Question about Hotpoint RLM30 Refrigerator
What number is high on the fridge - Hotpoint RLM30 Refrigerator
  • 308 Answers
The higher the number, the colder the temperature. Hope this helps
Posted on May 15, 2010
Maytag frig model no mfi2569vem2 control panel not lit up and not coolong or freezing. light inside is on but dont here the motor running. we did have a power outage when issue occured
Sounds like the power outage took out your high voltage control board. This control board is located on the back of the fridge. Roll the fridge out of its position so you can get behind it. Once you have pulled out the fridge you will need to UNPLUG it. There will be a couple 1/4" screws securing the metal cover to the back left side of the fridge (if you are facing the back of it). Remove these screws to find another plastic cover which will need to be removed. This control board controls the fans and the compressor. You can take the control board out and look for a burn mark or a blown soldered fuse. According to your model number the control board part number is W10310240.
Nov 02, 2016 | Maytag Refrigerators
Freezers high tempeture light is on and freezer is not getting cold
Door left open usually starts a defrost failure, the evaporator gets blocked with frost and the fan motor can't circulate cold air into the fridge section- while the freezer fan is running, put your hand in front of the slots where the cold air should be blowing in the fridge section- if you don't feel air flow, you have a blockage. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Kenmore Refrigerators
Reverse doors freezer hinge
What is the model number of your unit?
Nov 28, 2012 | Refrigerators
I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
Apr 18, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Why is our fridge frozen all the time?
Hi!!
The evaporator fan (little fan in freezer), is the one that blows cool air to the fridge. If your evaporator is freezing up, it could be due to the thermostat set too high, and the fridge control set too low. Set freezer temp. one number lower, wait 24 hrs and check, if evaporator still freezes, lower it one more setting. If temp in fridge is OK. leave it alone, or adjust accordingly.
Let me know how it worked out.
Good Luck!!
Mar 28, 2010 | GE GSS25JFM Side by Side Refrigerator
My belling fridge has a 1 to 7 temp setting , which is low and which high temp ?
normally the smaller number is the warmer setting and the higher number is the colder
Jun 26, 2009 | Refrigerators
How To Set The Temperature
5 is the coldest.
1 is the warmer setting.
Normal setting would be halfway.
Apr 23, 2009 | Refrigerators
Maytag ice20
When replaceing the highvoltage control board be careful to not handle it too much as nano voltages can burn it. Unplug before repair. Simply hook it up the way you unhooked it very easy and in the left back of the fridge. Now that it's installed plug fridge in and push back to wall. Look at model tag and write down your code something like 0304 most likely. Go to digital control hold down door alarm and freezer - minus button for 3sec. then let off door alarm now you should see PE flashing the fridge wants personality code (the one you have wrote down). Let off minus now it should show 0000 now push minus once more a decimal should show up 0.000 the decimal indicates what number your about to change. Move the decimal with freezer plus button and lower or higher number setting with fridge side buttons.Once your done hold down freezer minus till the numbers are flashing then open any door and close. Now the fridge should be working properly.Hope I helped
Dec 12, 2007 | Maytag MFD2560HES Bottom Freezer French...
Hotpoint RLM30 Refrigerator Logo
59 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
