Question about Drive Deluxe Fly Weight Aluminum Transport Chair, 19" Seat
Bios sense cd-rom but not read cd
Cd-rom repair
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Right click my computer and click on device manager then right click on DVD/CD-ROM drive then Scan for hardware changes. Then xp will automatically mount the cd-rom.
Posted on Jun 09, 2010
Cd rom not read the cd
Posted on Nov 21, 2010
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
This is my first time building a computer. When I turn the computer on, I get a screen that reads: "Boot Block Compatible Version Ver.022 Bad BIOS checksum. Starting BIOS recovery... Checking...
My first thought is that you have a defective motherboard. I've never seen so many things going wrong except when the board was a dud. It sounds like the BIOS ROM or its interface circuitry is bad. If this board is still under warranty you can probably get it replaced. Try the vendor first. If you bought your board from a company like TigerDirect or Newegg, they're pretty good about replacing defective parts. Then check the manual or Asus website to see what you need to do if the vendor won't exchange it. I have used this same board (purchased from TigerDirect) in a couple of systems, and they went together without a hitch.
Once you've got a working motherboard, it should be pretty much smooth sailing with the rest of the assembly. Good luck and thanks for using Fixya! Please post a followup to let me know when you get your system running.
Dec 26, 2010 | ASUS M4A785M (890552666775) Motherboard
Will not read any cds or dvds
First you check from bios your CD-ROM is detected or not. If it is detected then you can clean the cdrom lence.if it is not detecting then it is a hardware problem. Then you can repaired it from service center.
Dec 18, 2009 | Acer (91.49C37.001) CD-ROM Drive
Trying to install XP when disk selection comes up it reads, "Unkown disk. There is not disk in this drive". NOt sure what that means.
your drive is not being read,
have you set BIOS to boot from CD ROM,
is your CD ROM working,
is your XP CD working
Do the following
1 go to BIOS and re-set to BOOT from CD ROM
2 use another copy of XP/Win98/Vista etc to verify if CR ROM is reading the CDs else...
if you doubt CD ROM drive has a problem....
3 use a USB external CD ROM, and to do that u need to re-set the BIOS to boot from USB CD ROM
Dec 07, 2009 | IO Magic Corporation GigaBank (I250HD35)...
System reboot
Depending on what bios it has it may not show the cd drive. All you can do is set it to auto or if it has the option to cd or atapi. Then set the boot order so that the cd is looked at before the hard drive and you should then boot off of the cd.
Oct 24, 2009 | Acer Aspire 3610 Notebook
Bad bios checksum
You need to go to the website of whoever made the motherboard and get the BIOS flash utility and the BIOS binary file to update your BIOS. Make sure you get the right one, as using the wrong one can render your motherboard worthless. The BIOS file has to be the exact match. There is no such thing as close in this situation.
If you are not sure of the exact make and model, get te free Belarc Advisor from http://www.belarc.com
The BIOS chip holds information about your motherboard hardware. It is reprogrammable. It uses what is known electrically erasable read only memory. This is also called Flash memory. Reprogramming is called flashing. When you flash the BIOS, all data is erased, then the new data is written. The flash utility will most likely allow you to save the old contents, but you might have an extremely tough time recovering from an improper flash. You'll also probably need a couple of floppy disks, one of which may have to be bootable. If you need a bootable floppy disk, you can get an image file from http://www.bootdisk.com.
Jan 23, 2009 | Intel Motherboard
Cannot boot from cd rom drive
choose in bios the first boot device the cd rom that is right then insert your winxp cd then save and exit. your computer then reads your cd and automatically reads rour previous operating sytem and installs
Dec 19, 2007 | AMD M863G (M863G15CV22ARV000) Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Drive Deluxe Fly Weight Aluminum Transport Chair, 19" Seat Logo
94 people viewed this question
Top Drive Health & Beauty Experts
Colin Taylor
ray gallant
Are you a Drive Health and Beauty Expert? Answer questions, earn points and help others
