Question about Hobart 84145 Food Processor
Im trying to put a belt on a hobart 84146 - Hobart 84145 Food Processor
    Scholar:
  • 44 Answers
I'll do my best to recall all the steps, I haven't done it in a while. Read instructions fully before starting, as step three may not be necessary, although if performed you'll have much more room for your hands during the remainder of the process.
1. Lay machine on side/back (so that the knife shaft is standing vertically) to access the bottom.
2. Remove bottom cover panel.
3. Remove motor. Two nuts are easy to access, the other two are quite difficult to reach. This step might not be necessary if only changing a belt because you should be able to slip the old belt off and the new one on without completely removing the knife shaft. If the knife shaft must be removed for some reason, the motor must come out to give you room to fit a puller onto the knife shaft (in order to remove the lower knife shaft bearing and lift out the shaft).
4. Take note of the knife shaft pulley. Notice how close to the casting the pulley is. When re-assembling, you'll need to position the pulley at approximately the same location for the black belt to track properly). Loosen two set screws securing pulley onto knife shaft and slide pulley down (don't lose the key for the pulley when you slide the pully down).
5. On the "outside" of the machine, remove the plastic cover where the knife shaft enters the casting.
6. Now visible is a special locknut and special lockwasher (sorry, don't know their names). One of the tabs of the lockwasher is likely bent upward into one of the slots of the locknut. Use a hammer & punch to bend the tab out of the locknut's slot, allowing the nut to turn.
7. Using a hammer and punch, position the punch in one of the slots on the locknut and spin the nut counter-clockwise with sharp blows with the hammer & punch. Have an assistant hold the shaft to offer some resistance to the shaft spinning if you're having difficulty. This may also be easier with the motor and belts still in position, using the motor to partially hold the shaft from rotating while driving the locknut loose.
8. With the locknut removed, spin it back onto the shaft a few threads with the flat side of the nut towards the casting (upside down compared to it's original, installed position). Don't spin it all the way on, you need room to fit a prybar under the flat edge of the nut.
9. Using two prybars, one directly opposite the other, under the now upside-down locknut, pry up evenly on each side of the locknut, and the shaft usually pops out fairly easily.
10. Back on the bottom side of the machine, slip off the belts and replace with new belts and reassemble machine.
11. Be sure to turn the locknut back around to it's proper orientation and be sure to tighten it with a hammer and punch just as during disassembly (special wrenches exist for those nuts, I don't know their name) and bend one of the lockwasher tabs into one of the locknut slots (even if you need to turn the locknut backwards slightly from it's fully tight position).
When everything is reasembled, be sure the flat black belt tracks properly, that is, make sure it doesn't walk off the pulley as the motor runs (just spin the shaft by hand at first to observe if the belt tracks properly.
Good Luck!
Posted on Dec 16, 2010
Moter is working but dooh hook not working
hi if you still have problems email me and i will try and talk you through,
it may be the belt (teeth worn out) or the pulley (same problem).
the info given in your post is very vague.
if its the teeth on either the belt or pulley there is a simple fix.
remove bottom of base with screwdriver there should be screws under the feet of machine. use a bike valve screwdriver to remove the two remaining screws(depending on make and model)
remove belt, put RUBBER BAND
Jan 24, 2013 | Kenwood MX270 Patissier Food Processor
When i turn on the hobart fp41 food processor nothing happens.But when i push on the contactor with a screw driver it works.Does that mean that the switch is bad or is there something wrong between the...
have you tried to replace the contactor and see if that helps at all? If there is another issue like a bad switch contact then you can still replace that becuase some of those parts are universal
Feb 28, 2011 | Hobart FP41 16 Cups Food Processor
Hi my mixer suddenly wont spin and im not so sure how to fix it.
if its like mine the belt or pulley wear out mine took 8 years for it wear out. i couldnt find the parts so i took of the base(make sure its unplugged) remove the belt(hold one side of belt over the large cog and turn the cog, the belt should fall off) get a large rubber band (the width of the pulley)and twist the band over the pulley a number of times until it fits tightly over the pulley, replace belt and base and it should work.
this will work if the belt or pulley teeth are worn
my wife still cant beleive it worked
Dec 19, 2010 | Kenwood Food Processors
Hobart slicer 1612 need to make the product thickness ajustment knob work . It was stuck from non use . I have tried spraying with silicon spray the two shafts, but i dont undrstand the mechanism that...
Hi, I just received an older 1612 Hobart, and fixed the same problem.
First i disassembled the linkage from the bottom, then i used a propane torch to heat the rods and the aluminum castings (carefully, bring the temp till it is hot to the touch) Hammering doesnt work well so i made a piece of pine appx 1x1" with a notch to use as a pry stick. put a thin piece of plywood against the casting so you dont crack the housing, as it is thin alum.
Worked for me, take your time
Nov 13, 2009 | Hobart Food Processors
Hobart grinder mdl 4346, what is the value the control board is looking for on 1QTM and 2QTM? Is this a resistance (thermistor) and if so, what is the value? We had the motor re-wound but could not...
It is a thermistor and the value should be approximately 100k ohms at room temp.
You can substitute a pair of 100k ohm resistors to allow operation but to actually get the protector board to function as designed you will need the ~100k ohm thermistor with the correct temp / resistance curve bonded into the stator.
An option would be to use a standard motor starter for the protection although the wiring gets a bit tricky with the relays, aux switches and the reversing contactor.
Another option would be to imbed / affix a klixon type overload into the windings and wire this in series with your 100k ohm resistor.
This will still allow the board to indirectly protect the motor.
Oct 26, 2009 | Hobart Food Processors
How to remove and replace a hobart slicer blade model 2712
PHIL SMITH HOW DO YOU CHANGE THE BLADE ON HOBART SLICER 1712??
Sep 09, 2009 | Hobart Food Processors
Hobart Meat Slicer not working..please help!
i have a automatic holbart meat slicer and i can't get the blade to closes all the way any information? thank you:)
May 08, 2008 | Food Processors
Hobart 84145 Food Processor Logo
928 people viewed this question
Top Hobart Food Processors Experts
eyecam
Are you a Hobart Food Processor Expert? Answer questions, earn points and help others
