Question about GE GDS18LBR Bottom Freezer Refrigerator
Evap fan not working
My evap fan is not working. wow do you access it to test/repair
  • macsadow Nov 10, 2008
    Hi, I have exactly the same problem fridge does not working but freezer is OK.
    However the evaporator fan is working Ok but there isn't cold air flow from control console inside the fridge ???
Thx for you comment, There is no back panel inside this freezer. You remove the bottom panel of fridge to access evap and motor. Motor had power to it. Ohmed out motor and was open.
Posted on Mar 31, 2008
  • 109 Answers
You must remove baqck panel from bottom of freezer compartment, there you can access fan and other freezer components, check for open defrost thermostat as well.
Posted on Mar 30, 2008
P0466 circuit location on 1997 Isuzu rodeo ls 3.2L 4x4 automatic transmission?
wow, and engine size 3.2L and 4x4 auto. (all there key facts)
P0466
Evaporative Emission (EVAP) Purge Flow Sensor Circuit Range /
login to alldata.com
read the pages on how to diagnose EVAP, system.
its the tank venting system called EVAP controls.
1: tighten gas cap, (or replace it, if bad)
2: reset the code with scan tool (or pull fuse EB12 ECU ,5min)
3:drive
4: is it gone now.?
5; IF NOT?, MORE WORK, if You must do smog tests, it must pass.
and not stated.
Nov 25, 2015 | Isuzu Cars & Trucks
Kenmore 106.54584400 fridge warm, air baffle No open in normal ops. in test mode opens and closes but evap fan does not run. fan motor runs during normal ops. thermistors good in test mode.
I would meter test the evap fan it may have gone out cuz if it was ur defrost timer or cold control you would have no motor condenser fan working either? and no cold control damper working in test mode?
is the fan impeeded or just not moving?
May 21, 2015 | Kenmore Refrigerators
What is anti pollution fault indicating malfunction in emission control system in a peugeot 307
WOW! that is a big question! It will require testing of all related components including the evap system and related electronics, gas cap, all evap hoses, egr system, etc.....This is going to take some diag. time
Jul 26, 2014 | Peugeot 307 Cars & Trucks
Code 442-455 replace all hoses coming from the fuel tank, fuel filter and the and some othr that were craked also replaced the gas cap.
old posts.
wow, no year car stated. not that makes this hard....
wow2, no engine option stated,either. trike 2.
did you forget to use the scan tool an RESET the PCM.?
evap failure !
fuel tank , vent failures.
the FSM covers the tests. in detail.
you use pressure tests. we use shop air, and a low pressure regulator (laws in some states require mech to use nitrogen tanks)
we pressurize the vent system. and make sure it works right.
the tests are easy, here.
i most smog stations we do that at the fuel tank filler neck with a cap
adapter to the pressure leak down tester.
Most smog today are from this system failing, that is why each year
the system is more complex.
EVAP 1 ,2, 3, ETC.
there are 3 classes of failure
  1. wont hold pressure (even a bad cap does that)
  2. the solenoid valves bad. stuck etc.
  3. the tests parts are bad, there are parts of this system just to do the test and they too can fail.
all 3 ways and tests are covered in the FSM.
ever seen one, the factory service manual under EVAP chapters.
the PCM does not ever know why or what is bad, it only knows the EVAP monitors failed, nothing more,
a tech, does the EVAP tests by the book and finds , truth.
ill guess year, 2000
read the emissions page here
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
do you have the leak pump. options?
Feb 26, 2014 | Jeep Grand Cherokee Cars & Trucks
Water dripping from unit need to access drip tray and drain pipe on indoor unit
It sounds like you have a central a/c that has part of the system, the compressor, condenser coil and fan outside on the ground, and the rest inside. The inside part, the evap coil, normally uses the same circulating fan as the heater. If this is the case, then locate your heater access and you should find the evap coil and its drip pan in the duct work.
Jul 13, 2011 | Heating & Cooling
Freezer staying cold but fridge side is HOT
The Evaporator fan is not working. Located in the freezer above the evap coils is the circulating fan. Remove the cover to access the evap coils and circulating fan. If fan runs you have a defrost problem and the evap coils will be frozen over.
Nov 06, 2009 | Refrigerators
Check engine light is on for emission evaporator failure-large
P0455 - EVAP Control System Leak Detected (No Purge Flow or Large Leak) The PCM monitors the complete EVAP control system for no purge flow, the presence of a large fuel vapor leak or multiple small fuel vapor leaks. The system failure occurs when no purge flow (attributed to fuel vapor blockages or restrictions), a large fuel vapor leak or multiple fuel vapor leaks are detected by the EVAP running loss monitor test with the engine running (but not at idle).
  • After-market EVAP hardware (such as fuel filler cap) non-conforming to required specifications
  • Disconnected or cracked fuel EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube
  • EVAP canister purge valve stuck closed
  • Damaged EVAP canister
  • Damaged or missing fuel filler cap
  • Insufficient fuel filler cap installation
  • Loose fuel vapor hose/tube connections to EVAP system components
  • Blockages or restrictions in fuel vapor hoses/tubes (items also listed under disconnections or cracks)
  • Fuel vapor control valve tube assembly or fuel vapor vent valve assembly blocked
  • Canister vent (CV) solenoid stuck open
  • Mechanically inoperative fuel tank pressure (FTP) sensor
Check for audible vacuum noise or significant fuel odor in the engine compartment or near the EVAP canister and fuel tank. ----------------------------------------------------------------------------- HX43 DTC P0457: CHECK FOR MISSING OR LEAKING FUEL FILLER CAP
  • Check for missing fuel filler cap.
  • Check for loose fuel filler cap.
  • Check for possible cross-thread fuel filler cap condition.
Is a fault present concerning the proper installation of the fuel filler cap? Yes No REPLACE cross-threaded or damaged fuel filler cap. RECONNECT and TIGHTEN the fuel filler cap only one eighth turn so that the cap initially clicks by sound or touch. CLEAR Continuous Memory DTCs. COMPLETE an Evaporative Emission Running Loss Monitor Repair Verification Drive Cycle (refer to Section 2 , Drive Cycles). RERUN Quick Test . If DTC P0455 or P0457 is present, Go to HX44 . CLEAR Continuous Memory DTCs. COMPLETE an Evaporative Emission Running Loss Monitor Repair Verification Drive Cycle (refer to Section 2 , Drive Cycles). RERUN Quick Test .
For DTC P0455 still present: Go to HX44 .
Otherwise, INFORM the vehicle owner that it is important and necessary to immediately install the fuel filler cap after every refueling event. HX44 DTC P0455: VISUAL INSPECTION FOR SUBSTANTIAL EVAPORATIVE EMISSION SYSTEM LEAKS
  • Check for missing fuel filler cap. If the cap is loose DO NOT DISTURB EVAP system.
  • Verify that both the input port vacuum hose and EVAP return tube are attached to the EVAP canister purge valve. Note: If the EVAP canister-CV solenoid assembly is not accessible during this pinpoint test step, GO to Evaporative Emissions, Section 303-13 in the Workshop Manual for removal and installation instructions.
  • Verify that the CV solenoid is properly seated on the EVAP canister (if possible).
  • Visually inspect for disconnected or cracked fuel vapor hoses/tubes between the intake manifold, the EVAP canister purge valve, the EVAP canister, the fuel vapor vent valve assembly and if applicable the fuel vapor control valve tube assembly.
  • Check for damage to the fuel filler pipe and the fuel tank.
Is a fault indicated? Yes No CONNECT or REPLACE fuel vapor hoses/tubes as required. REPLACE damaged EVAP system components (fuel filler pipe, fuel vapor vent valve assembly, fuel vapor control valve tube assembly, EVAP canister purge valve, FTP sensor and EVAP canister-CV solenoid assembly) as necessary. REFER to Evaporative Emissions, Section 303-13 in the Workshop Manual for removal and installation instructions. GO to HX45 . GO to HX45 . HX45 DTC P1443 and P0455: CHECK FOR EVAPORATIVE EMISSION SYSTEM LEAKS
    Note: When checking for leaks or blockages in the EVAP system, energize (close) the canister vent (CV) solenoid through the scan tool for a maximum of nine minutes per pinpoint test step. Then de-energize the CV solenoid prior to performing the subsequent pinpoint test step. This is done to assure proper closing of the solenoid.
  • Disconnect and plug the EVAP return tube (EVAP canister purge valve to intake manifold) at the intake manifold vacuum source.
  • Connect scan tool.
  • Key on, engine off.
  • Access VPWR PID. If the voltage is not 12 volts or greater, GO to HX61 .
  • Locate evaporative test port [marked EVAPORATIVE SERVICE PORT DO NOT USE UNREGULATED PRESSURE ABOVE 6.89 kPa (1 PSI)] near EVAP canister purge valve or EVAP canister.
  • If vehicle is not equipped with the evaporative test port, GO to HX50 .
  • Install the Rotunda Evaporative Emission System Leak Tester 310-F007 (134-00056) or equivalent at the evaporative test port.
  • Close CV solenoid by accessing Output Test Mode on the scan tool.
  • Select ALL OFF mode and push START button.
  • Regulate the nitrogen or argon gas pressure on the tester to 3.48 kPa (14 in-H 2 O).
  • Follow the instructions that come with the EVAP System Leak Tester and pressurize the EVAP system.
  • Perform the EVAP system leak test.
Does the pressure on the EVAP system stay above 1.99 kPa (8 in-H 2 O) and pass the leak test? Yes No GO to HX46 . REMOVE the EVAP System Leak Tester from the evaporative test port and REINSTALL the test port cap. GO to HX50 .
Apr 15, 2009 | 1999 Lincoln Town Car
GE GDS18LBR Bottom Freezer Refrigerator Logo
134 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
