Question about Philips Magnavox 27MS343S 27" TV
Unit is resetting always
My computer keep on resetting,can u help me this problem>>????
  • 1,557 Answers
The unit has a memory back up unit normally a batterty but in this model its a capacitor the faulty cap needs to be found and replaced send it in for a service shouldnt cost much
Posted on May 15, 2010
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Tip
Providing Care to your computer
<p><span>If you are using computer there are many reasons why you should take care of your <span>computer,</span> and you would probably like to keep running as long as possible. </span><br /> <p><span>Hardware & Software and other are several things you do to have a longer life of your PC. There is always a good thing to clean your <span>computer</span>. A clean hardware <span>will</span> run faster and last longer. </span><br /> <p><span>Here are some options for cleaning and maintenance of the<b> </b></span><span>operating system on your Computer. </span><br /> <p><span>1. Disk Defragmenter run at least once a month. Select this by using this Windows path (Start &gt;all Program&gt;Accessories&gt;System Tools&gt;Disk Defragmenter). The defragmenter will help ensure your Disk files are in the proper place on the <span>computer</span> and will improve the overall speed of your browser. </span><br /> <p><span>2. Clean up old files. Disk Cleanup will help you to remove unnecessary files from temporary folder and system folder which are remain after install/uninstall software frequently. Select this by using this Windows path (Start &gt;all Program&gt;Accessories&gt;System Tools &gt;Disk Cleanup). </span><br /> <p><span>3. Scan for viruses. Viruses are also may cause your <span>computer</span> to slowdown and not work in proper way. You should always install a good antivirus and keep it update.</span><br /> <p><span>Here are some ways you can easily keep your hardware.</span><br /> <p><span>1. Each time a while, you should open it and clean it out. Computers are notorious for accumulating dust. For cleaning dust you can use a vacuum cleaner or a can of dust remover can be done.</span><br /> <p><span>2. Keep your PC cool. You should always make sure that your <span>computer will</span> keep in a ventilated area. This will help prevent life of your hardware to be extended. </span><br /> <p><span>3. Always purchase high-quality hardware.</span><br /> <p><span>By following some <span>tips</span> you can be sure you <span>computer</span> to reduce future.</span><br />
on Dec 24, 2010 | Computers & Internet
How do I reset softwear on my BlackBerry 8520?
try....options------->security options--------->general settings-------->press the bb button and click wipe handheld--------->tick off third party applications if you want to loose them all------->click continue and type blackberry and hit the enter button and the blackberry will now reset and reach factor state. If this doesn't work for you, contact your cell carrier and they will be able to assist you. Depending on how long you had the phone, you should be able to get it replaced under warranty.
Jul 29, 2014 | PDA Giant RIM BlackBerry8520 Unlocked...
How to restore contacts on iphone
Did you at least make a backup using itunes(for iphone), cus thats the only way you can restore contacts, same for your computer using windows backup, cus this is also important for your data, if you didn't, you are screwed and there is no hope for recovery. Tip: always make backups before you do something.
Jul 12, 2014 | Samsung Galaxy Ace GT-S5830
Samsug gt-c3222 master reset code
samsung gt c3222 mobile reset *2767*3855#
Oct 12, 2011 | Samsung Star GT-S5233 Cell Phone
I have Hotmail . When I try to access any of the drop down menus they are greyed out on this computer -Sony Vaio - but not on my Samsung Netbook . For example when I try to move emails into a folder I am...
Hi
You don't say whether this has suddenly and recently occurred or whether it was always this was on the Vaio computer.
This seem like Browser Settings issue on the Vaio that has set the security controlling the Browser. It could also be a Browser infection. So - take a twin track approach.
First improve your Anti Malware / Anti Spyware security.
The following 2 have an excellent reputation:
Malware Bytes (www.malwarebytes.com)
Super Antispyware (www.superantispyware.com)
Download and install these and then scan and purge any infection the find.
If infection does turn out to be cause of the problem, also consider a very effective, free, a Resource Light (does not slow your system down) alternative Anti Virus:
Avast! Home Edition (www.avast.com)
Consider downloading the latest version of Avast! Home Edition, disabling your current Anti Virus Program, installing Avast, restarting the PC and testing avast! (if you keep it, uninstall all components of the previous Anti Virus in Add or Remove Programs:
Start Control Panel > Category View > Uninstall a Program > select previous antivirus > Remove all components > Restart Computer.
If this does not fix the problem, either:
1) Manually initiate an update of Internet Explorer (even if you already have IE9), here:
http://windows.microsoft.com/en-GB/internet-explorer/downloads/ie-9/worldwide-languages
2) Download, install and use Google Chrome as your Default Web Browser.
3) Download, install and use Firefox as your Default Web Browser.
4) Download, install and use Safari as your Default Web Browser.
5) Download, install and use any other Browser (such as Opera) as your Default Web Browser.
If you prefer IE, try System Restore to a time when the Browser worked normally (if applicable):
Start > All Programs > Accessories > System Tools > System Restore > Restore My Computer to an earlier time > select a date on the calendar and an event in the schedule that precede the Browser Fault > Restore > Restart computer > test Browser.
Resetting the Browser manually is option you should consider if you are very confident, very precise, very patient, very methodical, highly organized and willing to test the bewildering array of settings options. The Setting Options to Reset the Browser are many and varied and some settings changes could seriously affect the integrity of your system. so it is important you remain, at all times, able to reverse each settings change you try:
Launch Browser > Tools > Internet Options > Security > Reset All Zones to Default Level > Apply > OK > Restart computer > Launch Browser > Test E-Mail Page > if solved, close > if not, Launch Browser > Tools > Internet Options > Advanced > (Reset Internet Explorer Settings) Reset - take heed of warnings > Apply > OK > Restart computer > Test E-Mail Page.
The final option is to uninstall > restart > reinstall the IE Component of Vista, sometimes requiring the Vista installation DVD to be in the laptops DVD Drive:
Start > Default Programs > Set program access and computer defaults > Continue > Custom (click Custom Drop Down Menu) > Custom (select alternative configuration) > OK
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This gives Answerers, like me, the opportunity to better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Sep 04, 2011 | Facebook Computers & Internet
My HTC HD 7 phone keeps turning off it goes to the white screen with green HTC then shuts off and keeps doing the same thing over and sometimes when i try to use it and i tap the screen then it shuts off...
I finally had to have them replace the unit. If doing a factory reset does not help, then I would have them replace it. Mine started rebooting infrequently, but then started doing it more often. They didn't waist any time getting my replacement out.
Please make sure you back up all your contacts/email before proceeding. I use Google on my phone through the Outlook option. Google/Outlook syncs all my mail, contacts, and calendar.
RESET: Software: SETTINGS > ABOUT > RESET YOUR PHONE
Hardware: 1) Turn off phone 2) While holding down both the Up/Down Volume buttons, turn unit on 3) Keep holding down the volume buttons until white screen appears 4) Press the Down Volume button to reset to factory defaults. 5) Restart phone
Jun 28, 2011 | HTC HD7 Cell Phone
Forgot password on 680 nuvi and were out of town
Try giving the unit a hard reset, this is done by turning it off > place your thumb in the bottom right corner of the screen > turn the unit on keeping your thumb in the bottom right corner > let the unit power up unitll the message " Are you sure you want to erase all user data appears" > select yes.
This may fix your problem but you will lose all your favorite and info so only o this as a last resort.
Hope this helps!
Dec 10, 2010 | Garmin Nuvi 680 GPS Receiver
I have a windows vista 5310 laptop keeps freezing sometimes the screen goes white and it takes about 5 minutes to open a web page i reset it to factory setting but it has not done no good pleace help me
The problem is in the configuration of your Windows program. Try booting in safe mode.
If it works better, then there is a driver affecting the performance of your computer.
Click on Start > Run> type MSCONFIG > select STARTUP and mark or unmark the drivers you do not need.
Aug 26, 2009 | Microsoft Windows? Vista Home Basic...
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Philips Magnavox 27MS343S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
