Question about Canon FAX-L1000 Plain Paper Laser
Canon Fax L100 - How to set time
How to set time
  • 82 Answers
Simple,
open cover that is used for one touch speed dial buttons on the control panel, press the button called data registration, then look for keys that go up,down, left and right and use them to scroll to to initial settings and press the set key to choose the date and time and set the correct date and time and press the set key to complete or choose that function and the up/down or left/right to make changes.
thank you,
mikey
Posted on Apr 03, 2008
On our cabnon l100 we are trying to send faxes. After entering fax no. we are getting message saying *Memory* Set Doc - but fax does not go - what have we done wrong?
try to check the memory of your fax, their might possible that the memory is full and need to clear them. Just a thought hope it helps thanks.
Sep 15, 2011 | Canon FAX-L100 Plain Paper Laser Fax
Fax L100 codice errore durante rx 0033
Information from service manual Canon L100:
Error Code 0033 :DCN was received through a non-normal procedure
Jan 18, 2011 | Canon FAX-L100 Plain Paper Laser Fax
What is a com 01 error?
Information from Canon L100 Service manual
Error code 0001 : The sender may not be using a G3 fax machine
Dec 23, 2010 | Canon FAX-L100 Plain Paper Laser Fax
How do I locate the switch for the Canon L100 fax machine?
wich switch, the macine is automatically turnd on when gets the current.You only have the copy buttton that you need to press if you want to copy, and for return yust red one two times.
May 19, 2010 | Canon L120 Fax Laser Printer
FAX MACHINE CANON L100 ,RX ONLY BLACK PAPER?
Change toner,it may be damage.So you can change.
Dec 14, 2009 | Canon FAX-L1000 Plain Paper Laser
Canon Fax L100 has Comm Error. Seems to re-appear often. Presently not recieving faxes. Please help!
evry time press red button to clear it. It means that there are interferences in send or recive. Check your tel. lines.
Oct 09, 2009 | Canon FAX-L100 Plain Paper Laser Fax
How do reset the time on Canon L100
Press Data Registration, select Timer settings, press set and you will see the time and calender. Enter each digit from left to right and then press set
Mar 26, 2009 | Canon FAX-L1000 Plain Paper Laser
Canon-l100-fax
Under user mode (MENU), there must be something like user sett.
Feb 19, 2009 | Canon FAX-L1000 Plain Paper Laser
Storing FAX numbers in Canon FAX-L100
Hi - You can download the manual from the link underlined in blue below:
FAX-L100
See page 4-6:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jul 31, 2008 | Canon L120 Fax Laser Printer
Just flip the little key cover open on the right hand side of the machine then press "Data Registration" then press "Set" then press "Set" again this will put you on time & date setting if you press "Set" a third time you can now change the settings using the arrows to step around and the numbers to change the settings. Just press "Set" when finished to save your setting & press "Stop" to exit programming mode.
Oct 30, 2007 | Canon FAX-L1000 Plain Paper Laser
Canon FAX-L1000 Plain Paper Laser Logo
237 people viewed this question
old marine
old marine
