Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
After replacing the bulb and replacing the case into the slot, the yellow "bulb" light is blinking as if its not input correctly.....what do i do?
  • 1,557 Answers
Its not the globe its a sensor youl need to have it looked at by a pro
Posted on May 15, 2010
Wd60c9 lights blinking green sometimes,then yellow and finally red and no picture for any significant length of time
2 possibilities. First, the bulb which allows you to view your picture could be burned out. If that is the case, your tv will turn on and you will hear audio but no picture. $85 for a new warranted bulb from Shopjimmy.com. Second possibility. If your TV is on with no picture or sound, you probably have a light engine problem.$325. I don't think it's your light engine. Just don't have enough information. Check the first possibility first. The bulb takes less than 5 minutes to replace. Don't buy just the bulb, buy it with the housing. It doesn't cost more, it costs less and saves a ton of aggravation. Don't touch the bulb with your fingers, use latex gloves when working on electronics.
Feb 23, 2013 | Mitsubishi WD-60C9 60" DLP HDTV
Mitsu hc3000 problem "red-green status light blinking and no input"
Heres what the manual says about REd / green lights
Unplug the power cord from the wall outlet and contact your dealer
And also this:
Check that the lens cap is removed.
It may take about one minute for the lamp to light up.
The lamp fails to light up on rare occasions. In such a case, wait for a few minutes
and then try again.
If the projector was turned off before the lamp was cooled down suf? ciently last time,
the fan may start rotating and the POWER button may not work after the power cord
is plugged. After the fan stops rotating, press the POWER button to turn back on the
POWER indicator.
Check that the intake vent is clean.
Set SCART INPUT in the FEATURE menu to OFF. (See page 25.)
Check that the lamp cover is closed. (See page 33.)
Check that the cables connected to the external devices are not broken.
When an extension cable is being used, replace it with the supplied cable for check. When
images are displayed correctly, add an RGB signal ampli? er to the extension cable.
Check the operation manual of the video device for its connection.
Mar 14, 2008 | Mitsubishi HC3000U Multimedia Projector
Yellowlight blinks 3 times on my toshiba 62hm116
If you are refering to the 3 yellow blinks repeated over and over the
boot data is corrupted. Download the firmware update(link below)from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses,I used a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
Jul 04, 2012 | Toshiba 65HM167 65" Projection Television
I have a WD-65737. The lamp gave out, so I replaced it. Now it will start, but generally after about 5 minutes of it running fine, it'll shut down and blink yellow
Where did you get the bulb. I tried a cheap one and it did not work correctly. I found a bulb dealer that had I believe had a warrentee of a year and I have had no problem since. I have a WD73737. the cheap bulb carrage was not quite to specs and did not fit correctly from bulb surface and there was a gap and color kept changing on screen. I got the bulb cheaper than Mitsubishi, aprox 75 t0 80dollars.
Sep 01, 2017 | Televison & Video
What does hdmi is blocked mean
Hello!
HDMI blocked could mean, that one or more HDMI inputs are turned off. In WD- series DLP TVs it's possible to disable one or more inputs, which are not to be in use, to speed up signal source switching. Most of modern sets are constantly monitoring inputs and automatically recognizing "plug"n"play" signals. blocking any input would not cause TV to shut down.
Yellow(amber) light means: lamp door interlock switch is off or malfunction. green blinking: set is initializing, about to begin normal operation. So: quite possible that lamp has been replaced incorrectly or door is not tight intermittently. Last possible issue: door's interlock switch is bad. Take lamp door off and you will find the switch with blue lever on the left side of the door inside plastic compartment. Push it with your "pinky" or pencil carefully, then ask someone to turn set on. Make sure, yellow light is off, before do so. If set starts normally, observe lamp's activity: it should stay on and getting brighter, while you holding switch. If lamp stops working, while there is no "amber" light, then TV shuts off, red blinks, lamp is bad. I just had to replace lamp twice, due to defective batch of lamps with housing. 3rd time I replaced bare bulb and it solved the problem. But there was no "amber" issue!
good luck,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
Won't turn on. Only yellow light at the bottom of the unit. I heard a brief clicking noise from the back. Maybe a relay. What are my options?
The yellow light means the monitor is in standby mode. When the computer is active the monitor sees a signal from the video card and it wakes up. You should check your cable, make sure the monitor is on the correct input if it has more then one, then try plugging in a different monitor to rule out the video card being faulty. If you are handy with computers you should also open the case of the computer and make sure the video card is fully seated in the slot unless it's onboard video.
Aug 08, 2009 | Samsung Computers & Internet
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Lamp light blinks
The blinking lamp light indicates that there is a problem with the bulb. Mine did this when I had used the bulb past it's life and the bulb was burned out. Use the owner's manual instructions to remove the bulb and visually inspect it. Mine looked burned out - it was black with clouds on the glass. If this is the case with yours, replace the bulb, or replace the whole unit. (Bulbs can be costly.)
Mar 21, 2009 | Sharp XR-30X Projector
Yellow blinking status light
I would make sure you have it seated correctly into the ballest some times the connector will come undun
Sep 23, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
90 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
