Question about Garden
Rover i5000 mower wont start
Pulling start cord, only gets a splutter and a couple of turns before quitting, engine not engaging
  • 211 Answers
SOURCE: my lawn mower will not turn off
Hi
From under the flyweel comes a wire(probably black).check it.It is connected with the off position of the trotle.
best regards savumihai71
Posted on Dec 22, 2008
  • 12 Answers
SOURCE: Toro Electric Start Mower Barely Turns Over
this is easy to point out the problem. if it is still under warranty get warranty replacement of the starter is not you might be better off just buying a new mower might be easier and cheaper because if your not still under warranty with it it will cost you quite a bit of money if you can't replace it yourself it will cost you the amount of the new starter and it will cost you the amount that the shop's labor fee which can vary a lot depending on where you take it.
Posted on Jun 15, 2009
rburroak
  • 14 Answers
SOURCE: lawn mower needs new cord to crank the engine. how do i replace the cord
Remove the 3 bolts located on the flywheel housing.(should be 7/16") one in front and two on side.
Posted on Jun 19, 2009
  • 11 Answers
SOURCE: Craftsman 7.0 HP Briggs & Stratton mower stalling
Check the muffler, if the muffler is clogged it could cause overheating of the engine, and could keep the engine from getting the necessary fuel-gas mixture.
Posted on Aug 12, 2009
woobie dog
  • 1273 Answers
SOURCE: once engaged and start mowing, you can mow for
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Posted on Aug 15, 2009
After power outage, we had to pull the release cord to disengage the opener. Now that the power is back on, how do you re-engage the door with the unit so it will function?
These usually attach to each other with a slide lock. What you can do is command the door to stop within a few inches of the cord release. Then lift the door without pulling the cord until the door engages to the lift. It may take a little pressure and repeated cycles to get it to engage. Be sure that the cord release is not stuck. Cycle it a few times by pulling on the cord and watch the lock mechanism to make sure it is operating correctly. Your door is adjusted so that the opener senses a little pressure on the door to make sure it is completely closed. So if you just try to open and close the traveler may not quite make it to the disconnect. That is why you need to engage them manually. I hope this helps you. This is a real common problem with garage door openers.
Nov 01, 2017 | Building Materials
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
I have a Troy Bilt Weedeater Model # TB415CS Here is the problem my wife decided to use this unit while I was at work one day and broke it. When I go throught the start up routine and go to pull the start...
If the rope recoils back into the starter, at least the starter spring is not broken...but...if you can break the unit down to where you can get a good look at it, you may find that the ratchets on the starter pulley are not engaging with the pawls on the flywheel...The pawls are spring loaded so they engage and then drop out of the way when starting, See if you can break the machine down to that point and post back,
Aug 06, 2010 | Troy Garden
My diesel vw transporter misfires/splutters on
I have just had my T4 2.4 cambelt and water pump done but the van does not run right unless the choke is out any ideas?
Many thanks
Mark
Mar 31, 2010 | 1999 Volkswagen Euro
I have a 2004 polaris sportsman atv. I went out to start it and with not being turned over for a couple of month the battery would not fire the rig up. so when I pulled on the start cord it just recoiled...
powered up the battery, still wouldn't kick over the machine. then tried for the heck of it to pull the start cord and it wasn't pulling the engine crank just recoiled for three pulls then suddenlly it caught and started the machine on the first pull. percervierence prevails!!! Now my life is whole again.
Jan 29, 2010 | Polaris ATV
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Toro GT5 lawnmower - the pull cord (to start the engine) only comes out about 3 inches - I'm afraid to pull to hard for fear of breaking the line.
First - remove spark plug and squirt 3mls of engine oil in there - replace spark plug and leave overnight.
Try pulling that start handle !
Two things may happen - it snaps or - it turns over.
If it turns over - prime fuel and start in choke setting.
If the cord snaps - undo the pull start block - and take it to a lawnmower spares depot, and buy some more cord. It's quite cheap.
Get the length right so you don't have too much.
Next - the engine is probably seized - so needs freeing up. You may be able to do this with the new cord, Otherwise - take the head off the cylinder and tap the piston down with a wooden drift while turning the crank.
Use a non-setting gasket sealant like hematite red to re-use the old gasket. Lawnmowers are quite resilient.
Jun 29, 2009 | Toro Lawn Mower With Toro Power Tools
Engine splutters and dies when i try to turn it on
sounds like either the cam or crank sensor is going bad, test both and get back to me
Apr 13, 2009 | 2000 Volvo S40
Garden Logo
265 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
