Question about Boating
Autohelm mast Wind speed unit. Bottom bearing worn out. Can this be replaced, or where can I get a full replacement unit. Len
  • 38 Answers
Here is post copied from other person with same problem
I recently, had a problem were my ST50 Wind mast Head unit was not giving an output to the display for wind speed. Having removed the unit I found the bearing supporting the rotor had collapsed and hence allowed the indicator to rotated but not on a true axis and hence there was no output signal. A little investigation found that the bearing and the Digital Position sensor (Honeywell SS 411-A, the bit that measures the 4 magnets on the rotor) could be purchase from Radio spares at http://uk.rs-online.com/web/ the RS part numbers for those interested are: -
Honeywell SS 411-A = 181-1463
Rotor bearing = 612-5739
The unit is now working as new all for under Ten quid.
Posted on Jun 21, 2010
Testimonial: "Thanks very much. I will contact."
  • Diego Mar 29, 2013
    Could you please tell me how to get the bearing out of the case? Thank you in advance
  • 64 Answers
The part number for the lower pod is Q002. I am willing to bet that Raymarine will not have any more of these. The new ST60+ version will read faster than what the wind is actually.
Posted on Jun 14, 2010
Testimonial: "Thank you for your advice"
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Nov 22, 2014 | Boating
Autohelm st50 wind
Go to Raymarine.com to find the usermanual for these units. They should be helpful.
May 06, 2013 | Boating
High pitched noise with use
The problem was the seal was worn, allowing liquid to seep past into the top blade shaft bearing washing out the grease and ruining the bearing. The "noise" you heard was the bearing running without any lubrication. Both bearings and the seal needed to be replaced but I have not found a source for purchasing these. Vita-Mix Company does not sell parts, they sell units (outrageously priced units)!
Sep 03, 2012 | Vitamix 5000 Work Top Blender
Is there someone wo can show me visually how to replac the strint
Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit.
Replace empty spool with new full one or wind on aftermarket string. Wind in direction of
arrow on spool.
Apr 18, 2010 | Black & Decker 14" Grass Hog Xp...
I have a black & decker gt701 strimmer. i recently replaced the line on the spool but now it wont feed, ??
arrow on spool. Make sure spool is seated on rachet firmly.
Apr 16, 2010 | Black & Decker Garden
04 corolla. Oil light comes on. Full of oil.
the oil pump on any car is rarely the cause of low oil pressure. if you remove the oil pressure sending unit and install an oil pressure gauge,even the type you can buy as an add on,and the reading you get is low.the problem is genrally worn out main crankshaft bearings.to avoid unneseary replacement of these,you should buy some plasti-gauge from an auto part store remove the bearing caps one at a time and measure the clearance this way.there is a risk here because the smallest grain off dirt that getts into the bearing, crankshft will ruin the bearing when you restart it.if these are worn out you probabably shoul consider replacing the engine because the other bearings are probably also worn out by this time.
Feb 15, 2010 | 2004 Toyota Corolla
Autohelm st50 how to calibrate??? wind instrument
I had one. Don't think you calibrate it. Reading is relative to it's mounting base. To change the direction reading, you would need to rotate the base.
Jun 10, 2009 | Boating
Machine won't spin
you both may have a slipping belt, but not likely. the belt is easy to replace, but you have to get under the unit to access the belt. then just turn the new belt onto the pulleys.
i would guess you may have a drain problem thats causing the unit to not spin properly. make sure the unit is out of water before it goes into the full spin speed, if not then it wont get up to full speed spin.
if it wont drain all the way, then check to see if the pump is plugged with lint or just may have a worn bearing in the pump.
Dec 28, 2008 | Washing Machines
Fitting new antena aerial to Saab 93
Len-
The replacement only costs about $20. The dealer can also provide a replacement but it can cost upwards of $50+. Part number is 5035944.
The hardest part is removing the metal sleeve from the mast pole. Once you get this out, refit the new mast with the teeth so the motor will pull the new mast down when you turn the radio off. refit the 17mm nut on top of the mast and then turn the radio back on. It will click a few times and then be properly set.
Justin
Strictly Saab
Melbourne, FL
Jul 07, 2008 | 2000 Saab 9-3 Viggen
Boating Logo
538 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
