Question about RCA D52W19 52" Rear Projection Television
It wont turn on but some times when the moons aline it will is there a way i chould hard wire it to stay or and i just unpluge it
  • 1,557 Answers
You can bypass the main switch if its a push button that clicks if its a pulsh switch then no let me know what type it is and ill send you the diagram to bypass wire it
oh and you need to be able to solder
Posted on May 15, 2010
6 light 2 spot light low volt moon Raysystem trouble making a connection on 4They clip onto line fine wont stay lit Is there a way to clip the lights to the low voltage line better so they stay lit.
Not sure what you are needing here but if its a poor connection, try soldering the wiring or using correct spade and socket connectors.
May 25, 2015 | Cars & Trucks
How do I remove a steering wheel on a 1967 nova
its not really hard ,remove horn cover and horn assembly you'll see a wire and unplug it and remove 3 screws holding grounding ring, now remove nut holding wheel on , you want to mark it in a way you will know where to aline it when putting it back on ,now use a steering wheel puller with extracting bolts and tighten center bolt to remove wheel that's it.
Mar 01, 2015 | Cars & Trucks
My 2005 Artic Cat ATV battery wont stay charged when lights are on
maybe your alternator dont chage good.check this whit a voltmeter,on your batterie when motor is running.you chould read , some 14.50 volts.when read 12 or 13 is to low
when read 14.80 or 14.90 volts is too high
Jul 07, 2013 | Cars & Trucks
I install a timing chain on a intrepid 2.7 and it backfires what did I do wrong
that engine is an interference engine and you turned the motor with out turning the cam with the chain removed and possibly bent some valves or the timing is off 180 degrees
Jun 03, 2013 | 2001 Dodge Intrepid
Replacing camshaft position sensor, Sable 2003,Ohv
usually if the magnet in the sensor comes out it destroys the cam position shaft,(it should have a half moon shape when u remove the sensor from the cam pos/oil pump drive. if the half moon is damaged or missing u must replace the cam pos/oil pump drive, and yes it is timed with the engine. wot i have done is try to locate where the half moon was on the drive it usually leave a trace of where it was. now index where the half moon is at remove hold down bolt and remove the driver assy. install the new drive, clock the half moon shaft to match the one u just removed once u get the half moon shaft where u want it and the oil pump rod alines and the whole housing is down install the hold down clamp. now to get rid if that check engine lite youll have to plug a scanner in and look at the live data adjust the cam position till u have plus or minus 2 degrees
Mar 18, 2010 | 2003 Mercury Sable
Fuel gauge stays above the full mark when the
its not a short in the wireing its a very bad earth check for bad earths
Oct 30, 2009 | Chevrolet Impala Cars & Trucks
1998 bmw 528i severe misfire
If you've never replaced the timing belt or chain,That would be my first thing I'd check is the Timing belt or chai, just aline the timing marks on crankshaft and then look at the position on the distributor to see if it's pointed in the #1 firing position .
May 02, 2009 | 2008 BMW 528i Sedan
The moon roof on my 1996 saturn sl2 not working
I have the same car and had the same problem, when you pull down the head liner you will find the motor for the moon roof. i disconnected the motor so that i could analyze it. i found that the gears in the moon roof motor are made of plastic and most of the gear teeth were chewed off. i disconnected the wireing harness from the motor and left it unplugged, i then pushed the moon roof back into position and tightened the screws to the moon roof. That is the way i left it for the past 2 years, because i was not about to spend the money t fix the motor.
Mar 20, 2009 | 1996 Saturn SL
Laptop wont turn on this a weird one!!! Please help!
Its very unfortunate but you've short circuit your power supply and before it get worse, please check it out with your vendor asap. It might cause severe problems.
I'll not suggest you to get your hands on to resolve this.
Hope this helps and you get your laptop up.
Thanks.
Mar 06, 2009 | Computers & Internet
RCA D52W19 52" Rear Projection Television Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
