Clicking sound when trying to switch on - Televison & Video
  • 1,557 Answers
It has a fault in the mains line relay its clicking on then finding a fault and clicking of to protect the unit from further damage get it looked at by a pro should cost around $ 130 to fix
Posted on May 15, 2010
Michael Pryor I got a dryer model number.WED7500VW, is not turning on door switch onewire Was burn....
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the "click." If the door switch makes a clicking sound, it is probably not defective. If you don't hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
Aug 30, 2016 | Dryers
Why is brake light inop when using the front brake?
There is a switch built into the hand brake. If you pull your hand brake, and don't hear a click sound, the switch probably needs replaced. Try someone else's hand brake or one on a new bike. If you don't hear a distinct click sound, you need to replace the switch.
Aug 10, 2014 | 1996 kawasaki VN 1500 Vulcan Classic
Key clicks is ON , but NO sound
Is it possible that you also changed the function of the lock switch?
Try going into settings and change the settings of the lock switch to mute/unmute then place the switch itself into the unmute position.
If that brings back the sound of the keys, then it's safe to change the lock settings back to lock rotation.
If that doesn't solve the issue then I would recommend you do a backup and then restore to factory settings using your computer and iTunes.
Hope that helps!
Aug 21, 2012 | Apple iPad 32 GB 3G Tablet PC
Turn key on nothing ,trun key off and on three or four time then it start
Either u got problem in ur ignition switch contactor(it is located aty the end of ur ignition key assembly) or the starter solenoid.
Do u hear any clicking sound when u try to crank ur ignition key? if u hear some clicking sound that means ur starter solenoid got problem.
If u don't hear ny clicking sound, that means ur contactor in the switch is at fault!
better bring ur car to ur nearest garage to fix on that, if u can fix it it by urself try it.
Dec 02, 2010 | 2004 Nissan Quest
Switch clicking on start up wont start lights flash at same time
tried the battery, charge it manually, sounds silly but i had this problem with my 600ss
thanks
Apr 21, 2009 | 1998 Yamaha FZS 600 Fazer
Windows wont go down or up
Check the switches for a clicking sound if you hear a clicking sound then the switches are fine. Does the driver side switch work for the windows? Check it for the click sound. Make sure it isnt a blown fuse. If you have replaced the fuse and you dont hear clicking sound it might be the switches and you can find them at a junk yard. If you have tried all these things and it still doesnt work you might need new window regulators and/or window motors or it might be a wiring problem.
Mar 08, 2009 | 1995 Pontiac Bonneville
My PC does not have sound ,it keep on asking me for sound device,i tried to update but still not working what should i do,i us dell vostro 100 and software is windows XP
Your sound card may have a bad driver. Click on start>right-click on my computer>click properties>click hardware tab then device manager. Look down the list until you see sound card. Click on the "+" to open it. Right click on it an click on update driver. If that does not work, or if you do not see your sound card then it needs to be replaced.
Don't forget to rate this solution with 4 stars before you log out.
Jan 29, 2009 | StarTech.com StarView SV211K 2-port KVM...
Clicking sound from unit occsanially
clicking sound? most receivers resort to this trying to determine what the input source is, and mainly if they are trying to determine if it is a analog or digital input signal, try setting the input source switch to AUTO if available, this way it will recognize the signal and switch to that input mode.
Jan 25, 2009 | Sony STR-DE897 Receiver
Washing machine tub is not spinning and holding water
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch.
If you have a hidden lid switch (no visible hole around the top where the lid closes) try tightening the screws on the lid hinges.
Jun 18, 2008 | Washing Machines
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
