Question about Kenyon 14 in. Kiss B23006 Gas Cooktop
I have a B23006 gas hob where do I get the cannisters from please in the UK?
What type of pipe do i need to by for connecting necht gas hob to my gas
Usually it is a flexible pipe with a gas clip connector on the wall end and a standard thread on the cooker end. In the UK we employ Gas Safe technicians to install gas appliances due to leaks and possible explosions caused by an unsafe installation.
Feb 04, 2017 | Cooktops
USER MANUAL FOR SAMSUNG CERAMIC HOB C61R2AEE
Samsung has the manual you want is the 1.75 MB PDF at the bottom of the list here: http://www.samsung.com/uk/support/model/C61R2AEE/XEU-downloads . If this second link doesn't work, follow the directions below to reach this page.
Samsung has the User's Guide for the oven on the Support tab, see http://www.samsung.com/uk/consumer/home-appliances/cooker-hobs/ceramic/C61R2AEE/XEU . The support tab is on the right. The manual for the cooking hob can be accessed from the Need More Downloads link below the Download button.
I hope this helps.
Jul 06, 2012 | Cooktops
Severely reduced gas supply to hobs while grill
Valve at back of cooker that isolates gas to the hobs when the lid is lowered is sticking. Move lid up and down half a dozen times or oil it to ease it.
Dec 27, 2009 | Cooktops
Gas hob turning bottom of pots black..not sure if the hob is installed properly
if the hob is turning the pots black the cooker needs a good cleaning they have air ports in the burner assembly they could be blocked or the incoming gas preasure to too high and needs to be checked by a gas engineer
Aug 19, 2009 | Cooktops
No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Nov 24, 2008 | Dacor Preference SGM466 Gas Cooktop
Converting gas hob to electric hob
If you are in the USA most codes require a seperate circuit for the oven and the cooktop. Most cooktops require 30 amps and at least #10 wire.
Jun 09, 2008 | Cooktops
Ignis Gas Hob AKL700
no. not in the uk. a fixed appliance must have a rigid pipe connection with a means of disconnecting/isolating. you must not use a flexible pipe.
pete
Jun 02, 2008 | Cooktops
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Open Questions:
Kenyon 14 in. Kiss B23006 Gas Cooktop Logo
50 people viewed this question
Top Kenyon Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kenyon Cooktop Expert? Answer questions, earn points and help others
