Question about LG WM-2277HW Front Load Washer
Keeps tripping electric
As soon as turn on washer it blows the fuse in plug but not the electrics in the house
  • LG Master
  • 1,205 Answers
Are the elecrtic wires all well fastened where the should be fastened?. A loose wire in the plug or in the in the machine itself can blow a fuse, it does that to me. So I am careful to have wires well fastened. There is also the risk of fire starting.
Posted on May 15, 2010
2 Suggested Answers
  • 389 Answers
SOURCE: washer keeps fussing
it could be your heater as soon as it fills the heater is engaged on the neutral side and if your heater is down it will trip your 30 ma rcbo on your board the best way to make sure its your heater at fault is take the back off your machine make sure you are unpluged and you will see the heater terminals there are 2 at the bottom of the drum take the wires off and rap the spade connections wires up in tape turn on your machine on a 90c wash it will fill up and then switch it to a 30c wash but it might l not go though the complete cycle as it cannot heatup depending on how hot your water is if it does not trip anything out you will kwow its the heater let me know if i can help futher
Posted on Nov 19, 2011
Can the motor control board cause the house circuit breaker to trip?
It's unlikely. An internal fuse would blow first, I'm assuming. If you've diagnosed this far you sound capable of continuing. Electricity is dangerous!!! I would remove all things from the board, 1 by 1 plug each component into board until the breaker trips. That should pinpoint what is tripping breaker. I would assume a motor.
Apr 04, 2017 | Heating & Cooling
Why does it blow controller fuse when key is turned on?
Electrical: Circuits, Relays - SwedishBricks
www.swedishbricks.net/700900FAQ/Electrical-CircuitsRelays1.html
fuse keeps blowing Drills & Drill/Drivers Questions ... - Fixyawww.fixya.com > Forum > Tags > fuse keeps blowingDrills & Drill/Drivers fuse keeps blowing questions and answers. Ask your fusekeeps blowing drill and drill/driver questions. Get free help, advice & support for ...Ryobi Multi-Volt Battery Charger Fuse - Questions - Fixyawww.fixya.com > ... > Ryobi > Ryobi Multi-Volt Battery Charger1423701) and have blown the internal fuse. The label on the charger indicates the input is 120V AC. Question about Drills & Drill/Drivers. 1 Answer ...Remember that fuses can fail without showing signs of an obvious ... remember that suspect turn signal flashers, fuses, bulbs and relays can be ... will be predictable, such as a bad current or ground connection, blown fuse and the like. .... The relay then sends power to all the lock motors (all doors except driver's door).Missing: drills
[PDF]Electrical Safety - Occupational Safety and Health ...
https://www.osha.gov/.../4...
Occupational Safety and Health AdministrationShe has an older drill with a steel housing and a 3-prong plug. ... current. This willgenerally allow enough current to flow so that a fuse will blow or a circuit breaker is tripped, thus turning off the electricity in that circuit. ..... There are three major ways tocontrol power line hazards: 1. ... Install warning signs at driver's eye level.Missing: drills ‎key
Jan 07, 2016 | Drills
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
My wight knight wk767 condensing tumble dryer keeps tripping the electrics in my house when i turn it on the reset button at the is ok what is the cause .
Simply there is to much load on the breaker so its tripping to protect your home. I'm not an electrician so I am giving you info based off my experience. Some houses, most I think, have a special plug for the dryer and you can buy a different plug that screws on to the dryer depending on which plug your home has. You may need to upgrade your existing plug in the wall if its an older house. Also, I believe that circuits is on its own breaker separate from the rest so it shouldn't Tripp anything else but the dryer\washer. You can easily fix this yourself if you are confident in dealing with shutting off the electricity and rewiring the outlet or the dryer plus. If not then a electrician can do it easily allbet at a fee. Often times the Home depot or Lowes reps will give you advice but you have to understand its only advice. I would take a picture of the plug and the wall outlet and the breaker. This way you have something to show them at the store when you ask about the plug. One other thing it might be is that the dryer has a bad hearing element or sensor and its drawing to much current causing the trip of the breaker but usually dryers have a $50 fuse on the back that's supposed to blow out first.
Dec 07, 2014 | Dryers
Clarke power washers 150
Need more info:
What fuse? the one at the end of the cord on the pressure washer? Or the circuit breaker on your house?
If it is the one on the cord it may have gone bad. To test replace it with normal plug (non-GFI) and plug it into an outdoor or bathroom GFCI (GFI) outlet. If it still trips that outlet then there is a ground fault in the device which may be minor or major.
If it is a home circuit breaker remember that electric pressure washers use a lot of power - typically 1500 watts. If anything else is plugged in it can trip the house circuit breaker.
Jun 04, 2014 | Garden
Washer keeps fussing
Nov 19, 2011 | Washing Machines
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
Oven fuse blows - Nothing works
try lifting the stove top assy and checking wires under main top, leading to the elements them selves??? if tis tripping and not allowing to reset its gotta be an obvious short. isit hard wired directly to stove or into a 220 cord and plug???id look again, perhaps remove entire back panel and have someone trip on the breaker you might see where it flashes as it trips off
Apr 03, 2008 | Tappan TEF242 Electric Kitchen Range
LG WM-2277HW Front Load Washer Logo
239 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
