Question about Cameras
Just bought a new Lumix DMC-FH22. Inserted an SD
Just bought a new Lumix DMC-FH22. Inserted an SD card; camera is still saving pics to built inh memory. Copy function is not available. What am I not doing right?
  • 12,061 Answers
Http://www.panasonic.com.au/products/details.cfm?objectID=5485
Please go to this above site and download your user manual, and drivers, inside the manual the operation you describe is addressed inside. Usually though, the SD card is only used when the Camera's memory is "Full" Or there may be a function to transfer to SD card, but usually one simply need an increase in memory, and to get the photos one uses the software and downloads to a PC, or where ever and it doesn't matter where it is stored.
Posted on May 15, 2010
What is the max sd card size for a panasonic lumix dmc-fh22
SD cards max out at 2GB. However you may also use SDHC cards, which max out at 32GB, or 64GB SDXC cards.
Dec 04, 2012 | Panasonic Lumix DMC-FH22 / DMC-FS33...
Built in memory full and I have only taken one photo.
Have you inserted an SD card as the built in memory on the camera is only 12.7 Mb big so an SD card should be inserted. Hope this helps.
Jul 04, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
How to download the internal memory of my Panasonic Lumix DMC T27 to the memory card
Go to previous view pics in internal memory, select the pic and then "move"at SD Card (work in some models).
Other possibilitie, take off the SD card and connected the camera at pc, open explorer software and copy/paste the pics from camera at one folder in the pc. Verify that the pics are saved and secure, so, delete the files in the internal memory. Turn off and unplugged the camera.
Then, take on SD card inside camera and reverse procedure, copy/paste from pc to SD card (like a external device).
Hope helps.
May 25, 2011 | Cameras
The panasonic DMC-LS 70 is not regognising my SD card and keep giving me "the picture will be recorded in the built in memory"
I don't have a Lumix but most phones have a setting of where you want your photos to be stored. If you can get to your settings menu and then look up your storage options, maek sure you have the SD card selected as where you want the photos to be saved.
Feb 07, 2011 | Panasonic Lumix DMC-LS70 Digital Camera
When pictures are taken they are being stored on the camera. They do not go to the SD card.
You need to get rid of the pictures in the internal memory. If you want to save any of them, go into the menu and find "copy". You will find the option to copy them to a memory card. Then, with no card in the camera, go into the menu and find "format"....follow the on-screen instructions to erase the internal memory. Then your card should work properly.
Dec 28, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
DMC-FX55 memory problem
Press menu/set...playback menu....select "copy" Make the choice to copy the internal memory to the card and select "yes".
Jun 30, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Video compatiablity problems
Do not try to use the same card from another camera. You run the risk of losing all your pics and possibly corrupting the card and the camera. Download any pics from the card to the computer using a separate card reader if necessary. Then, if you want to use the card in your new camera, format it in the camera first.
Jun 24, 2010 | Cameras
Built -in memory full
First, determine if any of the pics on the internal memory are important...if so, download them first. Then, with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, if the memory card contains any important pics, download them using a card reader if necessary. Then, insert the card into the camera and do the "format" thing again. Now, you should be ok.
Mar 03, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
After forgetting to put the sd back into the camera i had to take some pictures on the built-in memory. how do i get them onto my computer?
To get the pictures from your camera to your computer. Turn the camera off, remove the sd card, then plug the camera into the computer using the usb cord and transfer the pics as if you had a sd card inserted in the camera.
Dec 06, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix DMC TZ3
Use your USB cable or a Card Reader. Read your manual to insert Date on pictures. Note date will show on pic and cannot be removed.
Best idea is to downloand you pics asap and change each pic file name to embed date taken in filename, not on the pic itself.
I recomment the San Disk MobileMate SD+ miniature Card Reader for SD and MicroSD card reading. Just a little larger than a Flash Thumb Drive. Saves lugging around a USB camera cable and saves your camera power otherwise needed to power a download via a USB cable. About $15 at RadioShack, Staples, etc retail stores selling cameras.
Jan 07, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Cameras Logo
435 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
