Question about Dell Axim X50 Pocket PC
Start screen stuck in align mode. - Dell Axim X50 Pocket PC
    Problem Solver:
  • 16 Answers
I see your problem.Try wiping the corners of your pda gently with a business card. This may help as unresponsive screens occur due to dust trapped under the casing.Remeber to practice this every 3 months.Good Luck :)
Posted on Jun 25, 2010
Hi samsung gio won't start stuck in first samsung screen and can't log to recovery mode it gives ramdump and stuck
ram dump if your press vol up+power+home button, but if you wanna go to download mode you must press vol down+home+power button.
it stuck on first screen called boot loop, solution is reinstall or flash new rom on your phone,
follow this http://www.droidvan.com/2012/06/link2sd-on-stock-rom-s5660dxkt8-236.html if you wanna back to stock rom
or this http://www.droidvan.com/2013/03/cm-9-final-for-galaxy-gio.html if you wanna taste off ICS on your phone
Mar 12, 2013 | Cell Phones
Computer stuck on E screen
Start in safe mode. Restart computer and continue pressing F8 during startup until the safe mode start up screen appears.
May 28, 2012 | Computers & Internet
I am using imate jama101 mobile. the mobile was hanged screen mode aligned screen its not changing from the aligned screen mode i had restarted the mobile but still its not working
HARD RESET
1) Start->Settings->System tab->Master Clear->1234->ok
2)Press soft-reset for 15sec.
3)Remove the battery, Simultaneously hold volume(-) button and red hangup button, while still holding those keys, insert the battery and wait for the led to go out, release keys and device will hard reset
3rd option really worked for me
Jun 26, 2010 | i-mate Jama 101 Smartphone
Unlock screen won't respond to stylus.
First check to see if any of the buttons are stuck. If that doesn't help, try a few simple things with the digitizer, the thing you write on. It could be stuck.If there are any gouges, dents, deep scratches or cracks, that could do it, it's toast - but self repairable if you dare. -However- 2 things to try first just for giggles though if there are no cracks: #1. Use your joystick & enter button to navigate through the Start Menu to Settings>>System>>Screen>> Align Screen and align the screen. Worth a try. #2. There might be some crud stuck between the edge of the digitizer and the edge of the case. That can give you phantom key presses. Take a piece of stiff paper or thin plastic and run it *gently* around under the edge where the case covers the screen to scoop out any stuff that may have settled there. Those blister packs that cut you up when you try to open them works well, credit card is too thick for my taste. #3. If it's been around water, there's a very slight chance that putting it on top of the clothes dryer for a few loads will dry it out.Beyond that, needs technical help.
Mar 09, 2010 | Dell Axim X51v Pocket PC
Palm treo smartphone upon reboot gets stuck on "align screen"
yes u cant exit the screen until u do the align test for the touch screen its a easy fix on the back of the phone on the left side top there is a hidden pen that comes out of the phone and when u get the pen out use the point of the pen to touch the center of the circle on the align screen test it will ask u to do this in every corner of the screen after that the phone should get out of the align screen test and be able to work good luck
May 29, 2009 | Palm Treo 755p Smartphone
Get to Start menu
I have same problem but found a work-around. I have found that 2 SD cards kept in the pockets in the flip over cover of my leather case has caused scuffing to the touch screen and the screen will now not align properly. In the alignmet utility I have to tap the centre of the alignment cross in the middle and 2 top positions and tap about 3mm above the cross in the bottom 2 positions (portrait format). This means of course that the bottom of the screen is out of alignment and I have to tap high at the bottom of the screen but I have got used to it. Not great, I know, but its better than nothing.
Steve
Oct 13, 2008 | HP iPAQ HX4700 Pocket PC
Touch screen problem
Change the LCD (and not the touch screen) is what i've done and it's very easy.
If you had it apart you should have seen the connector of the screen.
Just look for a LCD on ebay, for example, and you'll see what the connector looks like.
Changing the touch screen is surely more complicate as you have to unglue the touch screen.
So as i've found a LCD for a quite cheap price i did buy it and change it, everyting is fine now.
Aug 15, 2008 | Computers & Internet
Align screen
i have the same problem wat to do i am stuck wit align..
Aug 13, 2008 | i-mate PDAL Pocket PC
Stuck on "align screen"
your touch screen gone just change your touch screen it goes back to normal
Mar 20, 2008 | HP iPAQ H6300 Pocket PC
Dell Axim X50 Pocket PC Logo
147 people viewed this question
Alun Cox
