Question about Epson Stylus photo C87 InkJet Printer
How do you clean print head?
How do you clean print head of the Epson Stylus C87plus printer? Some line not clear even though ink levels are OK.
    Sergeant:
    Champion:
  • 246 Answers
Open the cover, while your printer is still ON. Take the ink out from the printer, off the power for the printer. If you are able to see a plastic horizontal material, wipe that material very gently using a soft tissue. Might you will need to wipe it twice, replace the same ink and on your printer. Hope this works and try to dust out any dirt you can find on the rolller. Thanks
Posted on May 15, 2010
  • 56 Answers
Have try to clean by software, HP software driver bundled a maintenance software to cleaning, if by software didn't work try this :
Remove print cartridge from printer. and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink.
put your cartridge back to the printer then do clean with software again to make sure. see the result
Note :
Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets; if you get isopropyl alcohol on the gaskets, it could dry them out.
    President:
  • 1,768 Answers
1. One method is with Q tips and denatured alcohol .
2. Some printer heads just need to be replaced. They are designed to fail after so many prints.
I have an Epson RX680 the black and yellow ink are not printing after trying several print head cleanings and even replacing the cartridges (even though they were better then half full)
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 15, 2012 | Epson Stylus Photo RX680 Printer
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus C86 - prints faint magenta even though ink levels are in a normal printing range - does not print anything or a barely seen magenta line during nozzle check and heading cleaning
You probably have a slowly worsening clog building up in the Magenta nozzles. It's also possible that your ink is reaching its end of life which, given the age of the C86 is entirely possible, especially if you are refilling or using a CIS sytem with your printer.
If it's a clog issue you can try soaking the parking pad with a mildly ammoniated cleaning solution (original Ammonia windex is good for this) or even distilled water. Leaving this with the printhead parked above it allows the solution to wick up into the nozzles and break down any clogs in the printhead.
If the problem is ink age though you will probably want to carry out the solution above AND replace your ink with a fresh solution. A CIS will need a thorough flush to remove any algae and cloggation residues before you use it again or you will just reintroduce the problem.
Hope that helps.
Martin
May 27, 2009 | Epson Stylus C86 InkJet Printer
I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Jan 27, 2009 | Epson Stylus 880 InkJet Color Printer
Epson Stylus CX6400 All-In-One InkJet
try doing 4 head cleans and then leave the printer powered up over night. Don't print or anything else after the head cleans until the morning then do one more head clean (this soaks the print head in ink overnight and then the final head clean should clear any obstruction. If the printer still refuses to print in colour, you could try replacing the cartridges anyway as they can be faulty. The only problem is thaty sometimes it's cheaper to buy a new priner. (how silly is that!) By the way, are you using compats or epson original ink carts?
Nov 03, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Blurred and fuzzy print quality
i think you use a compatible ink... use genuine ink for epson ok...
Jan 04, 2008 | Epson Stylus Color 740 InkJet Printer
Epson Stylus photo C87 InkJet Printer Logo
241 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
