Question about Hotpoint TDC32 Electric Dryer
Tdc 32 dryer not getting hot anymore - Hotpoint TDC32 Electric Dryer
  • pgfr Jan 02, 2009
    it spins and seems to work fully but there is no hot air!! hepl please!
Thermostats.... 2 of... (cut out & one shot)
Posted on Jun 06, 2008
SOURCE:
Dryer part of the washer/dryer is not getting hot anymore
hay Darren , If you have an electric dryer it may be a element or fuse , if its gas it may be bad coil or fuse . The washing machine does not heat the water rather bring it in from the boiler therefor its unrelated to the dryer .good luck APPLIANCES R EN
Mar 01, 2013 | Washing Machines
I have a hotpoint aquarius tdc 30 conderser dryer. It gets hot and rotates the clothes, but they aren't drying. what's wrong?
Hi, Well if it is getting hot but not drying the clothes than most likely you have an airflow problem. Take off the vent hose on the back of the dryer. It will be plugged up with lint either inside that vent on the dryer or the hose will be plugged somewhere. If you clean this or just plain replace the old hose this will take care of the problem. Good Luck. feed back is appreciated.
Jan 12, 2011 | Hotpoint Dryers
Hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Thnks.
Nov 15, 2009 | Hotpoint TDC32 Electric Dryer
My maytag clothes dryer does not get hot anymore.
is this an electric dryer? if I had the model number, around the hole where you put the clothes in, I could tell you better if this is something you can do yourself. it may not be the heater, it could be a thermal fuse cutout giving you trouble. let me know.
Oct 13, 2009 | Maytag Dryers
Dryer wont turn inside but gets hot and turns on
If it's not turning at all, the belt is probably broken. If it turns a little and then stops, the belt is slipping. In either case, the belt needs to be replaced.
May 11, 2009 | Dryers
My electric Kenmore Dryer (65291) does not get hot anymore
does it still start? if so you may need a ne heat element?
Feb 28, 2009 | Kenmore Dryers
TDC 30 Dryer starts but after 5 mins "clicks and stops"
its probably the relay (brown plastic box at the front under lid)! Symptoms are usually.... the dryer will go for a few minutes then shut down.... then you have to wait for it to start
May 23, 2008 | Hotpoint TDC32 Electric Dryer
Changing the thermostats on a TDC 32 P
your stats are at the back of the dryer take the metal cover off at the back u should see your stats straight away the cover should be the one that sticks out more than your back casing m8
Aug 27, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
259 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Archie Ferrarini
Archie Ferrarini
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
