Question about LG WM-2277HW Front Load Washer
Le error cleaned front filter and will not start cycle again
Water drained out c=when I cleaned front filter, unplugged for a while tired to resatr cycle and continurously getthe le error again and again
I can not locate my manual please help
  • LG Master
  • 713 Answers
LE on your machine means that the hall sensor or motor is faulty. 80% to 90% of the time it is the hall sensor. the hall sensor is located attached to the motor which is accessible if u remove the back panel. if you need any more help please reply.
Posted on May 15, 2010
Testimonial: "Thanks it may a lot help when I call the service person!"
My washing mAchine is broken?
code le = thermal overload protection
let washer stand for 30 minutes then restart
if code persist call for service
page 28 user manual
Sep 27, 2015 | Kenmore Washing Machines
Hover DYN 7164 error E16
OK Anthony! Now you have enough money to FIX the machine! LOL. First One error begets another. So forget about the errors! You are focusing on them too much! You told yourself whats wrong with this machine! OK Give Up? It is Not Draining! It is your Drain Pump Lad! Go and buy a new one, replace but remember to unplug it first. Don\'t due all that other stuff. Run the machine afterwards on a short cycle and guess what? No water!
Jan 20, 2014 | Washing Machines
LE error on LG 2277HW
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Oct 15, 2012 | LG WM-2277HW Front Load Washer
Have l g tromm # wm2277HB drum stoped truning and code on front says L E
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. --------------- Unplug the unit from main outlet.Then drain the water from the machine.By disconnecting the drain pump ,There will be too much water so be care full.If you disconnect the drain pump from drain hose to drain the water it will flow on you,so keep towels ready to soak the water. Also clean the water filter. ----------------- In most of the case LE error is solved by just disconnecting the washing machine from main power outlet for 30 minutes.But if the problem is still the same then try cleaning the filter and draining the water from drain pump.This error occurs when motor stops functioning and water does not drain. --------------Also another cause of LE error is Regarding the LE ERROR CODE. This code is also caused by having a residue on the sensors in your unit. You have to use a HE liquid detergent.If you use fabric softener use half of the recommended amount and dilute if it is concentrated. Once a month (for a family of four) put 3 cups of white distilled vine-ager directly into the drum and select sanitary cycle or the hottest cycle you can. This prevents residue from forming in your unit and causing the LE ERROR CODE. ---------------- This should help.Thanks.Helpmech,.
Mar 25, 2011 | LG Washing Machines
The washer is saying LE what does this mean. I had it on delicate cycle and now there is water in the machine and it needs to spin out. Help.
Apparently "LE" can mean a million different things - everything from "your drain motor is burned out" to "your drain filter is clogged" to "you used too much soap". I have found that usually it is the latter. I gather that what "LE" really means is that the drain flow rate is not high enough. Here's the quick fix that you hope will work, and that has always worked for me (knock on wood):
1. Get a 5-gallon bucket (or a little less)
2. Open the little door on the bottom left of the front (pry it open with a quarter, like it says in the owner's manual)
3. There is a drain hose with a plug in it. Pull out the plug and let the water drain into the bucket
4. There is a gross trap/filter in that same door. After draining, unscrew that filter, remove and clean out, then screw it back in place.
5. Replace the plug in the drain hose, and close the door back.
6. Try running the washer again, but don't add any soap. If it was the filter that was clogged, the washer will run to completion, everything is fixed, and you can start your free happy dance.
7. If it stops again and gives the "LE" again (likely), then drain the water into the bucket again, replace the plug, and start the washer at the beginning again without adding any soap. Usually by the third time I do this, the washer will run to completion and I can commence the free happy dance, followed by the gentle reminder to my lovely spouse not to use too much soap, that the washer actually cleans better with the right amount of soap, even on those extra dirty clothes.
Hope this helps!
Feb 21, 2011 | LG WM-2277HW Front Load Washer
LG WM0642HW ALWAYS HAVE (LE)
Jan 25, 2011 | LG Washing Machines
Le error code on my LG washer.
On LG Washers the code LE is for motor overload protection.
Ensure that you are not overloading washer, make sure to clean pump by draining at little door at lower left corner(check manual for instructions), unplug for 30 minutes to reset, now try running cycle again. if it fails again something else is causing the motor to work to hard and will require a professional.
Apr 25, 2009 | LG WM-1832C Front Load Washer
LG WASHER WM1832CW HAS LE ERROR MESSAGE
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
Jan 15, 2009 | LG WM-2277HW Front Load Washer
WM1832CW, wont drain and spin, has LE error, was able to drain water, using spin only function, still would not spin, sounds abnormally, drum is not moving at all. I know LE means motor overload, but what...
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Dec 12, 2008 | LG WM-2077C Front Load Washer
LE ERROR CODE ON LG WM-2277HW
Don't call service, they will rip you off!
See posted titled "LG Tromm WM2277HW will not spin"
Aug 30, 2007 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
231 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
