Question about HP Pavilion a1610n PC Desktop
Wont start up
No output signal blue light on no amber light running sound
    Scholar:
  • 47 Answers
Check physical connections first, check monitor cable if securely plugged in and then check power light of monitor. If power light on monitor is amber or yellow it means that monitor is not getting a signal from cpu/ tower. Try to do a power drain on the computer, remove power cable at the back of the computer and then press and hold the power button for 10 secs, after that plug in power cable again and restart the computer.Check if there is any connection if not then try to use another monitor, a known good one. If you get a video from another monitor it means monitor is already defective.
Posted on May 15, 2010
Won't stay powered on. Clicks off within few seconds. Amber power light stays on.
Could be speaker wires shorted together, but it is more likely that there is a fault in the output transistors or the power supply. The front right and left normally produce the most sound output and those transistors run hotter than the other channels. If you have the equipment and know how to check the output transistors, I would start there.
May 05, 2015 | NAD T747
Monitor wont power up, indicator light flashes between amber and blue...
maybe your computers video card is bad and it is not receiving a signal
Sep 22, 2014 | Acer Computers & Internet
Ihave no amber power light only a flashing green
sounds to me like it isn't receiving a signal and stuck in power saving mode, i would recommend trying another computer that you know is outputting a signal and go from there. if that doesn't work then my guess is its broken.
Feb 03, 2010 | Dell Computers & Internet
Solid Amber light when starting the Inspiron 530 . Every time i start the Dell inspiron 530, the solid amber light comes on and it dont start. As per Dell user manual i have tried everything but of no use....
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
Jul 30, 2009 | Dell Inspiron 530 Desktop Computer
1721 Inspiron shows flashing amber, three times, then blue.
The cells in the battery are starting to go bad which is why the light is blinking the way it is.
Once you get a new battery put in there the light will stay blue instead of flashing amber.
Jul 04, 2009 | Dell Latitude D600 Notebook
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Jl amp
The amber is the low impedance indicator and can mean that the impedance of the load is too low or there is an internal fault (shorted output transistors).
The blue LED indicates that the voltage is too low. This can be due to a bad connection or low battery voltage.You need to measure the DC voltage across the B+ and ground terminals of the amp to confirm that they're at or above 12v.
Let me know if you have any other questions.
Aug 11, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Powering up problems.
Try using another monitor that you know works. Then try another video card. The fans are running because the computer is running ---but the monitor is not. Green to Amber means monitor is not on.
A lot can go wrong with loose wires that shouldn't be loose.
But I would try this first.
Jul 22, 2008 | E-Machines eMachines Desktop PC
HP Pavilion a1610n PC Desktop Logo
271 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
