Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
BLACK INK IS NOT WORKING
THE BLACK INK IS NOT PRINTING. I HAVE TRIED TO CLEAN IT. TEST INK. TAKE IT OUT AND REPLACE IT
  • 316 Answers
May be problem on your printer head nozzle jam.So you should to need clean or replace.If itself clean with worm water or other way clean all surface in on nozzle with tissue paper.With the best luck.
Posted on May 15, 2010
Testimonial: "AWESOME"
5 Suggested Answers
SOURCE: black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Posted on Dec 20, 2008
uten
  • 162 Answers
SOURCE: new cartridge won't print
re-seat the black cartidge, do head cleaning, get a windows test page (go to printers and faxes then right click on the printer icon and choose properties, click the print test page button).
replacing ink cart is the next step or service.
Posted on Nov 26, 2008
  • 10 Answers
SOURCE: epson CX3650 printing gaps
Remove ink cartridges one by one and put it back in. If same thing happens, try to do head cleaning and nozzle checks consecutively from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the patterns appear, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Posted on Jan 01, 2009
yooperbud
  • 8637 Answers
SOURCE: new black ink but still not printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
HP Officejet Pro L7555 will not print black ink
Replace print head(black & yellow) or try to clean the nozzle.(try youtube videos for cleaning)
May 19, 2014 | HP OfficeJet Office Equipment & Supplies
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
Canon pixma ip1000 print black colour with gaps.
Sounds like printing nozzle problems, or the waste ink absorber is saturated. There is step by step guide to cleaning it at
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Jan 23, 2014 | Computers & Internet
Hi my printer won't print black, test colour work but no black, therefore all text to print is blank. I have replaced the ink with a new one and cleaned it 5 times, still no black ink. Thanks
Hi
Clean it manually by removing the black ink cartridge and rub the print head into a paper with rubbing alcohol until ink flows more. Then run the print nozzle to clean the print head thoroughly. After, try to print again.
If not, dip the print head only into hot water for 5 minutes and then run the print nozzle.
Let me know if you need more help
Mar 08, 2011 | Brother MFC 420CN All-In-One InkJet...
Our Brother MFC-490CW printer prints yellow, blue and red but won't print black even though we just replaced the black cartridge. We've checked everything about the new cartridge -- we took off the...
you have air in the air line tubes. you can try doing a couple cleaning, wait 24 hrs, and try a couple more cleanings and then do a test print.
you can try doing a ink purge, but it will **** up a lot of ink, but it might be your last resort.
press menu, and then *2864 quickly, then type 76, use the arrows to select black and then press 0.
when all done press 99 to exit.
It may work it may not, its possible you may even need to do it again, however, your inks will be depleted.
Aug 12, 2010 | Office Equipment & Supplies
My brother mfc-240c doesn't print black. I replace the black with a new cartridge as it still wouldn't print black. I also tried to clean all the colors numerous times, but to no avail. I don't know what...
Wow, something similar just happened to me the other day, my black ink ran out & when I replaced it, it just wouldn't print, I kept trying to print things and it sounded like it was printing but then it would just shoot out a blank page of paper (I was trying to print BLACK). So, I went to the Brother website for troubleshooting tips and it said to make sure I had the ink cartridges installed properly so I took the black cartridge back out (it WAS installed correctly, but I was willing to try anything at this point), so I took it out, gave it a blow, like how you would blow on the old Nintendo game catridges when they did not work-I'm not sure if this did anything at all but it's what I did) and then I put it back in). The machine asked if had just replaced black I said "Yes", then it did another "cleaning", as it does when you replace any cartridge. Then I went in the menu to have it print out a "test page" (the instructions for this were in the troubleshooting tips on the website), the test page printed out with NOT all the little black squares as IT SHOULD BE so when it asked me if the test page was ok, I said "NO", then it did ANOTHER CLEANING and I did another test page, this time it worked ok, then I was able to print.
So, bottom line is, maybe take the ink out, make sure you installed it correctly, put it back in, print a test page, if the test page does nto come out right, then tell it it is no good by selecting "NO", then it will do another cleaning and then maybe it will work, if not, then check for more troubleshooting tips on their website, good luck.
Jun 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
Pixma MX850
I was working on the Pixma mx850 for 3 weeks now. I have found that you need to reset the using back to factory default. On the display look for the "printer head" cleaning and alignment. Go through the steps that it gives you for printer head cleaning. Print a test page. have you tried to copy in "black/whte" and not color? that will use the large black and not the small black cartrdge. Try a couple of black circles in "paint" if your running windows XP. make a test page of your own and print it.
Apr 15, 2009 | Canon PIXMA MX850 Multifunction Printer
Printer replaced with black cartridge, and doesnt print
Either the print head for black is faulty, or the wiring to the black print head on carriage are broken. Try also cleaning the metal sensor to the black cartridge inside the ink carriage.
Apr 14, 2009 | HP Officejet J5780 All-In-One InkJet...
Black ink not working
Your black ink printer head might be blocked by dried materials. Try to open your printers maintenance software and execute head cleaning procedures. Try to print a test page after every head cleaning or you may run print head diagnostics. If the black ink still doesn't print, try to use another black ink cartridge and compare with initial results.
Apr 01, 2008 | Computers & Internet
Big black cartridge not printing
Try replacing your printer ink cartridges with a new one.Chances are you have bought a defective cartridge. If that does not work, pls try to check the slot for your black ink for obstructions, then replace your black ink cartridge.
Mar 07, 2008 | Canon i860 InkJet Photo Printer
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
1,539 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
