Question about RTO Atwood Water Heater - 6 Gal LP
Water not reaching proper tempreture before cutting out . it is only luke warm
  • 494 Answers
What setting do you have the temp dial set at? The biggest problem I find on RV water heaters because they sit unused for long periods of time, are spider webs in the burner or dirt dauber nests restricting burners and not allowing it to fire properly, causing intermittent flame or flame outage.
Posted on May 15, 2010
Luke warm water
is the water temperature dial turned up? or even functioning?
Jul 28, 2013 | Bosch AquaStar Indoor Natural Gas Tankless...
Worcester 35cdi water and heating luke warm
First thing is to know when it was installed? Check the top of the unit and see if it has in and out marks on it. If it does are they correctly hooked up? Installing them backwards causes this.
Jun 04, 2013 | Water Heaters
Replaced diverter valve on worcester 9.24 combi and still only luke warm water
check your expansion vessel is not flat.if so recharge..simple way to check press in valve on vessel if water comes out or little air recharge..if water still in vessel the diaphram in vessel has split so replace vessel?hot water relys on expansion??
Dec 10, 2012 | Water Heaters
I have abosch 1600 ps aquastar 4.3 gpm indoor when i turn hot water on it all fires up but no hot water comes out only luke warm water why
Water heater is heating water but only luke warm water arrives at faucet.
Open TP valve and confirm that hot water is available.
If water at TP valve is hot, then problem might be plumbing-related, for example crossover.
http://waterheatertimer.org/Crossover.html
Aug 15, 2011 | Bosch 1600PS NG Aquastar 4.3 GPM Indoor...
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
My jAYCO rv only get luke warm water for as few seconds and
Also check that by-pass valve(s) is/are, in proper position at back of tank.
Apr 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Extreme hot water then to consistent luke warm
Possible thermostat problem. Are you experienced enough in that area to do some testing. Have a multimeter? If not experienced, don't try it, too dangerous. Call in a service person.
Mar 07, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water is lukewarm. Not hot! Two year old tank, 220 amp is present. Both sides of relay have 220.
Make sure you have power going to elements from thermostats. check lines going to elements.
Luke warm water is the result of an element gone bad most of the time. One at th etop gone will cause you to get just luke warm water and one at the bottom gone will give you real hot and then cold.
The elements are not to exspensive so if it has two you might as well replace both of them. If you just put 1 new one in it will work the old one till it goes.
Cut power off and cut water off to water heater and drain heater, open hot side on any faucet to help it drain. once drained remove element they have a tube type socket at hardware stores for the removal of it.
Put elements in and fill water heater till all air is out of lines before turning power back on. make sure water is flowing out of all faucets before turning power onto water heater.
The reason being is the elements has to be in water not open air in tank or it will blow new ones.
Dec 16, 2009 | Little Giant Water Heaters
Gas water heater running only cold water
Sounds like it is the pressure diaphram.This is a object that looks like a space ship or ufo undo all the screwss on the flatish side after isolating the water supply revove old diaphram & install a new one
Dec 03, 2009 | Water Heaters
My boiler lights up,stays on for 1 minute then cutts out...
You could check the flame sensor is clean and the connections are tight . check the pressure switch as well. also get the over heat could be shutting off too soon ,
Check the rads for air lock ,
May 11, 2017 | Water Heaters
RTO Atwood Water Heater - 6 Gal LP Logo
119 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
