Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Instructions on how to refill the the ink cartridge for a Canon mp730 .
  • Canon Expert
  • 316 Answers
You can easily to refill it only one time.If itself open cartridge and hole top of the cartridge push refill ink and close tide and tide.First time clean cartridge OEM software by printer default.
Posted on May 15, 2010
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
How to change ink cartridge mp730
Hi Sandra,
Follow these instruction in attached images.
Feb 10, 2012 | Canon MultiPASS MP730 All-In-One InkJet...
Wrong cartridge...I removed the cartridge head, cleaned with alcohol as suggested, to no avail
If you are getting an error that says "wrong cartridge" then the ink cartridge you are trying to use is defective. Return the cartridge to the store you bought it at and get another one. Do not use refilled cartridges unless they are purchased by a professional who knows what they are doing. Your problem lies with your ink cartridge and not the printer.
Jul 16, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MultiPass MP730 purchased 2004 NOT Printing Black INK- did: new canon ink tank inserted (never used refills) ran: printhead maintenance mannually cleaned print head w/ rubbing...
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Dec 02, 2010 | Canon Office Equipment & Supplies
How to refile the cartridge of canon pixma ip1300 printer
Instructions :
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Good Luck!
Aug 28, 2010 | Canon PIXMA iP1300 Printer
I have a canon mp730 and since I have replaced my ink cartriges I keep geting a wrong cartridge message. I have checked and rechecked installation and re booted several times to no avail. I have checked...
Many times , if we use refilled ink cartridge , then also we might get such error messages on the printer display .
Ensure that you are using genuine Canon ink cartridges.. but if the error is after changing to a new set of genuine ink cartridges..
try by cleaning the electrical contacts of both ink cartridge and the printer.. and also do a semi full reset..
Aug 12, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer saying refilled bci3e is empty, when it is actually full
This is a very common issue with refilled ink cartridges. The fact is that you have a MP730. The cartridges have an eprom chip loaded into the cartridge which blows once the cartridge is empty. Refilling it as a general rule does not work. The best and only solution to your problem is to pop out to your stationery supplier and purchase a genuine canon cartridge.
As a side not, the ink inside the cartridge is covered by a patent held by canon. it means that no other supplier can use this particular grade of ink. The use on non genuine ink will destroy your printhead and make future use of your unit much less than its normal life expectancy.
Gremlin 11
Dec 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
I've heard that with canon there is a way around the ink-level chip monitoring on the cartridge by doing the following:
  1. Power off printer
  2. Hold RESUME button then press and hold POWER, the beeper will sound once.
  3. Hold POWER and release RESUME
  4. Press RESUME twice
  5. Release POWER button
  6. When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
  7. Press POWER to set data
Jan 03, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
61 people viewed this question
old marine
old marine
