SOURCE: I would like to know the weight of a jcb 1400b
if it is standard clutch and the weight is 8,550lbs w/converter and 8,430lbs with dry clutch and if equip with extendahoe pwer shuttle is 9,210lbs and dry clutch is 9,090lbs and those weights do not include front or rear buckets of backhoe and loader as this can vary because of the size of bucket equip with. hope this will help you. [email protected]
SOURCE: Transmission on Backhoe
I think you need Check your Transmission Pressuer of your machine. After That Change Recormanded Transmission Oil & Right Quntity. Transmission Pressure Should be 10-12 bar.
SOURCE: Have wiring fault on a JCB Backhoe 1987 3CX and
Hi
you can get wiring diagram from here.
Hope this helps, thanks!
