab scroll down to Internet protocal (tcp/ip) Make sure the settings are set to automatically obtain an IP address. If they are and still are not working you can try to manually assign an IP address yourself. The laptops ip address might be something like 192.168.1.2 so whatever your laptop ip address is make the desktop 1 number higher in the last field (192.168.1.3 for example). Don't change any numbers other than the last field. You can find out the other information like subnet mask and default gateway by using the laptop. On the laptop go to the start menu, hit run. Then type in cmd, this will bring up a dos prompt. Then finally type IPCONFIG . Listed will be the laptops active internet connections and it's IP addresses. Copy over the subnet mask IP address and the default gateway address into the desktop and like in the previous step just manually assign the desktop a different IP address 1 number higher than the laptop. If the dns server's address isn't listed on the laptop a quick call to your dsl provider will solve that question.
Sep 29, 2007 | Compaq Presario 5000 PC Desktop
My router doesnt seem to be Broadcasting the wireless connecition!
it may be that the router is not assigning ip addreses properly, and is duplicating the ip address on all pc's. or you have done the windows diagnose and repair or detect problems. Go to the properties of each wireless card in control panel>network connections and on the TCP/IP line click propertes again and ensure obtain ip address automatically is checked. Also go into the routers settings and ensure DHCP is enabled to give all pc's an automatic ip address. Restart all pc's and your router (not Reset) and you should get renewed ip addresses and be able to connect.
Sep 13, 2007 | SMC Barricade g SMC2804WBRP-G Wireless...
Wireless modem not connecting to everything on the network
this sounds as if either the router is not set at enable DHCP which gives your pc's and x box an automatic assigned ip address, so check in the routers settings via your web browser that DHCP is enabled, also go to your wireless network card and go to the properties, select the TCP/IP line, click properties again and make sure automatically obtain ip address is ticked, ok and close window. Do the same with the Xbox in the network settings and make sure that automatically obtain ip address is highlighted and automatic DNS is set. Lastly make sure non of the pc's network setup is set in a way that other pc's connect to the internet through this computer type set up, they should all be set up using the network wizard using the 'this computer connects to the internet through a gateway' setup, which is your router, but if your laptop is Vista, then everything should have set up automatically when a connection to your router was found. Lokk in the routers DHCP clients and look to see if all your pc's and the Xbox is listed and given IP addresses.
Jun 26, 2007 | Belkin (F5D9230-4) Wireless Router...
E-Machines eMachines Desktop PC Logo
98 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
