Question about Dell Inspiron 640m Notebook
Realtime clock RTC is not working - Dell Inspiron 640m Notebook
    Sergeant:
  • 356 Answers
Hi there! I think you might need to change your CMOS battery... or update to the latest BIOS available for download from the dell support website.
Cheers!
^_^
Posted on Jun 03, 2010
I have a RS Medical RS-4i Plus and it keeps saying on the display, RTC error how can i fix that.
Verbatim right of of the manual: If any of the following Device Errors appear the product will not work and will require repair by an RS Medical technician. Contact Customer Service at 800-935-7763 to discuss repair or replacement options. RTC error - displayed when the real time clock (RTC) has been disrupted or has lost charge.
Nov 03, 2017 | The Computers & Internet
Rtc battery is low or cmos checksum is inconsistent
The RTC battery is a rechargeable Li-ion "clock" battery that's buried underneath the keyboard - it keeps date and time going when your computer is turned off. If you're getting this message, you should go follow the screen prompt, hit F1 to enter Setup, and set the date and time, leave the computer on for several hours to charge it (the clock battery recharges only with the computer turned on) and it should go away.
In the rare event that your RTC battery is bad, it's really up to you as to getting it replaced or not - it's a lotta work, and not all the battery vendors out there is competent enough to sell you the right kind of battery (installing a non-rechargeable Lithium battery will kill the thing outright, and there are actually people selling these....). Not having a working RTC battery doesn't really interfere with the workings of the computer - you'll just have to set date and time every time you start it, and you can do so manually or by downloading some freeware such as Atomic Clock Sync to automatically do it for you.
Sep 19, 2011 | Toshiba Satellite A45-S151 Notebook
Toshiba a60-155. keep getting press f1 setup screen. have to enter date. keys 1 and 2 don't seem to work. can I bypass this page
Don't think you can bypass this thing because the RTC (Real Time Clock) battery is, most likely, dead. But if you can replace the just the keyboard, then you'll still have a working computer. I'd leave the RTC battery alone and use software (such as Atomic Clock Sync) to set the date and time automatically every time the computer boots into Windows.
Jul 08, 2011 | Toshiba Satellite A60 Notebook
Vx510le bad rtc chip how to reboot Problem
Bad RTC suggests a bad Real-Time-Clock, and it's usually bad because the battery for that clock has been let run down, or humidity killed that battery. Try replacing the battery first, then consider replacing the chip (using a soldering iron and replacement chip.)
May 31, 2011 | Computers & Internet
Why is my samsung mp3 shows me RTC Checking while i plug it into the PC?
RTC is standing for Real Time Clock.
It's checking it to synchronize your MP3 Player internal clock with the your computer clock.
Hope this explaines
Mar 04, 2011 | Computers & Internet
Is there a patch to fix the clock error? my vostro does not keep time when shut down
Date & Time are kept by RTC (Real Time Clock) CMOS Battery, which is usually a coin-cell battery on the motherboad.
As the RTC of your system is dead, it can not keep time.
Therefore, RTC (CMOS Battery) is required to be replaced with a new one to fix the issue.
Refer here for more information/ disassembly guide.
Let me know if any further clarification is required. Hope this helps! Dont forget to rate the solution!!
CreativeTECH
Nov 29, 2010 | Dell Vostro A860 Notebook
Were is the rtc can you show me a pic of the rtc
RTC stans for Real Time Clock. It is the chip that keeps the time in your computer and the beat, so to say. It keeps working even when the computer is down. It has an indepent battery.What do you want with it?
Hope it helps.
Aug 30, 2009 | Dell Inspiron 1501 Notebook
How to remove power on password on hp compaqnx6110?
You can try reseating the RTC battery:
http://h20464.www2.hp.com/index.html
Real-time clock battery removal Before you begin: Remove the battery and keyboard.
  1. Disconnect the RTC battery cable from the system board
  2. Use a small, flat-bladed, non-conductive tool to flip the RTC battery out of the socket on the top cover.
Real-time clock battery replacement
  1. With the positive (+) side facing up, insert and press the RTC battery into the socket on the top cover.
  2. Reconnect the RTC battery cable to the system board.
If this does not fix the issue, you may have to replace System board
Jul 06, 2009 | HP Compaq nx6110 Notebook
RTC battery
http://www.irisvista.com/tech/laptops/ToshibaM45/Satellite_M45_disassembly_1.htm
the rtc battery is on the motherboard.i doubt its the problem. If you have a voltmeter check your charger to make sure it is working. then make sure battery is charged with the voltmeter. try and run the system without the battery in, just using the ac adapter. if it works with the ac adapter and not the battery your battery probably needs to replaced as its been charged and discharged too many times. you might want to just reload the os. the link i gave gives disassembly to all toshiba laptops. the rtc battery on the motherboard looks like a watch battery. it should be good for 5 years or more. your laptop battery will go long before the rtc battery.
Nov 01, 2008 | Toshiba Satellite M45-S165 Notebook
Samsung YP-K3 MP3 Player Problem what is aRTC ERROR and how do i fix it ??????
For RTC error, open Windows Media Player and connect it. Windows media should offer to synch the clock. RTC stands for RealTime Clock
For License Error, this is to be expected around the same time every month. You see, when you transfer DRM protected music, a license is transferred as well. When you use a montly "all you can eat" plan, the licenses expiring every month keeps you from syncing all sorts of songs onto your device, then canceling your service, making away with free music.
Open your music service, connect the device, and synch a song to it. That should update all licenses.
Oct 19, 2007 | Samsung YP-K3 MP3 Player
Dell Inspiron 640m Notebook Logo
47 people viewed this question
Alun Cox
