Question about HP Computers & Internet
I have the tip for the charger to my hp 6960p and a charger rated correctly i just need to know which to hook to which
Blueparott B250XT Charger Specs
9vdc positive tip. Road King RPDC-812 available at most truck stops work great it's a universal dc adapter and the orange end fits the 250xt. Price $15 at Love's.
May 01, 2012 | VXI Corporation Blueparrott B250-XT...
So i lose my Literati charger right after my birthday! I cant find it anywhere and i found my old t mobile charger and it fits perfectly. But i cant tell if its chargeing and it wont turn on! Please help...
Stop!
There are no voltage and amperage "standards" for low voltage connectors found on devices made to run from an external "wall wart" or transformer type charger or adapter. Just because a connector "fits" does not mean the power is 1) the correct voltage 2) correct polarity 3) correct type (AC or DC) or 4) can supply the amount of power needed to operate the device.
You may have done irreversible damage to your device by literally "grabbing any old charger that fits" to power it. Obtain the correct charger - or if unable to find one; determine the characteristics needed by the device - those variables are listed in 1 through 4 above.
You may find adjustable power sources that allow 1) changing of tips to fit the device, 2) a selector to choose from a range of voltages, 3) a switch to select AC or DC output and 4) the ability to plug in the tip backwards so that the polarity reverses. The last thing needed, is to know how much current in amps or power in watts is needed by the device. The charger / adapter should be chosen on its ability to supply this power continuously - never choose a charger / adapter that provides less than any of the electrical requirements; otherwise damage to the charger or device may occur - and if left unattended, could overheat and cause a fire.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 23, 2011 | Computers & Internet
I lost my adaptor plug charges, so how?
This is not a complex problem, to find an acceptable charger for your machine all you need is some basic information about the device. First you will need to know the voltage and current requirements of the device. This should be posted usually as a sticker on the bottom of the device near where it would be plugged in, it should say something like 5 VDC 400mA this stands for 5 volts of DC voltage, and 400 mili amperes of current. Next you should take your device to a Radio Shack store they have lots of adapt-a-plug chargers with many voltages and currents and many tips to connect to them. All you need to do is find a correct tip to fit into your device, they have at the store an index where you can try different ones in your device. Once you have found a match you will need to locate either a home charger or a car charger with the EXACT voltage level as indicated on your device. I.E. if your device says 5vdc you need a charger that says 5VDC. Once you locate an acceptable charger check to see that the current rating is greater than or equal to what your device says. Most people think that a higher current rating on the charger will burn up the device, this is not true. The device only draws as much current as is necessary(trust me I am an electrical engineering student). Next the assembly of your charger is as simple as plugging the plug into the charger, there will be instructions on the box. The whole rig is usually less than 20 bucks, so its not too bad.
Feb 28, 2011 | Besta CD-608 Dictionary
My laptop is saying plugged in, not charging what whould i do ?
First u need to run a battery check . Steps are :
  1. Click Start
  2. Click All Programs
  3. Click on the HP Folder
  4. Then click HP Battery Check
    This may give out five results.
    Please let us know what is the result that it gives out.
Dec 21, 2010 | Compaq Presario CQ60-220US PC Laptop
I misplaced my power cord to my notebook. How do I determine which powercord is the ccorrect one?
A) Look on the bottom of the notebook. Usually states the Voltage (V) and Amperage (A)
Should state > Input: 18.5V/3.5A
(18.5 Volts at 3.5 Amp's)
B) Look at the charger;
The AC adapter (Charger) will state;
Input: 100 ~ 240V/50 ~ 60Hz
Output: 18.5V - 3.5A
Should look similar to this,
http://www.buy.com/prod/65w-new-ac-power-adapter-charger-cord-for-hp-compaq-presario-c300-c500/q/sellerid/24353325/loc/101/213887466.html
Nov 29, 2010 | Compaq Presario 700 470024-192 Notebook
I was having problems with the car charger CA-051, then, I used a T-Mobile charger, at first time worked, after that, the GPS Maagellan was dead. Is it possible that I have to order a new battery? or I...
Using non standard chargers is probably the problem. If the battery has suddenly become sogged since using this charger then it may have done more damage than you want to know about.
Was it the correct polarity +ve Tip? was it the right amperage?
Magellan are specific in recommending you only use their charger and with reason, its correctly made for it.
You can try the new battery angle, but get advice on the charger.
As a small note.. Car chargers do NOT fully recharge batteries in GPS. Use an AC or USB charger. The car charger is a maintenance power supply. Always fully charge the unit prior to use and do not plug to car power until engine has been started.
These are standard rules with all non hard wired GPS and phones, ( but not always in the manual, have to have service and new sales someway!)
Please rate my help++++Thanks for using FIXYA
Aug 11, 2010 | Magellan RoadMateā„¢ 1212 Car GPS Receiver
Charger port not working.
I worked as a computer tech for 20+ years, and I still hate taking laptops apart. I strongly suggest you take it to someone who knows what they're doing, or you might end up with a useless pile of parts.
Apr 16, 2010 | HP Pavilion dv4-1120us 14.1" Notebook PC -...
CanI use power rated 19volts instead of original power supply 18.5volts
As you have found... half a volt at that amerage should be just fine...
If it helps, I just bought an aftermarket replacement of the correct voltage and amperage for my nx9010 from eBay for $15AU delivered. It'd probably help when it comes time to sell your laptop =-]
Apr 19, 2009 | HP Pavilion dv5000t Notebook
HP Ze2000 laptop charger overheats
CHECK THE POWER OUTPUT RATING ON YOUR POWER SUPPLY AND SEE IF IT IS HIGHER THAN THE COMPUTERS POWER RATING, THIS INFO IS ON BOTH THE LABELS OF THE COMPUTER AND SUPPLY, IF ONE IS HIGHER THAN THE OTHER THAT WOULD EXPLAIN THE OVERHEAT, IF THAT IS NOT THE CASE, THEN GO TO ACERS TROUBLESHOOTERS WEBSITE OR CONTACT THEM DIRECTLY FOR HELP... JON T
Dec 07, 2008 | HP Pavilion ze2000 Notebook
IPOD30GB
you obviously need the charger, is your ipod the ipod video black? I need to know so I can point you at the correct charger.
Oct 25, 2008 | Apple iPod MA446LL/A MP3 Player
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
