Question about Onkyo TX-DS696 Receiver
Onkyo TX-DS696. No right channel speaker sound
Onkyo TX-DS696. I have no right channel speaker sound. Could it be a fuse blown and I can do a DIY fix
  • 1,527 Answers
Hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
Posted on May 15, 2010
Testimonial: "Thanks - i'm gonna hv to take in in for the experts as i couldnt see anything visually."
Onkyo TX-DS696 receiver center channel not working
Can you say explicitly that the Center Channel speaker is defined as something other than NONE?
And how does dialog sound? If it sounds ok you're routing it to the front speakers. This is from the manual...
"For ideal Surround effects, all speakers should be installed. If a
center speaker or subwoofer is not connected, the sound from the unused channel is properly distributed to the connected speakers in order to produce the best Surround sound possible."
Apr 10, 2010 | Audio Players & Recorders
I turn it on and the words "protect" comes on and shuts down, i know its an internal problem but how can i fix it withought going to a "chop shop" and just by doing it myself
Find the cause of the problem, either a blown fuse or a shorted output stage. Not so easy to find the cause but you can try. Or it could be caused by other things.
Apr 07, 2010 | Onkyo TX-DS696 Receiver
Onkyo TX-DS 595 receiver surround channel unrealiable
How you power off the amp won't hurt it generally. I used to fix ONKYO amps under warranty, and I can tell you now, it will be full of dry solder joints. Take you unit to your local repairer, and they will resolder all the offending PCB's inside. This type of repair will fix 99% of strange audio noises and cutting in and out etc. for ONKYO recievers. Otherwise this is quite a good product.
Oct 27, 2009 | Onkyo TX-DS595 Receiver
No sound when dvd input is selected on onkio tx-ds696
Make sure your DVD setting is looking at the right audio inputs. Usually there is a menu option or a button to toggle from analog or digital input. Usually when no-sound but video ok, you have the wrong input-type selected. If you are using 2 RCS's (red/white) then you want ANALOG input mode. If you are usung a single RCA (orange) or a fiber optic input for audio, you want DIGITAL input selected. If digital os selected, make sure you plug into the correct digital input to hear. If it does not work at first, mofe the jack/fiber around into the different inputs untill you hear sound, then you will know which port is associated with the DVD setting. Unless it is self evident feom the menu.
Jun 12, 2009 | Onkyo TX-DS696 Receiver
No sound from Left and Right front speakers
You didn't state it but I assume the other channels are functional?
The auxilliary channels are generally lower power and may even be serviced by a different voltage than the main amps. If it is so designed, you may have something as simple as a blown fuse for the main amp supply.
If the aux. channels are equal in power, the power supply may still be dividing the load so a fuse still could be at fault. The unit could also use integrated power amplifiers in which case, if two channels are operating from a single module it could be a module failure.
I don't see much chance of anyone repairing this system without examining it in the first person.
Jan 04, 2009 | Onkyo TX-DS989 Receiver
Onkyo TX-28 Receiver Output Problem
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Sep 02, 2007 | Kenwood VR-305
Only the Front Right Channel is working.
it sounds like to me the transistors might be out in it they are on the heat sink inside check to see if there are any ones blown
Jul 29, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-DS696 Receiver Logo
649 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
