Finding my sever, I have tiscali broedband this does not appear on the dropdown servers available
    Scholar:
  • 117 Answers
Contact your ISP providor. They should have an installation disk.
Once their software and "drivers" are installed, you should have no problems with connection issues..
~~Jasta~~
Posted on Mar 30, 2008
SOURCE:
Why am I continually receiving error message 0x800CC92 when trying to access emails.
Hi Angela,
The first step is to check your Outlook Express settings, making sure that the POP3 and SMTP servers are as in the screenshots, and that your full user name and password are correct.
Then test your connection by following this procedure.
Click the Start button then RUN type in cmd on (Windows NT/2000/XP) or Command (Windows 95/98/ME). This will open a new command prompt window, with white text on a black screen.
Type in the following exactly as it appears. You will not see what you are entering so take it slowly, and if you make a mistake, start again.
telnet pop.tiscali.co.uk 110 and then click the Enter key on your keyboard. You will then be connected to the email server.
Type in USER followed by your email address e.g. USER [email protected] and then click the Enter key. You will then get a message +OK Please enter your pass, with the PASS command
Type in PASS followed by your password e.g. PASS joblog0370 and click the Enter key. If it is correct, you will get an OK Well done message.
If you can do this, you have connected to the Tiscali server and so the problem lies somewhere with Outlook Express.
If you can't get in this way either, it could be that your password has somehow become corrupted. Try changing it in My Account. Try again.
If this doesn't work, it may be that TCP/IP has somehow become corrupted within Windows. So try reinstalling TCP/IP. To do this
Click Start
Settings
Control Panel
Network connections
Right click your connection and click Properties
Click Internet Protocol (TCP/IP) and then click Uninstall
Then close down your PC and open it up again.
Follow the same steps as above, but instead of clicking Uninstall click Install.
On the screen which appears, click Protocol and then Add
Click Internet Protocol (TCP/IP) and then OK (You may be prompted for your Windows installation disk at this point.
If you run Windows XP, the process is slight different. You need to
Click Start
Run
Then type in Command
In the screen which appears, type in netsh int ip reset c:\resetlog.txt
Oct 24, 2014 | Dell Computers & Internet
SKY Netgear Router cant work on Tiscali BB service
hi,
try user name admin and pwd as sky
Ashish
Mar 23, 2009 | NetGear DG834G Router
Cannot connect to the Server when trying to play Lexulous
Please cheek your server configuration.Or cheek your server capability to take stable this configaration
Mar 19, 2009 | Microsoft Windows XP Home Edition for PC
Internet explorer not working with new siemens router.
Try to check proxy server to IE. Just uncheck proxy server..
Oct 04, 2008 | Computers & Internet
Error Code
Accidentally ended the session ?
Here's what you need to do - INSIST for assistance with the tech from tiscali with the windows mail client for configuration.
Don't mention the error code to them cause they don't do research.
15mins tops to do it.
As I said, there are some email server configuration that are off-limits to non-tiscali techs & non-subscribers.
Aug 25, 2008 | Computers & Internet
Outlook express problems
well the problem is complicated just go through the sollution given below
Troubleshooting Outlook Express Error 0x800ccc90
Symptom: There was a problem logging onto your mail server.
  • Your Password was rejected. Account: 'pop.tiscali.co.uk', Server: 'pop.tiscali.co.uk', Protocol: POP3, Server Response: '-ERR invalid user or password', Port: 110, Secure(SSL): No, Server Error: 0x800CCC90,
  • Error Number: 0x800CCC92
Solution The first step is to check your Outlook Express settings, making sure that the POP3 and SMTP servers are as in the screenshots, and that your full user name and password are correct.
  • Click the Start button then RUN type in cmd on (Windows NT/2000/XP) or Command (Windows 95/98/ME). This will open a new command prompt window, with white text on a black screen.
  • Type in the following exactly as it appears. You will not see what you are entering so take it slowly, and if you make a mistake, start again.
  • Type in USER followed by your email address e.g. USER [email protected] and then click the Enter key. You will then get a message +OK Please enter your pass, with the PASS command
  • Type in PASS followed by your password e.g. PASS joblog0370 and click the Enter key. If it is correct, you will get an OK Well done message.
  • If you can do this, you have connected to the Tiscali server and so the problem lies somewhere with Outlook Express.
  • Click Start
  • Settings
  • Control Panel
  • Network connections
  • Right click your connection and click Properties
  • Click Internet Protocol (TCP/IP) and then click Uninstall
  • Follow the same steps as above, but instead of clicking Uninstall click Install.
  • On the screen which appears, click Protocol and then Add
  • Click Internet Protocol (TCP/IP) and then OK (You may be prompted for your Windows installation disk at this point.
  • Click Start
  • Run
  • Then type in Command
  • In the screen which appears, type in netsh int ip reset c:\resetlog.txt
If you're still having problems, it could be that Outlook Express is itself corrupt. Microsoft's Instructions on how to delete it and reinstall it, along with making a backup of your address books etc, are located here for Windows 95, 98, and ME and here for Windows 2000.
Apr 28, 2008 | Microsoft Office Outlook 2003 for PC
Only partial internet access
Try a public DNS server, like:
  • 205.234.170.215
  • 205.234.170.217
  • There are many more, if you just want to 'Google' for them, IE; "Public Name Servers"
    Let me know if there are any changes..
    Dec 17, 2007 | D-Link DI-604 - 4-Port Broadband Router [...
    Only partial internet i assume refers to the fact that you can get on line but on certain peer to peer sites it won't be allowed. This is because you need to open the relevant port in the virtual server option or similair. Changing the dns back to the original is advised, and selecting obtain ip address automatically. also if this is not the case regarding open ports check that your browser settings are'nt too low.
    Feb 24, 2007 | 2wire (1000-400108-001) Router
    Can't get connected to the internet
    As usual technical dept in all ISP's are useless and unhelpfull especially if it's not a supplied modem. (p.s. the ip address they are going on about is probably your routers address and not the ISP's address) Anyway; you will have to get into your routers settings page, as you may have to set it up manually as I had to for a friend who is also with Tiscali as the router cannot obtain an ip address automatically from Tiscali. Make sure you are connected to the router via the RJ45 network cable (Normally Supplied)and then Normally you type in something similair to 192.168.2.1 or 192.168.1.1(check your manual for this), in your internet browser eg internet explorer. Then go through the settings using the routers settings Wizard and manually input the following. Virtual Circuit Identifier - VCI38 Virtual Path Finder- VPI0 Encapsulation Mode VCMux Authentication Type CHAP Protocol RFC 2364:PPP over ATM (PPPoA) Modulation Type G.DMT or Auto Primary DNS Server 212.74.112.66 Secondary DNS Server 212.74.112.67 Save settings. Try accessing internet while you are still wired, if you can you know the ISP's settings are ok and you already know each PC can access the router, you should be away.
    Nov 03, 2006 | Trendware TRENDnet TEW-435BRM 802.11g...
    Open Questions:
    Computers & Internet Logo
    20 people viewed this question
    Ekse
    Alun Cox
