Question about Performance Teknique ICBM-782 Car Audio Amplifier
Blow out amp
I was trying to instal my 4-channel performance teknique amp and accidently the positibe(power) cable that comes from the battery touch the ground and the 2 foses on the amp blow out so i replace them and i was trying to make it work put i coulnt it didnt turnback on again so it is possible that the amp wont work no more???
  • 311 Answers
Try a basic connection connect
positive from car to positive of amp
ground to ground
and positive of car to remote of amp
see if it turns on
also check the fuses in the car
check for voltage on the wires
Posted on May 15, 2010
I Hooked up a Performance Teknique 1200 watt 2 channel amp to my 2 12" comp kickers. and before doing all this i took out the fuse. from my car battery. after everything was hooked up i put the fuse back...
disconnect the amp and then put the fuse in.if it blows,there is a pinched wire causing a short.
Also,big amplifiers like that have to be wired battery direct.
the surge current at boot up can pull 100 amps for 10 millisec.
Jan 13, 2010 | Performance Teknique ICBM-892 Car Audio...
I have 2 perfomance teknique 700wts and i dont know what kind of amplifier use
Hello perezmagdiel,
That 700 watts is maximum peak power, not RMS. If you're looking to not spend a lot of money for an amp, but want something that sends enough power to the Performance Teknique's, I'd recommend a 2-channel like the Boss Diablo D400.2. It's plently powerful enough and if you change out later, the amp can be bridged. And for inexpensive, it's got a lot of nice features, including a remote level control. It's 2ohm stable in stereo. Nice, for under $70.
Hope this helps.
Jul 17, 2009 | Performance Teknique ICBM-892 Car Audio...
Performance teknique icbm-782 amplifier will not power on
run 12 volt into your rem terminal and see if it comes on if it does your remote wire coming from the headunit is bad or cut
Apr 15, 2009 | Performance Teknique ICBM-782 Car Audio...
Wont power on after checking all the wires
HI DUDE PLS CHECK UR REMOTE WIRE IN UR PLAYER .... U MIGHT BLOW THE FUSE .. ... THE CONNECTION IN REMOTE WIRE WILL POWER EVEN THE FUSE BLOW ..
ICBM-DIGITAL MONO-Channel 2000W AMPLIFIER speaker much
Look into competition lines of different manufacturers.... Massive Audio DMX, Soundstream, Atomic APX, Incriminator Audio Death Penalty Series, Kicker Solo X etc. In car audio, you have to pay to play. Dont expect a 100.00 subwoofer to take 2000W continuously.
Massive Audio offers a no questions asked warranty. Even covers blown voicecoils!
Dec 21, 2008 | Performance Teknique ICBM-Digital Car...
Audio system set up
Well one problem is you might need a smaller amp depending on how many speakers you have, 1200 watts is way overpowering for 300watt max speakers and could possibly blow them and even catch them on fire!!!! But everything else is compatable because all of your epuipment is of a newer products but if you dont have 4 guage wires or anything else make sure you get them heres a list: 4 gauge wires for power and ground, REM wire "blue is the normal color" RCA jacks, A compacitor, fuse for battery to amp to keep system from blowing up, 8 gauge speaker wire or even 12 guage to hook up from the amp to the speakers, That should be the common things you need to have a good thumpin system!!!!
Sep 12, 2008 | Performance Teknique ICBM-892 Car Audio...
My battery dead when i want to turn on car--what do i need?????
monster cable its good for our amp but do nothing for the battery its all depend how many amp our amp take away from the battery if our alternator is 90 amp maximum the alternator output is 75% off 90 amp =70 amp available if each amp take 25 amp you only have 20 amp left for everything else there no way our alternator is enough that y you drain the battery you need a bigger alternator and battery the minimum you can do is put ourself another battery you gonna have more capacite but you gonna have to charge it up at night put a little battery charger 2 or 3 amp per hour that should fix it cheaply hope it help dont forget to rate me cheers
Jan 18, 2008 | Performance Teknique ICBM-782 Car Audio...
Wiring question
Hi, If I got the specs right, your amp is a 4 channel hence the 4 RCA inputs. Probably the simplest would be to feed the 2 X RCA out of the deck to the 1 & 2 RCA in of the amp. This amp has also a line out, feed the amp's lineout back to the 3 & 4 in. This way, all four channels get same input from the deck and you will have identical power to all 4 speakers (front & rear). An afterthought is to also use the 4 outputs of the deck (since they are there anyway and it is not a good tech practice to leave outputs without load/speakers) and connect 4 mid-range or 4 smaller speakers. Hope this be of some idea/help. Post back should you need additional information. Good luck and kind regards.
Sep 02, 2007 | Performance Teknique ICBM-774 Car Audio...
Performance Teknique ICBM-782 Car Audio Amplifier Logo
130 people viewed this question
Top Performance Teknique Car Audio & Video Experts
George Nalley
Level 1 Expert
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
