Question about Microsoft Xbox 360 Console
Xbox 360 i tried everything with the cables the switches and even on different tvs but all i got is perfect sound but instead of seeing the game i am playing i see little white lines or little white dots some one any one HELP ME MY LITTLE SISTERS BIRTHDAY IS COMING UP AND SHE LOVE PLAYING ROCK BAND WITH HERE FRIENDS HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Ok, try going through all the different video cables till one works, same as the ps3 you have to go into the setting and tell the 360 what type of video setting you want to use, once you find the one that is active then you can go into the setting and change it around - if you have already tried this then the video processor is fried and you need a tek to fix,
keep me posted
Posted on Mar 30, 2008
When i plug my xbox 360 hard drive in it makes the screen go blank?
If the A/V cable is not inserted far enough into the console, the console might not transmit images or sounds to the screen.
If the screen is still blank, try the next solution.
or
Make sure that the TV or monitor is set to the correct input for the console. Check the TV or monitor user manual to see how to configure the video inputs, or try to use the console on a different TV or monitor.
or
Make sure that the TV/HDTV switch on the cable is set correctly.
  • For standard-definition TVs with only the yellow connector plugged in, set the switch to TV.
  • For high-definition TVs or monitors with the red, blue, and green connectors plugged in, set the switch toHDTV.
Dec 29, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
My xbox 360 does not show a picture but has sounds. can It be fixed? If so Where I live In Tacoma Wa.
try using a different tv or av cables. sometimes the plugs on tvs can become loose and that is why you will hear sound but not see a picture.
Nov 28, 2010 | Microsoft Xbox 360 Console
My son wants to play against his sister but can't find anywhere that lets her enter the game?
Both have to have xbox 360. Both have to have the ethernet cable attached to each other. (This is called a system link)
  1. Make sure you have the necessary supplies needed for System Linking (all supplies list at the bottom).
    System Link cable or an Ethernet Hub.
  2. Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9503394424+9665908481+9016233241+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
  3. 2Make sure that all of the Xboxes that will be used are hooked up to different TVs.
    1. 3
    2. To connect two Xboxes, use a System Link Cable and insert one end of the cable into the Ethernet adapter of one of the Xbox consoles and the other end into the other console's Ethernet adapter.
    3. If you are using two Xbox 360s, you can use a standard RJ-45 Ethernet cable instead of the System Link cable.
    1. 4Connect them each into an Ethernet Hub or Switch. A router will also work.
    2. 5Turn each console on and load a copy of the game into each console.
    Oct 27, 2010 | Microsoft Xbox 360 Console
    Xbox 360 not sending audio/video signal. Tested on 3 different TVs with both the AV cables and the HDMI cable, no red rings, everything seems to work, just no video or sound.
    If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
    Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
    It has a preview video on the website.
    Or of course you can send it in to have it fixed.
    Jan 26, 2010 | Microsoft Xbox 360 Console
    I can hear the audio but I can't get a picture
    Some x-box 360 cables have a switch on the end that inserts into the 360 console. It switches to HD TV if you have one. If it is switched to the wrong TV type you will get no picture.
    Try a different cable or HDMI cable if the 360 had HDMI.
    If none of the above work its probably 360 mainboard. Easiest fix would be to replace it or exchange if it has warranty. Good Luck
    Nov 23, 2009 | Microsoft Xbox 360 Console
    My Xbox 360 has no picture but it has sound I`ve tried on different tvs and different AV cables but all the same. I also made sure the cables were firmly in the ports and that the HD and TV switch was...
    try this take the game out off your console turn it off turn it back on with the guide button on the joypad hold the right trigger and y this will reset the display settings on your console if this does not work try www.xbox.com/support/contact
    Jun 17, 2009 | Microsoft Xbox 360 Console
    My Xbox 360 has sound but no Picture
    This happened to my first 360, and in my case, it was a hardware failure. You can call Microsoft and hope your warranty is still good, and they'll fix it free of charge, but if its not, then you have to pay a fee.
    Mar 26, 2009 | Microsoft Xbox 360 Console
    Plays dvds on xbox 360 fine, but no picture for games/dashboard
    already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
    Jan 02, 2009 | Sharp Televison & Video
    XBOX 360 COLOR KEEPS GOING ON AND OFF
    You can send your broken xbox 360 to my shop Fixit repair service and I can send you a refurbished xbox 360 system for $80 and one year warranty here is the number 206-271-0529
    Nov 07, 2008 | Microsoft Xbox 360 Console
    Sound with no picture
    Have you looked at the side of the cable and made sure that the switch is set correctly? you have to select either HDTV of AV I believe. If that isn't the problem, try hooking it up through a different input on your television. I don't think it's your xbox because with any hardware failure, you would get the RRoD (red ring of death). I would definitely troubleshoot the TV. Try to hook up a regular DVD player in the input that your xbox is in and see if it works.
    Jan 29, 2008 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    Top Microsoft Video Game Consoles & Games Experts
    Tre Elkins
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
