Question about Bike Extreme Lite Youth Shoulder Pad
Seat post size for 98 dyno nitro 24 bmx bicycle
    Scholar:
  • 102 Answers
Start with the seatpost itself, most of them have the size stamped on them below the minimum insertion hash marks. It is almost always measured in metric, millimeters usually, like: 25.4mm (which is 1 inch).
If the size is not stamped on the seatpost (it was most likely cut off or scratched beyond recognition) then you can measure the diameter in inches, multiply by 2.54 to get the metric measurement in centimeters, multiply that by .10 to get millimeters and then call your local bike shop for a replacement.
Dyno bikes are made by GT, it was there "budget" brand of BMX bikes, so you can google GT bikes and find a local dealer or you may be able to order direct from GT. From the year of your model, most likely the bike is steel (cro-moly or hi-ten) and these bikes normally have a smaller seatpost size, like the above mentioned 25.4mm. Aluminum frames usually have larger diameter tubes with thinner wall thickness and will require a larger diameter seatpost.
Posted on Apr 29, 2014
go to bmxmuseum .com fro assistance
Apr 18, 2014 | Dyno Old School Gt Number Plate Old...
Gt dyno serial # G6A02189
try gtbicycles.com or bmxmusuem.com
Apr 06, 2013 | Dyno Old School Gt Number Plate Old...
How do i raise the seat on a dynacraft tony hawk bmx bike
loosen seat post clamp with correct size allen. once its loose push down and twist the seat untill its where you want it then tighten the seat post clamp
May 17, 2011 | Dynacraft Tony Hawk Homer Boy's 20-Inch...
I cant seem to lift my mongoos bmx saddle. How do I do I?
Below the seat is a bracket on the neck of frame. There should be a lever that you pull and turn counter clockwise to loosen. Then you can raise and lower seat.
Jan 03, 2011 | Mongoose Bmx Bicycle Seat/saddle Part 269
Bmx bike has no seat post how do i put a seat on ?
You will have to buy a seatpost, either pivotal or railed depending on your seat. A railed seat has two rails underneath it, and needs a railed seatpost. A pivotal seat has a prism with teeth cut into it on the bottom, and requires a pivotal seatpost.
Oct 18, 2010 | Dmm Animal Stump Pivotal Bmx Bike Seat...
I have just redone my 2007 dyno bmx bike and I was wondering if I could swap parts with other bike parts
Some parts, you can. It depends on what parts and what bikes, and noone really has an all-inclusive list that I've ever found.
Best thing to do is measure up the part you want to replace, then check for parts that have the same important dimensions.
Jul 21, 2010 | Dyno Black Bmx Bicycle Handlebars Bike...
Dyno mountain bike with a braking noise
If it is when you pedal, check the bottom bracket (where the cranks are attached) The bearings might need changing which would cause the noise.
Do the handlebars rock back and forward, if so, check and tightent the headset, check the bearings inside if they are dry or broken, replace and re-grease.
Jul 08, 2010 | Dyno Old School Gt Number Plate Old...
Raising seat on x games bmx bike
A good bike shop will sell you a new seat post. You should take the bike with you as the posts come in different diameters. They can also cut it to the proper length for you if you don't have the tools.
Jun 13, 2009 | Cycling
Hot to fix a bike seat on a bmx
usually a 14mm wrench loosen the nut remove old seat put new seat on post tighten bolts
Apr 09, 2009 | Dmm Animal Stump Pivotal Bmx Bike Seat...
Bike Extreme Lite Youth Shoulder Pad Logo
156 people viewed this question
Top Bike Sport & Outdoor - Others Experts
Are you a Bike Sport and Outdoor - Other Expert? Answer questions, earn points and help others
