Question about Panasonic NV-GS15 Mini DV Digital Camcorder
NV-GS15 MINI DV CASSETTE COMPARTMENT DOOR JAMMED
I was trying to solve another problem(Firewire in Vista Ultimate 64 bit and XP SP2, not recognising NV-GS15 in my laptop) and While the cassette compartment door open (I think) I turned OFF and then ON the camera. When I turned it ON, the compartment slid down while it is open.
The compartment door (where you have the little "PUSH" label) is open but compartment itself(Which has the lable "BEWARE OF JAMMING FINGERS") now had gone down to usual Compartment closed position, so I cannot
1. get the compartment "UP" since the plastic door with the EJECT button is open and stuck, which prevents opening using that button.
2. close the compartment door while compartment is lowered in to the camera.
Any help is much appreciated.
Best Regards
Prasad
  • 2 more comments
  • prasadg Mar 30, 2008
    This is how it looks now :(
    hope this helps in case if my description of the issue is not clear
  • Anonymous May 01, 2008
    Best Regards
    MARIUS
  • Anonymous May 15, 2008
    Same happened to me. Any solutions?
  • Anonymous Nov 01, 2008
    Exactly the same. I tried to slip a tape in. It pushed the tape back up. I took the tape out and it then retracted down with the compartment still open. If there was some way of triggering the door opening operation it might come up??
SOURCE: Push the reset button,PANASONIC NV-GS11
TURN DIAL TO PLAY---TURN ON ---TURN OFFF
TURN DIAL TO RECORD----TURN ON
You will see which position works....
Posted on Jul 18, 2008
sainisonu
  • 156 Answers
SOURCE: Problem in connecting Camcorder with Laptop
Use USB data cable which u get with ur cam.Install the panasonic software also packed with cam.And get ur video copied to pc.But this is a slow process because of Movie copied while playing.
Regards,
Sandeep
Posted on Oct 23, 2007
sainisonu
  • 156 Answers
SOURCE: Panasonic NV-GS15 Mini DV Digital
U get usb cable and a software cd with ur cam.Install the software and attach ur cam to pc with the help of USB cable and get ur movies copied from cam to pc
sainisonu
  • 156 Answers
SOURCE: How to capture recorded vedio from Panasonic NV-GS15 Mini DV Digital to Laptop
SOURCE: Jammed compartment door
I am pleased to say that my good lady wife, of 49 years standing, 'fixed' the problem ~ not once, but twice. Pat has always managed to solve such problems, and this time she was fiddling inside the compartment near the camera 'on/off' switch and, Hey Presto!, the camera now works satisfactorily. I attribute her prowess in solving small mechanical problems to a woman's intuition. I just wish I could be more precise on her success.
ernie@epullen.fsnet.co.uk
Posted on Aug 07, 2008
Nv-gs15 pc won't recognise camera to load mini dv film (vista)
Download the latest version of quicktime player and you should have no problem.
P.S. Always a good idea to keep all drivers updated
Jul 21, 2009 | Panasonic NV-GS15 Mini DV Digital...
Required USB Driver for mini dv Panasonic NV gs 15
The Panasonic NV gs 15 can only be used as a webcam with the USB cable.
You need a 1394 firewire / DV cable to transfer the video to your pc.
May 06, 2009 | Panasonic NV-GS15 Mini DV Digital...
Aug 04, 2008 | Panasonic NV-GS15 Mini DV Digital...
Service manual for Panasonic Handycam NV GS15
I fixed 2 cameras with same problem "Push Reset Switch"
Removed small foreign plastic object which was jamming mechanism without stripping.
In both cases a very tiny piece of one of the broken plastic 'catch' of the door was the problem.
Turn unit upside down and give it a good shake-up and it will drop off & problem solved.
Hope this helps.
Seedata
Feb 04, 2008 | Panasonic NV-GS15 Mini DV Digital...
How to get my PC recognize the Panasonic NV-GS15
Solution A: make sure you are using the correct cable for what you are doing (eg USB for webcam and importing photos and Firewire for transferring video footage
most desktops have firewire plug in them but laptops don't usually
to get a firewire plug in a laptop you need a PCMCIA to Firewire Cardbus (ask your local retail store for one or buy one on ebay etc.)
after that put the cardbus in your PCMCIA slot and restart
then go to Windows Movie Maker and press "capture from video device"
hope this helps!
James
Jan 25, 2008 | Panasonic NV-GS15 Mini DV Digital...
what operating system are you using?
Oct 23, 2007 | Panasonic NV-GS15 Mini DV Digital...
Regards,
Sandeep
Panasonic NV-GS15 Mini DV Digital How to capture recorded vedio from Panasonic NV-GS15 Mini DV Digital to Laptop. I have Windows Vista and firewire port.I try to connect it with 4 pin but Movie maker...
Oct 22, 2007 | Panasonic NV-GS15 Mini DV Digital...
Oct 20, 2007 | Panasonic NV-GS15 Mini DV Digital...
Panasonic NV-GS15 Mini DV Digital Camcorder Logo
368 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
